Aerobatics Or Gliders, Which Is Most Beneficial?
Sat Nov 22, 2003 5:40 am
Hey all,
For discussion: What would be the most beneficial for the general pilot population to make them more skilled as aviators; aerobatics training or glider training. And since I'm trying to stimulate thought, please give your reasons.
...talk amoungst yourselves.... discuss....
-Normal
ThirtyEcho
RE: Aerobatics Or Gliders, Which Is Most Beneficial?
Sat Nov 22, 2003 6:17 am
Almost any flight training that you do helps to make you a better pilot but, given the choice, I'd say that aerobatic training is a priority over sailplane training. The chance that you can get over on your back, enter a spin, get in an unusual attitude or have to perform some maneuver with precision means that aerobatics can save your life.
I've dabbled in some things that I didn't go on and get the rating for, like seaplanes, and found that I had learned something that applied to my "real world" flying every time.
If you don't have an Instrument Rating yet, get to work on that one first.
MITaero
Sat Nov 22, 2003 7:50 am
Aerobatics training *in a glider* would be ideal, wouldn't it?  Smile
PilotHighFlyer
Sat Nov 22, 2003 7:58 am
Aerobatics training !!
Anytime that you can get with aerobatics will be very beneficial, including upset training
That kinda training will make you a much safer more competent pilot.
~Robert
Sat Nov 22, 2003 8:06 am
Ok, so that's 2 for aerobatics, 1 one for glider... (I think.)
Hey, MIT, one of my best buddies goes to... uh, MIT. He's a grad student in Materials Science.
-Normal
SkyGuy11
Sat Nov 22, 2003 8:20 am
I just finished an aerobatics course... I probably learned more about flying in those hours than I have since my first presolo days.
It's amazing how damn precise you can really be... I had no idea you could even recover from a spin on heading before starting (don't laugh!)... during the course I learned that along with about a million other invaluable things.
Plus it was a hell of a lot of fun. I'd really love to teach the stuff one day!
Can't really count this vote towards aerobatics though... because I've never flown a glider though that's another goal!!
Sat Nov 22, 2003 8:45 am
Does it have to be "either/or"? I've taken aerobatics courses, I teach spin entry and recoveries to all my students, and I'm a glider CFI. In my opinion, each is a necessary suppliment, but not a legal requirement. The skill set that you learn in each activity could come in real handy out there in the cold cruel world.
Case in point, the pilot of the Air Canada B-767 "Gimli Glider" that dead-sticked on to a drag strip several years ago. He was an active glider pilot. In my case, I had a total power failure in a C-172 15 years ago and I credit the skills that I developed flying gliders in saving my butt that afternoon. Aerobatic training is no less important. Having the skill to instinctively know what to do when you get into wake turbulence could also be a real life saver.
Neither activity is very expensive. Both types of flying are extremely enjoyable. Most aerobatic courses that I've seen are billed out in 1/4 hour increments. (That's an indication as to how long most people can handle active aerobatic instruction. Believe me, 15 minutes is a lot of time to be flinging yourself around the sky when you're "green and sweaty".  Laugh out loud ) However it doesn't take very many short training sessions before you really start to enjoy it. As far as glider training goes, the add-on rating isn't all that expensive - if you're interested, check out this web site: http://www.ssa.org.
Jetguy
liamksa
Sat Nov 22, 2003 11:05 am
G'day Normal
I've done a fair bit of aerobatics training but no gliding so I can't make a proper case for either one, but I can definitely say that the aerobatics training I've done has been awesome! You hone your skills so much while just flying the plane, nothing in the back of the mind thinking about your next waypoint or radio call.
Photo © Jerome Zbinden
Photo © Matthew Millsom
For aeros I've flown the Decathlon and the Zlin and each has its place. Flying (or maybe landing/taxiing  Smile) a taildragger is great fun, and it requires much more accuracy than a tricycle setup. Not having any flaps (obviously can slip but there's a company SOP on the minimum height) highlighted the value of flying a proper approach, on slope and on speed, and how important that is in nailing that landing.
And once you're up in the air with a few hours of aeros you really get to know the plane and expect what's going to happen next. I buggered up a stall turn the day other day and could feel the plane about to spin and without thinking reacted. That there I reckon is the real value in doing aeros -> the instinctive reactions you develop. I found that I really started to understand the aircraft - I could feel what was going on. Although i've never had to apply it in normal cross-country flight i'm confident that if (when) i come across that situation i'll react quickly and effectively.
Anyway, a bit of a ramble, but from me a HUGE thumbs up for aeros, although I'm definitely planning on gliding training in the future. Ideally i'd say do both.
That's enough  Big grin
Rob.
Mon Nov 24, 2003 3:45 pm
What I would personally recommend is to get glider training first in learning to fly, through PVT level, or at least through your first solo, then start learning to fly powered airplanes.
xxx
As far as aerobatics, maybe some 10 to 20 hours of training, when you near the end of your training for the CPL. Some countries require aerobatics as part of the CPL curriculum.
xxx
Happy contrails  Smile
(s) Skipper
L-188
Mon Nov 24, 2003 6:37 pm
I haven't done either, but I have been told by someone that did glider training, that he really thought it taught him a hell of a lot more about how the wind works.
KAUSpilot
Mon Nov 24, 2003 6:41 pm
I'd go for the glider training. I don't see any urgent need to learn aerobatics in civil aircraft, other than basic spin training. Gliders seem like more fun, plus there's another rating you can add to your license.
goboeing
Tue Nov 25, 2003 3:46 am
I think both are very beneficial. I've done more aerobatics training than gliding, but I can see the advantages to each.
I've flown a "real" glider once, at Van Sant airport. That was before I started PPL lessons. After the private license, I did about 6 hours of flying in a Grob-109 motorglider. We had to keep the engine on for some of the flights because of the cold, but I did experience some of the glider things people talk about.
Photo © Simon Thomas
Photo © Délitroz Dimitri
Photo © Mikko Maliniemi
Photo © Ben Wang
I also flew about 15 hours worth of aerobatics training in the Avions Mudry Cap-10. I think that if I'm ever in a situation where I'm in an "unusual" attitude, I'll be able to quickly react and get out of it without damaging the aircraft or panicing until it's too late. Unusual attitude training makes any attitude "usual." After loops, snap rolls, hammerheads, knife edge turns, and inverted flat spins, stalls don't seem scary any more.
One of the Caps I flew actually still had the French Connection paint job on it; it was obtained from that aerobatic team after they had an accident.
Photo © Paulo Rudolf Herren
Photo © Don Boyd
Photo © Paul Chandler
Photo © Aeroview Zurich/Worldwide
Photo © Den Pascoe
Photo © Colin K. Work
Photo © Andreas Beuermann
I think you should do both; they're equally beneficial.
Nick
pilotpip
Tue Nov 25, 2003 4:37 am
Both have very beneficial qualities and both will make you a better pilot. I've done both and can say that I'd prefer to do more soaring. Maybe it's because I had an instructor who had more time in sailplanes than powered aircraft, maybe it's because I'm one of those guys mentioned earlier who made it 20 minutes before blowing chunks.  Smile
Almost any rating or sign off will help you in your career. The instructor I had would always show me cloud formations that were turbulent. In a glider, you want that, in an airliner, you want to avoid them. He was also from the mountains and being in the midwest some of the weather phenomina we discussed never happens here. That will come in handy some day when I'm in a region that isn't just corn fields.
All that being said, I'll add one more to the mix. I think that everybody should get a tailwheel endorsement. My landings have gotten MUCH better since then. Tricycle gear is much more forgiving. If you mess up a crosswind landing in a taildragger you are more than likely going to ground loop. They also only take a couple hours in an aircraft that won't be much more expensive than what you fly now. No check rides or special forms to fill out, just a signoff in your log book and a whole new world of aircraft is opened up to you.
DMI
SkyGuy11
Wed Nov 26, 2003 7:21 am
Woah those pictures are awesome!
schreiner
Sun Nov 30, 2003 2:45 am
Aerobatics in a glider helped me very much in get more "feeling" in flying. Aerobic a/c have engines, so that would be a +.
I´ll choose gliding, just because you heve more feeling and because I love it!  Smile
Schreiner
Soaring the internet...
wingscrubber
Mon Dec 08, 2003 10:12 pm
6 years ago in while on AEG (air experience gliding) with the air training corps I was taken up in a Viking glider, I was 13 at the time. I was whinch launched(thats scary enough, 0-60mph in about 3 seconds), and was then subjected to loops and neg-G maneouvres at the hands of my instructor (sat behind me). As an aviation experience, combining both unpowered flight and aerobatics was truly memorable, I loved it Big grin
Pete
Resident TechOps Troll
PPGMD
Tue Dec 09, 2003 6:30 am
Well lets see if my old password works.
I say do both. And do aerobatics in gliders if you can too (much more graceful aerobatics compared to the traditional sport acro in power aircraft). Now you can do 2-3 times more soaring for the same price as Acro.
Now do get you in the mood for both:
http://movies.lazyeights.net/sailbatics.wmv
At worst, you screw up and die.
Tue Dec 09, 2003 7:19 am
That movie was sweet.
-Normal
Tue Dec 09, 2003 7:31 am
PPGMD...
Thank you for posting that website! That, my friends, captures it all.
Jetguy
SkyGuy11
Tue Dec 09, 2003 9:45 am
Yikes!!!! I hope that thing has a negative G fuel system!
Oh... wait
Seriously, that looks like it has got to be some of the MOST FUN flying you could POSSIBLY do!  Smile
Users browsing this forum: zaphod42 and 1 guest
