mlsrar
GP7000 Questions
Thu Oct 02, 2003 3:34 am
I've tried to do some research on how GE/PW are joining forces to produce the GP7000, and integrating their respective technologies and components and I have yet to come up with answers to the following questions:
1) Which manufacturer is providing the majority of the engine?
2) Where will assembly take place? Given the core comes from GE, I'd assume in NC
3) What is so special about the low-spool from the PW core that is attractive to GE?
4) What does each manufacturer bring to the table that is the specialty from their technologies?
I mean, for the right price I’ll fight a lion. - Mike Tyson
manzoori
RE: GP7000 Questions
Thu Oct 02, 2003 6:52 am
I can only answer one or two of these, and then from a source which you've probably already looked at (Enginealliance.com)
4)P&W = Fan, Low pressure Compressor and Low Pressure Turbine
GE = High Pressure Compressor, Combustor, High Pressure Turbine, FADEC, and I guess everything else.
What I think it really boils down to is that neither company had the funding necessary to each come up with their own engines. Thus they form an alliance, pool cash and resources and set about integrating their respective specialities into a single powerplant whilst at the same time trying desperately to keep their respective crown jewels separate from the other.
Happens all the time!
Rez  Big thumbs up
Flightlineimages DOT Com Photographer & Web Editor. RR Turbines Specialist
gigneil
RE: Since When LCD Screens In A340-300 Cockpit?
Fri Oct 03, 2003 4:01 am
P&W is also providing the accessory gearbox and some other items.
enginealliance.com has a mouseover that you can see exactly which parts are coming from which manufacturers.
The engine is basically a scaled and improved 3d-aero GE-90 core with PW4098, lpc, lpt, and a vastly redesigned front fan.
The entire engine will be 3D-aero.
N
mlsrar
Fri Oct 03, 2003 10:04 pm
Will the fan incorporate GE's "revolutionary" chevron-blades, or will it be a PW-Titanium style?
darkblue
Sat Oct 04, 2003 2:51 am
GE does not make chevron blades. Perhaps you are thinking of chevron nozzles? The fan is part of the LP system, it will be made by PW.
DB
[Edited 2003-10-03 19:53:07]
gigneil
Sat Oct 04, 2003 4:17 am
The fan will be titanium, wide chord, and 3D styled/swept.
It will be a PW part, not a GE part.
N
BR715-A1-30
Sun Oct 05, 2003 10:30 pm
Is this engine supposed to be bigger than the GE90 in terms of Diameter?
Puhdiddle
darkblue
Mon Oct 06, 2003 7:47 am
The GP7000 has a fan diameter 116in. The GE90 is a bit bigger with the GE90-94B at 123in and the -115B at 128in. The GP7000 and GE90 have similar bypass ratios.
DB
gigneil
Tue Oct 07, 2003 1:53 am
The GE90 has an amazing bypass ratio for a current-day engine - by far the highest of its competitors.
N
