tarzanboy
Boeing 757/767 Illuminating?
Tue Sep 23, 2003 10:48 am
hi...
just curious...is there a warning light in the cockpit of the 757 or 767 that tells the crew that the tail had striked the ground??
m717
RE: Boeing 757/767 Illuminating?
Tue Sep 23, 2003 11:12 am
Not on any 757 that I have flown. You must visually inspect the tail section from the outside.
fspilot747
Tue Sep 23, 2003 11:49 am
Tarzanboy, instead of starting all these threads about tailstrikes this tailstrikes that, just start a single thread and ask all the tailstrike questions your heart desires!
FSP
HAL
Tue Sep 23, 2003 3:18 pm
The 767-300 has a 'tailskid' light, but not a specific 'tailstrike' light. The 'tailskid' light comes on if the position of the retractable tailskid does not agree with the landing gear handle position.
That said, yes, it would probably come on after a tailstrike if the landing gear handle is down, since the 'up' position of the skid now disagrees with the 'down' position of the gear handle. In this plane, the most common time for a tailstrike is on landing, so if you see the light on after touchdown, most likely you did scrape the skid.
However, at Hawaiian when we first got the 767's, we had a few incidents where the skid had obviously touched the runway (scrape marks) but the light didn't come on (not hard enough to move the skid). Maintenance is required to do an inspection anyway, but there wasn't a sure-fire way to know after each flight whether or not it was a new scrape, or an old one. They first tried painting the bottom of the skid, but that came off with the coffee and hydraulic fluid that always seeps out along the bottom of the fuselage. The final answer was to wrap safety wire around the base of the skid, and make it part of the preflight inspection. Wire there = no strike. Missing wire = inspection.
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
cdfmxtech
Wed Sep 24, 2003 1:28 am
The B757-300s have a TailStrike EICAS message. They also have the Tailskid message to show a disagree btwn ldg gear position and talskid position.
Digital Flight Mgmt software not incorporates a Pitch Report to be viewed by the flightcrews. They can check the rotation attitude once they have lifted off. (Available, but not standard I don't think).
tarzanboy
Wed Sep 24, 2003 11:16 am
thanks to the guys who replied with sense, who replied not being selfish....
one more thing HAL; when doing 767 groundschool and simulator training, did your instructors ever teach to initially rotate to five (5) degrees to get off the runway?
is it ok and advisable to initially rotate to 5 degrees on the 767?
HAL
Wed Sep 24, 2003 3:42 pm
On the 767 we are taught to rotate at 2 1/2 to 3 degrees per second to an initial pitch attitude of about 15 degrees. According to our ops manual, the liftoff should occur as we pass through 7 1/2 to 10 degrees pitch up. Then, once airborne, pitch up to maintain an airspeed of V2 + 15 knots, up to V2 + 25 knots.
It's rotating too fast that can get you in trouble with a tailstrike.
HAL
Users browsing this forum: No registered users and 18 guests
