codeshare
ERJ 145 APU.
Sat Sep 06, 2003 5:10 am
The APU of this a/c is very noisy. I believe it's one of the loudest out there.
Why is that?
How much A is there is Airliners Net ? 0 or nothing ?
BR715-A1-30
RE: ERJ 145 APU.
Sat Sep 06, 2003 8:04 am
I agree. Of all the aircraft I have seen, and heard, the ERJ APU is very noisy. The CRJ is a whisper compared to the ERJ. I got to tour the inside and out of the FLJetconnect CRJ, and when I walked around the back, it was quiet, and the APU blew it's warm exhaust all over me and it felt so good from that 32 degree cold weather in ATL.
Puhdiddle
E1FAIL
RE: ERJ 145 APU.
Sat Sep 06, 2003 8:40 am
Did the APU you heard have the silencer installed? There is a huge difference between the silenced and unsilenced versions.
codeshare
RE: ERJ 145 APU.
Sun Sep 07, 2003 6:48 am
Perhaps it costs a lot. Maybe that's why some airlines don't have it.
ramper@iah
RE: ERJ 145 APU.
Sun Sep 07, 2003 8:49 am
The APU is only loud if you are standing directly beneath it, otherwise, it's bearable to work anywhere around the aircraft without ear plugs. It is possible that you could be mistaking the sound of the air conditioning packs for the sound of the APU. The AC packs are located on each side of the aircraft near the forward wing root. The high pitch noise is piercing, so it is typical to only use the right pack while the main cabin door is open. The left pack, of which 75% of its air goes to the cockpit, is usually turned on after the engines are started. While they are noisy, one can't complain of their effectiveness. They'll actually blow snow into the cabin even when the outside air temperature is above 100 degrees!
codeshare
RE: ERJ 145 APU.
Mon Sep 08, 2003 1:37 am
I saw a Swiss E145 with a sort of nozzle on the APU. And it was much more quiet.
jetdoctor
RE: ERJ 145 APU.
Mon Sep 08, 2003 10:45 am
Ramper@iah
Being technical, the "snow" would be really hail hehehe, I do agree the packs works well.
As to why the APU is loud? It just is. Try writing to Hamilton Sundstrand (it's manufacturer) The silencer helps a lot, but it is just a very loud APU. But it works (75% of the time, unless it is winter when glycol gets in there)
Jetdoctor
Break ground, and head into the wind. Don't break wind and head into the ground.
ramper@iah
RE: ERJ 145 APU.
Mon Sep 08, 2003 1:34 pm
"Being technical, the "snow" would be really hail hehehe..."
Yeah, you're right. Those little ice pellets that fly through the cabin get annoying. One passenger complained to the flight attendant that someone was shooting spit-balls at her. I'd rather have the frozen precip in the cabin any day over sitting in the sweltering heat like an MD-80 or a classic Boeing.
drewwright
RE: ERJ 145 APU.
Tue Sep 09, 2003 9:49 am
I had the opportunity to compare APU's on ERJ's a couple of weeks ago in MSY. Our plane parked right next to another company plane that had the old short exhaust pipe on it, and even inside our cabin I had to stuff TP in my ears to avoid hearing damage. There is quite a difference in noise levels between the two APU's. As noted above, the A/C packs generate quite a bit of noise too (as well as snow in the cabin). It is always funny when the flight deck switches both packs on because you can hear the ice moving through the ducts right before the pellets spit out onto the pax.
