Sepang
Question On Climbing And Landing
Thu Oct 02, 2003 7:47 am
Which is the positive climb? Why there is a difference degree of climbing? Who decided? By the airlines, the pilot, the environment or the weather?
Photo © Alexander Kueh
And what happen with this landing?
Sepang
Spitfire
RE: Question On Climbing And Landing
Thu Oct 02, 2003 9:04 am
THE WEIGHT OF THE A/C.......nothing else ( in order to keep V2+10 - V2+ 20 after lift off)
Concerning the landing picture ...what happend....nothing , they surely landed safely, once more nothing special here, quite normal to make some correction in short final (cross wind maybe...).What do you think?
Spitfire
[Edited 2003-10-02 02:12:11]
[Edited 2003-10-02 02:15:56]
Sabena ... Never to be forgotten (15 years already , what a shame !! )
cancidas
Thu Oct 02, 2003 9:33 am
in the landing picture the pilot is applying crosswind correction. there are two types of correction. one it the wing-low meathod (pictured) and the other is crabbing. with crabbing the airplane is pointed into the wind and it flies diagnally. with the wing low meathod the pilot will drop the wing from which the wind is coming and use aileron to maintain drift across the runway. since airplanes can't land sideways the wing low meathod is employed while on short final to maintain centerline in stiff crosswinds and to land safely.
as for climb, airplane performance and it's weight are the only 2 factors when it comes to climb rates. the 747-400 is an exceptional airplane when it comes to climbing. the A340-200/300 is not so good, it has a much more shallow climb angle. the more powerful an airplane the bigger angle of attack (angle between the ground and the flight path of the plane) it can maintain in climbout.
all of the above actions are used daily by all pilots. positive climb refers to the fact that the airplane is gaining altitude after takeoff. it is usually announced prior to gear retraction.
i think that the first 2 pictures are actually taken on appraoch, like the last while the second 2 are climbout shots.
[Edited 2003-10-02 02:33:48]
[Edited 2003-10-02 02:35:05]
"...cannot the kingdom of salvation take me home."
Spitfire
Thu Oct 02, 2003 9:49 am
Cancidas,
"...i think that the first 2 pictures are actually taken on approach, like the last while the second 2 are climbout shots...."
Sorry but have a sharp look at the remarks of those two first picture : they are taken on take off !
We are here making some comparative between "heavy" A340, MD 11 and very "light" B747's
Spitfire
cancidas
Thu Oct 02, 2003 12:13 pm
ok, i was wrong. i did not have the time to let the pictures load to get a good look at them.
Spitfire
Thu Oct 02, 2003 3:57 pm
No problem. I'm wrong also : it's a A330 !!  Nuts
Spitfire
fritzi
Thu Oct 02, 2003 6:06 pm
Sepang,
Stop making up threads to get cheap hits on your own photos.
You´ve done it before and now your doing it again...
Users browsing this forum: David L, mmo, Starlionblue and 2 guests
