lmml 14/32
Airport CAT And Acft Requirement
Wed Aug 06, 2003 11:27 am
What are the WX minimas needed for CAT I, II and III airfields for B732, B733 and A320?
goboeing
RE: Airport CAT And Acft Requirement
Wed Aug 06, 2003 12:04 pm
Usually, CAT I minimums are 200' AGL, CAT II is 100' AGL, and CAT III I don't know much about but 50' AGL comes to mind, but there's other things involved for III.
Nick
mjzair
Wed Aug 06, 2003 12:18 pm
ICAO -
CAT I
DH - 60m 200FT
RVR - 550m 1800FT
CAT II
DH - 60-30m 200-100FT
RVR - 350m 1200FT
CAT IIIA
DH Lower than 100FT or no DH
RVR - 200m 700ft
CAT IIIB
DH - Lower than 50ft or no DH
RVR - 200-50m 700-150Ft
CAT IIIC
No DH
No RVR
[Edited 2003-08-06 05:19:43]
Sat Aug 09, 2003 1:10 am
In Cat.IIIa operations (747) the "alert height" generally occurs between 30 and 50 feet AGL... the approach is flown on autopilot with autoflare capability. The aircraft we so operate are technically capable of Cat.IIIb operations (again autopilot) but the 747 is not approved to these minimums.
xxx
There are two Cat.II minimums, (I call them the 150 and the 100 Cat.II DH). One requires full equipment working, the other permits approaches to the higher minimums with some equipment inoperative...
xxx
Happy contrails  Smile
(s) Skipper
AM
Tue Aug 12, 2003 1:39 am
When can the autopilot be disconnected in CAT II and CAT III approaches?
"... for there you have been and there you will long to return."
covert
Tue Aug 12, 2003 8:50 am
Reread the last posts, that is the decision height, or minimum.
covert
none
lmml 14/32
Wed Aug 13, 2003 2:38 am
Just learnt that our company has established its own minimas:
CAT I: 800mtrs
CAT II: 300mtrs
CAT III: 200mtrs
This is for B737 only. Don't know what the minimas are for the Airbus yet.
Mjzair mentioned CAT IIIA and CAT IIIB. What is the difference?
mjzair
Wed Aug 13, 2003 7:32 am
Lmml 14/32:
The difference is in the RVR or Runway Visual Range.
IIIA Must be at least 200m
IIIB Can be 200m all the way down to 50m
Users browsing this forum: Baidu [Spider], CosmicCruiser, flyingcello and 21 guests
