QANTAS747-438
Victorville/Mojave Storage - What Is It?
Wed Sep 24, 2003 1:49 pm
I tried a search on this but didn't find what I wanted. I'm very curious about Mojave and Victorville storage facilities. What is the point of a place like this?
Also, I'm curious as to if an airline later chooses to fly this plane... what kind of condition could it be in sitting in the roasting sun of the desert 24/7? Wouldn't the cabin be musty inside and have bird droppings on it, and creatures crawling all over it?! And what about the equipment and fuel lines and all that?
According to the photos, it looks like they just threw the planes there with no care. It's not even an asphalt taxiway!
Any help in helping me understand this would be appreciated! Thanks!
Photo © Sam Chui
Photo © Sam Chui
RE: Victorville/Mojave Storage - What Is It?
Wed Sep 24, 2003 3:38 pm
Desert storage, is better than storage in any other (humid) areas. The planes are stored, and if they are meant to be flown again, they are stored with ample protection (engine covers), and avionics well protected... old tires are often fitted which are not reused for future flying of that aircraft.
xxx
I have taken airplanes out of Mojave or Victorville, that were stored for over 2 years, or sometimes more... sure, there are some mechanical problems, but they are properly inspected before flying again.
xxx
The other point is that storage at these airports is inexpensive, I cannot remember the numbers, but less than $1,000 per airplane per month. There are other locations as well, Kingman, and near Phoenix, in Arizona...
xxx
Happy contrails  Smile
(s) Skipper
COSPN
Wed Sep 24, 2003 7:14 pm
see www.cactuswings.com for aircraft in the desert..the ground is hard and can support the aircraftt and it almost never rains so it is the best place to store them to refly or to preserve the "parts" for later..
IMissPiedmont
Thu Sep 25, 2003 2:46 pm
here are several levels of storage here in the desert.
The cheapest is land and park where nothing is done, the airplane will be scrapped.
The most expensive is when the airplane has all possible openings covered including windows. Every 90 days the aircraft is moved a bit so the tires rotate 90 degrees and the hydraulic system is tested. An inspector checks all the seals and any getting questionable are replaced. One particular AAirline, which I will not name, goes so far as to replace all tires and brakes on any aircraft being returned to service, no matter how long in storage.
And, in all my years at MZJ, I have yet to see an aircraft fitted with old tires for storage. Of course it's only been 20 years so I might have missed one or two. Tires are cheap to keep, hubs and brakes are not.
The day you stop learning is the day you should die.
