upsmd11
A300 Winglets Or Not...
Sat Aug 30, 2003 10:20 am
Photo © Frank C. Duarte Jr.
Why does this aircraft not have winglets? When did AI start putting the winglets on the A300? Is it an option?
I don't know the full history of the A300 so some background would be helpful.
John
FDXmech
RE: A300 Winglets Or Not...
Sat Aug 30, 2003 1:08 pm
The A300-B4's (your picture) have no winglets.
The A300-600's have winglets.
The A310-200 have no winglets.
The A310-300 have winglets.
crewchief32
Sat Aug 30, 2003 8:07 pm
FDXmech,
Hapag-Lloyd A310-200s have been modified with winglets a few years ago.
CC32
Bekol
Sat Aug 30, 2003 8:37 pm
Also for China Northwest (now China Eastern), one (B-2303) of their A310-200s is equipped with winglets.
Bekol
fritzi
Sat Aug 30, 2003 9:34 pm
One small note, they are not winglets, they are wing tip fences.
The only airbus with winglets are the A340 & A330
CPH-R
Sun Aug 31, 2003 6:26 am
Am I correct in assuming that it's called winglets when the entire end of the wing is "curved up", and wingtip fences when it's only a small part (or something like that)?
aloges
Sun Aug 31, 2003 6:46 am
A "fence" extends both up and down, as you can see here:
Photo © Justin Cederholm
Photo © Tony Edlind
I assume that the downward extensions also play an important role, since modern aircraft with wing-mounted engines do not have fences, but pylons that do what the fences would do. Again, I'm certainly not an expert at aerodynamics.
By the way, I've always been wondering if this is an exotically-shaped winglet or a wing tip fence:
Photo © Markus Wisler
Anyone?
EDIT: reading the question once more, I just noticed that I might be wrong. However, my guess is that a winglet curves up (only), but a wing tip fence curves up and down, while it doesn't matter if it covers the entire length of the wing tip.
[Edited 2003-08-30 23:50:04]
gigneil
Tue Sep 02, 2003 9:14 am
The MD-11 is a winglet with a small fence.
N
Users browsing this forum: AAirbusCA, Starlionblue and 1 guest
