Slcpilot
Mode A, B, C Transponder Questions..
Fri Oct 31, 2003 1:49 am
Somebody asked me the other day what Mode A, and Mode B were with respect to transponders. I always thought Mode was just the "code" while C included the encoded alitiude. What is mode B?
Also, with respect to VFR cruising altitudes in the U.S., why does 14 CFR 91.159 refer to VFR cruising altitudes at the flight levels? I thought all the traffic was IFR up there.
Thanks in advance !
SLCPilot
I don't like to be fueled by anger, I don't like to be fooled by lust...
MxCtrlr
RE: Mode A, B, C Transponder Questions..
Fri Oct 31, 2003 1:52 am
You are correct on the A and C but you forgot the new Mode S (which is transponder with Altitude Encoding and TCAS).
MxCtrlr  Smile/happy/getting dizzy
Freight Dogs Anonymous - O.O.T.S.K.  Smokin cool
DAMN! This SUCKS! I just had to go to the next higher age bracket in my profile! :-(
cdfmxtech
Fri Oct 31, 2003 2:17 am
Mode A = Identity
Mode C = Altitude
Mobe B was planned for, but never used, at least not in civial aviation.
avioniker
Fri Oct 31, 2003 2:26 am
Actually Mode S is so named because it Selectively interrogates other nearby aircraft transponders in coordination with TCAS to determine proximity and threat. It also transmits the registration or international identification code of the aircraft so it may be specifically identified for interrogation by other Mode S transponders in the area.
The name isn't accurate in that a Transponder responds to interrogation and an Interrogator initiates interrogation or communication (i.e. DME Interrogator vs. ATC Transponder) The name stays because the primary purpose is still to respond to ATC queries for control.
liamksa
Fri Oct 31, 2003 10:27 am
Here in OZ generally the max VFR altitude is FL200 due to VFR altimeter accuracies.
Rob.
Fri Oct 31, 2003 11:17 am
Hey SLC! I used to live in Utah County, and did most of my flying in Provo. I've flown to SLC numerous times, though. Did my 10 night tower landings for the Commercial on 17. Fun stuff.
Drop me a line, eh?
-Normal
Users browsing this forum: Aircellist, StereoTechque and 1 guest
