levg79
Controls For Taxi
Sat Sep 27, 2003 11:53 am
Hey guys,
Please don't make fun of a new airplane fan, but I was just wondering if anyone could tell me how the pilot controls the airplane while he taxies to the runway or back to terminal.
Does the pilot use rudder pedals or yoke to turn the wheel? Or is there another way of controlling the direction while on the ground? Any help would be appreciated.
A mile of runway takes you to the world. A mile of highway takes you a mile.
flyboyaz
RE: Controls For Taxi
Sat Sep 27, 2003 11:57 am
It's a good question! They use the rudder mostly and on large planes, like commercial airliners, they also stear the nose wheel. Most smaller planes simply use the rudder pedals.
Catch a ride on a smile!
levg79
Sat Sep 27, 2003 12:12 pm
Then the next question would arise....what do they use to steer the nose wheel? Is there something similar to a steering wheel hidden in a cockpit?
P.S. Please don't make fun of my stupid questions.
goboeing
Sat Sep 27, 2003 12:16 pm
There is a steering "tiller" in the large jets. It's a wheel on the captains side if you see any cockpit pictures. It steers the nosewheel to the full turning capability. The rudder pedals only steer up to about 10 degrees I've been told.
Nick
Sat Sep 27, 2003 3:08 pm
In the 747, both captain and co pilot have a "steering wheel" (tiller)... there were other airplanes with the option of installing a tiller on the co-pilot side. I have seen a few 707s so equipped...
xxx
A reduced amount of steering (5 degrees, L and R) can be obtained in most airplanes (for takeoff and landing) through steering with rudder pedals, but tight turns for taxi require use of the steering tiller...
xxx
(s) Skipper
zak
Sat Sep 27, 2003 4:35 pm
On this picture, the airbus tiller is visible left of the sidestick.
Photo © Florian Kondziela
10=2
Spitfire
Sat Sep 27, 2003 7:52 pm
For your info, the round "knob" on top of the tiller is there to diconnect the rudder pedals input to the nose wheel while performing the "rudder check" (...feet full left then full right) during the flight controls check on the ground (during taxi).
Spitfire
[Edited 2003-09-27 12:53:53]
Sabena ... Never to be forgotten (15 years already , what a shame !! )
suspen
Sat Sep 27, 2003 8:15 pm
Levg79, they aren't stupid questions. Welcome to the forum.  Big thumbs up
Now I'm curious too. I thought some jets also used differential thrust for taxiway turning, but no one has mentioned it yet. Is that only used for "emergencies", or not at all?
Tower: "Cessna xxxx, state your intentions", Cessna: "To become airline pilot"
CX Flyboy
Sat Sep 27, 2003 8:52 pm
Levg79,
Remember that when most people reply, they are referring to specific aircraft. Don't get the idea it is the same for all aircraft.
On the 777, we have a tiller both for the Captain and FO. We usually use the tiller to steer the aircraft, however above 20kts taxying on long straight taxiways, we use the rudder. As others have mentionned, the rudder can only move the nosegear a limited number of degrees, whereas the tiller is quite sensitive and can turn the nosewheel a good 60 degrees or more. (68 seems to ring a bell but I'm probably wrong). On long straights, using the rudder means more gradual corrections to following the centreline instead of jerky movements with the tiller.
When doing the control check, the tiller is still connected to the nosegear so the rudder pedals will fight the tiller. To counteract this, we simply hold the tiller tightly when checking the rudder during taxi. If the tiller does not swing left and right with the rudder, the aircraft will not swing from side to side either.
tarzanboy
Sun Sep 28, 2003 11:31 am
skipper....
on other large crafts,,,,as well as the 747....how does the pilot avoid running off the taxiway wen he is making turns, like 90 degree turns?
how is he trained, or wat procedure is taught to avoid this mishap..and stay on the pavement...?
747Teach
Sun Sep 28, 2003 12:05 pm
Levg79: As others have said, most large aircraft have some sort of tiller or wheel to steer the nose strut while taxiing. A little differential thrust from the engines may help you, especially on tight turns. Seems to work a bit better on planes with wing-mounted engines. In this photo of a DC-9 cockpit, you can see the steering wheel on the left side.
Photo © Michael Carter
The round knob in the middle of the steering wheel sets and releases the parking brake. And you might be interested in knowing that on the 747 aircraft, when you steer the nose strut to the left, for instance, the body gear will steer slightly in the opposite direction (to the right) to prevent wheel scrubbing. Regards,
covert
Tue Sep 30, 2003 5:36 am
For the inexperienced, can the taxi process be likened to learning how to drive?
none
Tue Sep 30, 2003 6:54 am
Surprisingly to many, flying the 747 is extremely easy (very stable aircraft) but learning to taxi a 747, is not "that easy"...
xxx
Most pilots I train in the 747 come from other airplanes that are much "smaller" in size... I sometimes compare, that taxiing a 747 is like driving a "semi-truck" 18 wheeler (we have 18 wheels as well) and you have to "think" where you main gear "is" when making tight turns on taxiways...
xxx
I even sometimes teach taxi to ground engineers (mechanics) - we have a few mechanics who are qualified to taxi the 747...
xxx
Taxi in turns is not that easy with 747... if you nearly "stop" the aircraft, you are losing "inertia" momentum... and get quasi "stuck", requiring a lot of power to move again. I personally recommend a little extra power on the outboard engine (of the turn direction) to help... Taxi speed limitations in a 747 are (policy) 20 knots and 10 knots (or slower) in turns... think about your passengers in the rear if you "swing the tail" rapidly... very uncomfortable.
xxx
By the way, "steering on the runway" (nosewheel effectiveness) is as effective as a piece of "wet Kleenex"... the steering WOULD NOT HELP, if an outboard engine should fail... It is all in the "rudder" and "L/R" differential power... forget the steering, except to align yourself on the runway.
xxx
PanAm, by the way, disconnected the link, between the 747 rudder pedals, and the nosewheel steering system, since the 707 they were accustomed to, did not have a steering feature on rudder pedals...
xxx
Happy contrails  Smile
(s) Skipper
Tue Sep 30, 2003 7:04 am
Just an observation...
On nearly every Jet I've flown the biggest challenge facing the new pilot was learning how to taxi smoothly, without spilling the coffee and drinks in the back. In flight they're easy (and smooth) on the ground, well that can be an whole nuther story. Whether the problems are caused by sheer mass (B747), steering sensitivity, or touchy (grabby) brakes the results are the same.
Jetguy
ConcordeBoy
Wed Oct 01, 2003 5:07 am
Hmm.... "swing the tail" you say?  Big grin
meister808
Wed Oct 01, 2003 5:37 am
Well... thats a great video clip.
-Meister
POSITIVE RATE
Wed Oct 01, 2003 12:20 pm
Just a question in relation to the steering tiller. Is it directly connected to the nosewheel via hydraulics or is it electronically connected and simply sends a signal to move the nosewheel??
Wed Oct 01, 2003 12:48 pm
It depends upon the specific aircraft, I've flown aircraft with 3 different types - electric, hydraulic, and also direct (cable).
Spitfire
Wed Oct 01, 2003 7:37 pm
Positive rate,
It is electronically connected on Airbus A320, A330 and A 340. Then via a computer ( BSCU - for Brake and Steering Control Unit, there is two off them onboard), the nose wheel is hydraulicaly actuated ("Green" hydaulic circuit).
Spitfire
[Edited 2003-10-01 12:50:19]
gordonsmall
Thu Oct 02, 2003 1:30 am
Spitfire,
Is the steering control linear? Or does the nosegear deflection vs tiller deflection depend on speed or other factors?
Gordon.
Statistically, people who have had the most birthdays tend to live the longest.
Spitfire
Thu Oct 02, 2003 9:27 am
Sorry Gordonsmall that I can't post here a diagram coming from the Airbus FCOM. I'll try to explain...
Nose wheel steering angle varies in fonction of the ground speed. Up to 10 kts, you have 78 degrees available. Then from 10 kts to 30 kts the angle decreases from 78 to about 40 degrees. And from there ( from 30 kts to 100 kts), down to zero. That's for the input of the "manual" steering.
Concerning the rudder input, you have 6 degrees from 0 to 40 kts and then, down to zero up to 100 kts ( the rudder takes over).
All this for Airbus A330 and A340.
Rgds.
Spitfire
Users browsing this forum: BravoOne, unimproved and 1 guest
