FrequentFlyKid
Approach Lighting
Tue Oct 14, 2003 4:47 am
I have noticed on some of my flights (both real and sim) that there are a series of red and white lights at the beginning of the runway. They change between red and white and are sometimes four in a row or two by two. This may be a very ignorant questions, but what are they and how are they used by pilots on approach?
rthrbeflying86
RE: Approach Lighting
Tue Oct 14, 2003 4:57 am
There are different versions of these lights, but the most common that you have seen is probably VASI. I'm pretty sure it stands for "visual approach slope indicator". Anyway, this system involves four lights that can each be white or red. If all four are red, the approaching plane is very low. Three reds and one white indicate a low, but not terrible, approach. Two reds and two whites are ideal, and increasing whites means the approaching plane is too high.
As I said there are different versions of these lights, and the general rule of thumb is that an even number of reds and whites indicates a correct approach.
They're quite helpful in real life (especially at night), and also in flightsim.
I'd rather be flying.
JBirdAV8r
Tue Oct 14, 2003 5:20 am
Actually....
What you are seeing is most likely a visual approach aid.
You described two types: VASI and PAPI.
PAPI, or Precision Approach Path Indicator lights, consist of four lights. If all four are white, you are high (generally on a typical runway, on a glidepath steeper than 3.5 degrees). If you see one red and three white, you are slightly high (average around 3.2 degrees). Two red and two white indicate you are on glidepath, roughly 3 degrees for most runways. Three red and one white mean you are slightly low (around 2.8 degrees typically), and four red mean you're quite low (less than 2.5 degree glidepath.)
VASI, or Visual Approach Slope Indicator, is the other kind you described.
The "two-by-two" configuration you mentioned is called a two-bar VASI and is the most typical installation that I've seen. Bars can be either red or white. Basically, a red bar indicates that you will touch down before you reach the bar; a white bar means you will touch down past it.
If the near bar is white and the far bar is red, you are on glidepath. If both bars are white, you are above glidepath. And, if both are red, you're below glidepath.
The easiest way to remember this is: Red over white, you're all right. Red over red...well....you're dead.
 Smile/happy/getting dizzy
meister808
Tue Oct 14, 2003 11:27 am
Rthrbeflying86: You describe a PAPI, yet call it a VASI. Only a PAPI will have the ability to have 3 and 1. VASIs are 2 and 2 or 4 and 0 only.
Oh, and to finish the word device to remember the colors..."White over White, and you'll fly all night."
-Meister
goboeing
Tue Oct 14, 2003 11:53 am
Maybe I could squeeze a plug in here. This one is a VASI:
Photo © Nick Onkow
And this one is a PAPI:
Photo © Samuel Lo
Nick
c172akula
Wed Oct 15, 2003 3:27 am
Goboeing: Actually the VASI you have pictured is one of the 2 bar VASI systems. I've yet to see one before, more common are the 4 bar VASI systems.
There is also a VASI system for aircraft with higher cockpits that utilizes an extra bar above the 4, this is to compensate for the larger aircraft.
Although it seems that the PAPI is the preferred system nowadays at most major airports. There are also 2 and 1 light PAPI's too.
Crazy huh?
Oh yeah: Red on White "your alright", Red on Red "your dead" for the VASI  Smile
JBirdAV8r
Wed Oct 15, 2003 5:16 am
C172Akula,
FOUR bar VASI? What are you talking about?
Two light, yes....NEVER seen a 1 light PAPI. That kind of defeats the whole purpose. I think you're speaking of a Tri-Color Visual Approach Indicator...of which I have seen a grand total of one.
Contact_tower
Wed Oct 15, 2003 8:57 am
"1 light PAPI's too."
That would be the "PLASI" - Pulse Light Approach Slope Indicator
1 light, flashing white when very high, then steady white, steady red and finaly flashing red. Used a lot here in Norway on small STOL airports. No room for PAPI along the runway in some places, and it's cheaper of course.
Photo © Konstantin von Wedelstaedt
mandala499
Thu Oct 16, 2003 5:10 am
There's the VASI, there's the PAPI... those are the standard ones.
There's the PLASI...
With VASI, it's at least 2 along track. There's the 3 along track... to allow for 747s and longer planes to use it... not sure about 4...
Then there's the T-VASI... mainly used in OZ... they use it in CGK/WIII, but bloody hell they're hard to see sometimes (I blame the haze here! the reds are easier to pick out)... They take a lot of space, but dirt easy to maintain.
Then the French invented the 3 lighted VASI... not sure what it's called... but it's just a set of 3 lights clustered together. On slope, the 3 lights go bright. Too high then I think the top one goes bright, too low and the bottom 2 go bright... Haven't seen them... perhaps it's now scrapped and they decided to use the PAPI instead. Hell, this one I saw in a 1988 BA Aerad manual...
Mandala499
c172akula
Thu Oct 16, 2003 10:44 am
Yup, simple word mistake on my part. I meant 4 LIGHT VASI and the such, not 4 bar.
Users browsing this forum: CrackInspector, OMP777X and 1 guest
