cdfmxtech
Another Pop Quiz
Wed Oct 08, 2003 12:53 pm
B737-Classic Aircraft
Name the 2 causes of an illuminated System "A" Flight Controls Low Pressure Light.
RE: Another Pop Quiz
Wed Oct 08, 2003 1:33 pm
Just a guess...........assuming no wiring problems.
*No (or low) hydraulic quantity/pressure
*bad pressure switch
cdfmxtech
Wed Oct 08, 2003 11:30 pm
Actual Low Pressure condition, whether genuine or a bad switch is the first condition...
There is another cause.
NKP S2
Thu Oct 09, 2003 1:24 am
Standby rudder selected on the guarded "A" sys flt control switch.
cdfmxtech
Thu Oct 09, 2003 1:38 am
No, the light is deactivated when the Flight Control switch is placed to Stby Rudder.
dc10hound
Thu Oct 09, 2003 7:48 am
When the standby system rudder shutoff valve is closed and the system "A" flight control switch is "OFF".
"Eagles soar. But weasels never get sucked into jet intakes.."
dc10hound
Thu Oct 09, 2003 7:50 am
... orsystem "A" is low pressure (You asked for two conditions, I only supplied one in my first post...).
cdfmxtech
Thu Oct 09, 2003 9:56 am
OK...last try
With the Flight Control System "A" switch in it's normal position & the aircarft powered normally, what 2 conditions can cause the System "A" Flt Ctrls Low pressure light to illuminate.
The first condition has already been stated. An actual low pressure condition (includes malfunctioning pressure switch). There are no wiring problems.
aaron atp
Thu Oct 09, 2003 10:21 am
failure of the flight control module
dc10hound
Thu Oct 09, 2003 10:54 am
The bright/dim/test switch on the P1-3 panel is selected to "TEST".
The system "A" flight control low pressure light module L3 is pressed (to test).
That could be correct, if the system "A" flight control low pressure light module L3 is stuck in.
dc10hound
Thu Oct 09, 2003 11:18 am
Mr Boeing sez:
"Each flight control low pressure light monitors the position of the standby rudder shutoff valve when the flight control switch is in the STDBY RUD position."
"When the flight control switch is in the STDBY RUD position, the low pressure warning switch is not connected to the low pressure light. When the standby rudder shutoff valve is in the closed position, the valve position relay provides a ground to the low pressure light. When the standby rudder shutoff valve moves to the open position, the valve position relay energizes and removes the ground to the low pressure light."
cdfmxtech
Thu Oct 09, 2003 12:04 pm
CdfMxTech sez:
The question is with the Flight Controls System "A" switch in the normal position, which is "A" ON.
OK, the answer:
Post AD 97-14-03 (Yaw Damper System Modification) which was due for completion in 2000
The Yaw Damper Coupler can turn the System "A" light ON in the even that pressure to the Main Rudder PCU is less than 500 psi or when full pressure is commanded to the RPR and system pressure is less than 2,200 psi.
If you want to see what Mr. Boeing sez about this, Ref AMM 22-12-01  Big thumbs up
dc10hound
Thu Oct 09, 2003 12:48 pm
If I don't learn to pay attention to detail, I'll never get anywhere in dis biz...
 Big thumbs up
"My" (AAL) AMM doesn't have a 22-12-01. The airline doesn't have B737 Classics either....
Whoops.  Smile/happy/getting dizzy
Nice quiz tho, Cdfmx...
 Smokin cool
Users browsing this forum: OEM and 2 guests
