Red Panda
What Is The Black Smoke Coming Down From The Gears
Thu Aug 21, 2003 2:18 pm
Photo © Serge Bailleul
It is normal to have smoke coming out from the rubbers on landing, but what is that smoke falling down from the gear on takeoff?
r panda
AJ
RE: What Is The Black Smoke Coming Down From The Gears
Thu Aug 21, 2003 2:22 pm
During the retraction cycle of the undercarriage the rotation of the wheels is stopped to prevent gyroscopic rotational forces. When the brakes are applied it can cause any excess grease/dirt etc. to burn off as the brakes are absorbing quite a bit of energy, iplus the heat absorbed during taxi.
You can imagine the stress the brakes would be under in a rejected takeoff!
JBirdAV8r
Thu Aug 21, 2003 2:34 pm
It also stands to point out that the tires aren't smoking, but the brakes  Smile/happy/getting dizzy
As AJ already mentioned, I'd guess this particular airplane had a recent RTO or, perhaps, an extended taxi.
AA737-823
Thu Aug 21, 2003 2:38 pm
Actually, my understanding is that, while both of the above explanations are correct, the actual stuff you see is carbon- because they're carbon brakes, not steel anymore. When the system 'steps' on the brake pedal during retraction, the wheels stop pretty quickly, producing a puff of black carbon powder from the braking surfaces.
R
AJ
Fri Aug 22, 2003 12:46 pm
Another example:
Photo © TTT
Bronko
Fri Aug 22, 2003 1:18 pm
So why is this not seen on a regular basis? Does this only happen on a visible level when the breaks are new?
Jet City Aviation Photography
jwenting
Fri Aug 22, 2003 1:35 pm
It only happens when a lot of brake power is used during taxi or when putting on the brakes before gear retraction.
It might also have to do with environmental conditions (if there's a lot of wind the stuff would probably disperse quickly so you don't see it for example).
Personally I've never really noticed it.
I wish I were flying
flyingbronco05
Fri Aug 22, 2003 1:57 pm
This has been discussed multiple times in the tech/ops forum.
Do a search Smile
fb05
Never Trust Your Fuel Gauge
DC10GUY
Fri Aug 22, 2003 2:19 pm
You will see this on aircraft with "carbon brakes" .
Next time try the old "dirty Sanchez" She'll love it !!!
bio15
Sat Aug 23, 2003 12:47 am
AJ: I'm probably not very familiar with the subject, but I always thought that the stopping of the rotating wheels was to prevent further damage given a tire blowout during retraction inside the bay. Is that correct?
-Alfredo
Users browsing this forum: Vinothkris, Yahoo [Bot] and 1 guest
