ACB777
Can Airplanes Fail To Start Up?
Sat Oct 25, 2003 4:13 pm
Can civil airplanes fail to start up? What happens if a plane fails to start up after many attempts? What do airline staff exactly do to get the plane going?
CX Flyboy
RE: Can Airplanes Fail To Start Up?
Sat Oct 25, 2003 7:30 pm
A plane can indeed fail to start for a number of reasons. The fuel valves can get stuck, air valves, rotors, starter motors etc.. can all fail. Some aircraft have autostart and will manage the entire process and cease the start is a whole range of stuff happens. Most aircraft have manual starts and the pilot needs to monitor a whole range of parameters. Some failed starts require a time limit and certain procedures for a restart. Different companies and different aircraft types have differenct procedures and numbers of restarts allowed. Something like a stuck valve may mean that they cannot try a restart until the problem is fixed.
To get the plane going again, really depends on the problem to begin with. It may require a quick fix only, or it may ground the aircraft and a new aircraft has to be found. Really depends on the situation.
s.p.a.s.
Sat Oct 25, 2003 9:45 pm
I once heard a tale (never was able to confirm its veracity) but according to it soon Swissair started ops to Moscow with A320s, during one nice winter day air pressure was very low and temperature also and this combination was below the valid values that the computer had stored, specially for air pressure..
So, still according the tale, as the start is computer controlled, the black box "didn't let" the engines to be switched on, as the pressure would be "impossible" It was a minor software glitch...
As a result, a Crossair MD83 was flown to MOW to get the stranded passengers, until a revision on the software was loaded into the Bus.
Might be true... might be not... but anyhow makes a nice pilots pub tale  Smile
RS
"ad astra per aspera"
FDXmech
Sun Oct 26, 2003 6:41 am
The most common reason I've seen for an engine not starting (provided the engine is motoring) is an inop ignition system. Whether the excitor box, ignitor, ignitor lead or wiring is at fault is another story.
And of course if the engine doesn't even motor then the start valve or any wiring or switches leading up to it are probably at fault.
VC-10
Sun Oct 26, 2003 6:56 am
S.p.a.s.
I think it must be one of those myths, because if it was true how would you manage an in-flt start?
saintsman
Mon Oct 27, 2003 12:57 am
Sometimes they do fail to start. The hardest part is finding enough people to give it a push so you can bump it Big grin
cdfmxtech
Mon Oct 27, 2003 7:36 am
Simple just enable an Air/mode inhibit. From what I hear, Airbus is bizarre enough to impliment something like that in their systems. It seems like they are always trying to add a "wow" factor to their aircraft and systems.
Wow, that's a neat trick.
RE: 747 200 & 400 Range
Mon Oct 27, 2003 12:38 pm
Say - an engine does not start... OK, guys - let's move the switch to "GND START"...
xxx
"Nothing happens here"... well, could be start relay (start valve)...
Verify the CB for start valve relay... cycle it...
Well, maybe start valve opened, but "NO AIR" goes to engine starter...
Indication: engine rotor (most engines = no rotation N2)...
Verify air source - often it is an APU... is there air pressure...
I that valve open or not...
Is there is air pressure? Send mechanic to open the valve manually on the engine...
xxx
Say, that N2 shows rotation...
OK, with put the "fuel ON"... a few seconds later... still no EGT, and no FF...
No FF - fuel flow... well, is the fuel going to the engine...?
If there is FF indication... well, then, it is IGNITION which is the problem...
xxx
Problems to start an engine... simple if you analyse the problem...
Obviously, "them planes" designed by the Toulouse rocket scientists must be beyond my IQ...
That is the reason I stay on the 747 until retirement...
Thereafter I will fly my L-21...
So simple... with a start and L/R magnetos, and a manual fuel valve selector.
KISS = Keep It Simple, Stupid...!
xxx
Happy contrails  Smile
(s) Skipper
liamksa
Mon Oct 27, 2003 12:54 pm
Is this where wet starts could come into play? If the igniters failed to fire for the first few seconds whilst fuel was flowing, and then they magically did for some reason, would you have a wet start on you hands?
To avoid this situation would you motor then engine over (ie: not using igniters) to clear unburnt fuel?
challengerdan
Mon Oct 27, 2003 3:24 pm
Not a wet start, but a hot start! after a few seconds, if you don't have light-up, you usually dry-motor the engine (cranking it without putting any fuel) for a couple seconds to get the fuel out of the combustor. If you don't do this, or like you mentionned the igniters would suddenly come back on line, you would experience a sudden rise in ITT(temperature of the hot gases going to the turbine) that could potentially cause damage to the engine.
if your flight goes MX in YUL, I might be called to fix it!
Mon Oct 27, 2003 3:58 pm
A bit of education to a few of you here...
About "hot starts"...
xxx
With many hot starts (excessive fuel)...
Procedure calls to pull the "fire handle" which has a definite drawback.
The fire handle "kills the air" to the starter... thereby stops engine rotation...
Yet - the best, in case of hot starts is - "motor the engine"...
And "blow out" the tail pipe fire and excess fuel.
xxx
Most airplanes - the fire handles interrupts -
Fuel to that engine (good thing) -
Hydraulic pump (at that stage, not critical) -
Trips the generator of that engine (at that stage, not critical either) -
Shuts bleed air valves to/from engine - who cares -
The fire is not in the compressor... it is in the tail pipe...
Rotating the engine (with starter) is the best, yet...
I wish the fire handles were designed to still permit rotation by the starter.
xxx
(s) Skipper
liamksa
Tue Oct 28, 2003 9:56 am
Ah OK Skipper, so the fire handle kills the starter air and fuel supply (and the rest). I see that ideally you would keep it turning over to clear the excess fuel or tailpipe fire, so how do you "motor the engine" on a modern aircraft? Fuel cut off, igniters off, then engine start?
Photo © Mariusz Siecinski
Photo © Allen Yao
I realise you're a classic man  Smile so maybe it's a little different to these 2-crew aircraft.
Cheers, Rob.
air2gxs
Tue Oct 28, 2003 2:38 pm
I can tell you on "modern" Boeings (57/67) that you just move the start switch to ground and supply air. As long as you ahve a good airsource, you'll get at least 20% N2, probably closer to 28%. Don't throw in the fuel and your dry motoring.
Watch starter duty cycle or you'll trash the starter. The actual time eludes me at the moment. It varies from engine to engine anyway.
Tue Oct 28, 2003 3:05 pm
The problem is that the "fire handle" kills all bleed air sources IN and OUT of the engine... so the starter does not get any air... and cannot rotate the engine...
In my opinion, the start valve should be left open to permit to motor engines, to blow excess fuel when the fire handle has been pulled for a tailpipe fire.
xxx
I wish design engineers had permitted that feature to be kept on start valves...
All pilots and instructors in aviation have that same opinion.
xxx
(s) Skipper
air2gxs
Tue Oct 28, 2003 4:22 pm
Skipper,
I just went through our hung/hot start checklist here and couldn't find any reference to pulling the fire handle. I'm not sure what our AOM says about it, but from the maintenance put of view the only time we pull a fire handle is when the bell is ringing. What airline or fleet type?
A/c train
Tue Oct 28, 2003 10:33 pm
Hey, 747skipper,
if you know what to do, then why dont you go and open the bloody Air valve !
Send the mechanic, for christs sake.
regs
a/c  Smile/happy/getting dizzy
707CMF
Tue Oct 28, 2003 11:22 pm
Got a Lycoming on my taildragger (DR221 - not mine, but still...). Winter is coming, and I can coming see the days when I'll need at least 15 minutes to start the engine.
Good engines, but as soon as temp is below 5 deg, they take a hell of a time to startup (and yes, Skipper, they do have L/R magnetos, and a manual fuel valve selector !  Wink/being sarcastic )
707
vc10
Wed Oct 29, 2003 12:19 am
Back in the 1960's a VC-10 aircraft in the wilds of Africa could not open it's start valve on one of it's four engines, so it off loaded it's Passengers and cabin Crew and took off on the other 3 engines. Once in flight it started it's offending engine using the in flight procedure, then landed again and took it's passengers on board and proceeded to it destination only slightly late.
Would not suggest anybody try it these days as companies are not the same now , and some modern day passengers would probably sue
Regards little vc10
cdfmxtech
Wed Oct 29, 2003 2:26 am
Uhh, which aircraft is that?? Ass-u-ming the 747 is the same as the 737,757,767,777, pulling the fire handle will not prevent air from going to the start valve.
Wed Oct 29, 2003 2:56 am
Friends -
xxx
Hot start procedure ("impending hot start") is just calling to shut the fuel, and continue motoring the engine down to an acceptable EGT... Probably explained it wrong here. Some hot starts (excess fuel, late ignition) have degenerated in a bad combustion stage/tail pipe fire in which the crew aborted the start and properly call for engine fire check list procedures...
xxx
Fdfmxtech is correct, you can still motor the engine with fire handle pulled, if I made the contrary statement, it was my mistake... Fire handle only shuts bleed air valves, air exiting the compressor stages...
xxx
(s) Skipper
air2gxs
Wed Oct 29, 2003 2:23 pm
Skipper,
Don't back off so quick. The fire handlw WILL close the pylon valve on a jumbo, thus isolating the engine from the aircraft pneumatic system.
Had a real interesting and exciting engine start once at JFK:
APU inop.
Ground air and electrics hooked up and starting #4.
Ground electrics trip off at about 35% N2 (light up has occured).
No electrics w/air on: pack valves open robbing air from engine.
Engine hangs and EGT climbs rapidily, almost dizzyingly (sp?).
Flight crew pulls handle and blows bottle, guess what?, no help.
We got lucky, established ground power and quick thinking engineer put in fire handle and re-engaged (crash) starter and motored until cool.
1 borescope, 2 fire bottles and a starter change later the aircraft departed.
Thu Oct 30, 2003 1:25 am
Air2gxs -
Correct on the 747 for the pylon valve...
We were discussing other airplanes as well, and in general, as mentioned by Cdfmxtech, other airplanes permit using the air starter despite fire handle...
xxx
I did not want to enter in a controversy here, but with my airline, if we have a tailpipe fire, we will motor the engine rather than pulling a fire handle. All we do is shut the fuel (as in "hot start") then continue motor the engine. Pulling the fire handle and use the pylon fire extinguishers would not do anything to the fire in the tailpipe... I think this airline had an incident 15 years ago, and they damaged an engine by fire following a "fire handle" being pulled for a tailpipe fire...
xxx
(s) Skipper
DLMHT
Fri Oct 31, 2003 9:56 am
I'll never forget the time I was doing an airstart on one of our MD-88s (standing about 15 feet from the number 1 engine) and we had a hotstart.
Bam-Bam-Bam-Bam-Bam!
Even over the noise of the jet-powered starter cart, the bangs in the engine were tremendously loud. I could only imagine how loud it was in the cabin around rows 37-38.
The crew ended up just motoring the engine to get the remaining fuel out of the bottom of the engine, and the flight left with no incident, except for the ringing in my ears!
DLMHT
N243NW
Fri Oct 31, 2003 11:22 am
I suppose this question is directed toward jet aircraft, but...
You haven't truly heard a backfire until you've heard one from a 2000 horsepower Pratt radial in a Corsair (at the 2003 OSH airshow). After one failed start, it backfired a few more times and taxied (noisily) away to the runway. Wow! Wow!
-N243NW Big grin
Users browsing this forum: Starlionblue, zombie and 1 guest
