AA7771stClass
Lines Above The Doors...
Thu Sep 25, 2003 8:43 am
Apologies if this has been discussed before, the search didn't turn up anything. If you enlarge the picture below, especially in the large version, one notices lines the width of all the cabin doors above the doors. Can someone explain what these are/why they're there...?
Photo © Chris Coduto
Staffan
RE: Lines Above The Doors...
Thu Sep 25, 2003 8:52 am
I'd assume they are there to stop water etc. running down over the door when the aircraft is on the ground.
Staffan
OPNLguy
Thu Sep 25, 2003 9:22 am
He's correct--it's to channel the water away from the open doorway.
Think "very small rain gutter"...
AA7771stClass
Thu Sep 25, 2003 10:59 am
Wow, how thoughtful. Thanks guys...
bio15
Fri Sep 26, 2003 8:17 am
BTW that's a freakin' good picture!!
cptkrell
Fri Sep 26, 2003 9:30 am
Draingutters, yes, kinda like all cars and trucks used to have (before they went "aero", of course). You will notice that they are mostly all installed at an angle when viewed from the side to directionally channel water to front or rear, depending on door location, and not interfere with airflow...jack
all best; jack
OPNLguy
Fri Sep 26, 2003 10:26 am
Here's a shot that shows them pretty well...
http://www.airliners.net/open.file/429574/L/
The front ones (at least on the 737s and some other Boeings) is at more of an angle to compensate for the nose curvature, which you can see in the photo above. The one over the aft service door is closer to being level with the aircraft...
L-188
Fri Sep 26, 2003 3:18 pm
Being level is not a good thing, it would allow water to sit in the channel, inviting corrosion. So you will never see one of those gutters perfectly level.
OPNLguy
Fri Sep 26, 2003 9:09 pm
Agreed; that's why I said "closer to being level"...  Big grin
COSPN
Fri Oct 03, 2003 5:16 am
The 747 is Kind of flat to the Jetway so we have to use a plastic gutter we rigged up so the PAX dont get wet..only when it rains hard, and it does happen on out Tropical Island of Saipan..
Users browsing this forum: atalanta89 and 17 guests
