b773
Tale Fin Moved To The Left?
Sat Oct 04, 2003 5:21 am
Why do sometimes when planes are parked, they move the back part of the tail to the left?
UAL747
RE: Tale Fin Moved To The Left?
Sat Oct 04, 2003 5:39 am
It's probably moved in a certain direction because of the wind. At DFW, walk by the line up of 777's at the gate, and all of their rudders will be turned to the left because of a wind coming from the South.
UAL747
bio15
Sat Oct 04, 2003 9:53 am
I would guess it has something to do with hydraulics and the actuators on the rudder fin. Probably it's because the APU powers some system and not the other. I have seen A300's sitting on the gate with only the right low-speed aileron drooped all the way down, and the other horizontal. It is just a guess, someone please correct me if I'm misataken
-Alfredo
AJ
Sat Oct 04, 2003 12:17 pm
Pretty close, it is because the hydraulics are not pressurised, allowing gravity and wind to affect the control surfaces. The outboard ailerons on a Boeing remain level as they are mass balanced.
dc10hound
Sat Oct 04, 2003 12:39 pm
If any of the A300-600's three hydraulic systems are powered, both left and right All Speed Ailerons should be (Better be...) neutral (horizontal)....
"Eagles soar. But weasels never get sucked into jet intakes.."
bio15
Sun Oct 05, 2003 2:31 am
I couldn't find a picture of an A300 with only the right aileron hanging down, here's two with both hanging down:
Photo © Orlando Beaumont
Photo © Darcy Stevens
DC10hound,
It sounds pretty logical to me that all equal control surfaces on each side should be powered by the same systems. It would mean less risk in the event of one system failure, right?
AJ,
If the systems were not pressurized on the A300's I saw, what is a probable cause that the left aileron remained straightened horizontally?
Thanks in advance
-Alfredo
flyingbronco05
Mon Oct 06, 2003 1:59 am
It's called the rudder and or rudder tab/trim.
FB05
Never Trust Your Fuel Gauge
AJ
Mon Oct 06, 2003 8:24 am
Alfredo, the time for the surfaces to droop depends on a few factors, retention of hydraulic pressure in well sealed lines, wind or other external pressures etc.
Users browsing this forum: BravoOne, catdaddy63 and 2 guests
