After JT8D-17R What
Wed Nov 19, 2003 9:45 pm
What was the future model of the JT8D after the -17R.
regds
HAWK
broke
RE: After JT8D-17R What
Wed Nov 19, 2003 10:35 pm
There is a JT8D-17AR which provides for an automatic thrust increase in case another engine on the airplane fails.
Also, there are the JT8D-200 series engines, which are used on the MD-80 series airplanes and some hushed 727's.
There is the JT8D-22 engine which is used on the SAAB Viggen Fighter. There is a considerable amount of redesign, especially in the area of materials in the compressor to make the engine usable in a combat airplane.
After that, there is nothing else as the newer generation of engines are more efficient.
Tue Nov 25, 2003 6:27 pm
Are these similiar in size & mountings to the JT8D-17R ie the -200 & 22.
regds
HAWK
broke
Tue Nov 25, 2003 10:16 pm
The -200 series engines have a larger diameter fan and so the engine's larger size would require different mounts.
The -22 is the same diameter the standard JT8D's, but comes with a Swedish developed afterburner. 26,500 lbs of thrust in full A/B is a real kick in the pants!!
