Olympic A-340
What Is The Purpose Of "drooping" Ailerons
Mon Aug 18, 2003 12:56 am
After looking at some pictures of my favorite airbus planes as well as some 777/767s, I began thinking: what is the purpose (from an aerodynamic perspective) of drooping ailerons?
buckfifty
RE: What Is The Purpose Of "drooping" Ailerons
Mon Aug 18, 2003 1:35 am
Drooping ailerons act as additional high lift devices to augment the flap during t/o's and landings. Though from my knowledge, none of the planes you mentioned above have them.
They're usually found on fighter planes or STOL aircraft. One plane I know for sure that had them was the Twin Otter.
FDXmech
Mon Aug 18, 2003 2:26 am
In my experience the A300-600 has them.
Also, the MD11 has them, though Fedex deactivated theirs due to reliability issues.
gordonsmall
Mon Aug 18, 2003 2:46 am
The A319/20/21 all have drooping ailerons, the ailerons droop 5 degrees when the slats are extended I believe.
Not sure about the bigger Airbus aircraft or any of the Boeings though.
Gordon.
Statistically, people who have had the most birthdays tend to live the longest.
fritzi
Mon Aug 18, 2003 5:42 am
Just to add what Gordonsmall said:
The A330 and A340 also have drooping ailerons.
AJ
Mon Aug 18, 2003 7:41 am
"Though from my knowledge, none of the planes you mentioned above have them."
Both the 767 and 777 have inboard ailerons that droop with trailing edge flap extension.
The reason Boeing gives for drooping the 767 ailerons is to lower the nose attitude on approach for visibility and commonality with the 757's attitude.
UAL747
Mon Aug 18, 2003 9:16 am
The 777's outer ailerons also droop FYI.
UAL747
buckfifty
Mon Aug 18, 2003 11:40 am
Ah. Learn something new everyday.
SAAB340
Mon Aug 18, 2003 11:42 am
Can someone post a picture that displays a good example of this?
Paul
AJ
Mon Aug 18, 2003 1:13 pm
Paul:
Photo © Deborah Spragg
Photo © Wietse de Graaf
Slcpilot
Mon Aug 18, 2003 2:10 pm
I think the following picture may be a better example that shows a "drooping" aileron. One can't conclusively make that assumption from this picture; however, since it only shows one aileron and the plane might be in the process of rolling out of a turn....
Photo © Alejandro Ramos Garduño
An interesting sidenote..... As a kid I remember doing a few space-A flights on a C-5A. It seems they had some wing fatigue issues, and as a result reflexed the ailerons UP six degrees in cruise to reduce the moments on the wing and the associated wing flex. I think most of the C-5As were later re-winged, but I'm not certain...
SLCPilot
I don't like to be fueled by anger, I don't like to be fooled by lust...
suspen
Mon Aug 18, 2003 4:44 pm
In 1981, C-5As started receiving new alloy wings. The program was complete by 1986.  Smile
Tower: "Cessna xxxx, state your intentions", Cessna: "To become airline pilot"
RyDawg82
Mon Aug 18, 2003 7:54 pm
Hey I had this same post about 2 years ago, some good info on the 767/777 == check it out...
http://airliners.net/discussions/tech_ops/read.main/24822/4/
Ryan
You can take the pup out of Alaska, but you can't take the Alaska out of the pup.
Ejazz
Tue Aug 19, 2003 9:01 am
The B777 has outboard ailerons and inboard flaperons. Both droop when flaps are extended.
Etihad Girl, You're a great way to fly.
JBirdAV8r
Wed Aug 20, 2003 9:43 am
Okay, to add another question into the mix...
When I was on a 764 flight I noticed the right inboard aileron deflected a few degrees upward in level flight. Is this AFCS-related? I don't think it would be, since it seemed to stay stationary.
