Stablizer Compartment Access Door B737 Test
Mon Oct 20, 2003 11:16 pm
What is the Function test carried out on the Stablizer compartment Blow out access door [LH side] on the B737s to prove its serviceability.
regds
HAWK
dc10hound
RE: Stablizer Compartment Access Door B737 Test
Tue Oct 21, 2003 1:28 am
AAL B737 AMM 52-49-11-5
SECTION 48 ACCESS AND BLOWOUT DOOR - ADJUSTMENT/TEST
(1) Do a blowout test on the door:
(a) Apply a device that weighs between 52-68 pounds (23.6-30.8 kilograms) on the door frame near the latch torque shaft.
(b) Make sure the latches release.
"Eagles soar. But weasels never get sucked into jet intakes.."
dc10hound
Tue Oct 21, 2003 2:14 am
BTW, per the MM, DO NOT try it this way:
WARNING: STAY OFF THE DOOR. YOUR WEIGHT CAN RELEASE THE SPRING-LOADED LATCHES. IF YOU FALL THROUGH THE DOOR, INJURIES WILL OCCUR.
Ouch.
Users browsing this forum: BravoOne and 2 guests
GZIP: Off
