Mr Spaceman
Reverse Thrust Limit During An RTO?
Thu Dec 11, 2003 3:37 am
Hi guys.
A few months ago in this forum it was explained that on a certain type of airliner (I can't remember which type  Laugh out loud), the thrust reversers (TR's) are automatically stowed after landing once the airliner has slowed down to 100 knots to help prevent any engine damage (FOD) from being caused by the reverser's air blowing up any debris from the runway which could be injested into the engine's intake.
My question is ........
During a rejected takeoff (RTO), if the pilots really need to use "full reverse thrust" and braking to prevent themselves from overshooting the end of the runway, can the 100 knot TR limit be manually or automatically removed?
I believe that the last thing pilots would be worried about during an RTO while trying not to run off the end of a runway and into approach lights, trees, etc, is engine FOD.
Photo © Paul Harvey
Photo © Charles Falk
Photo © Tim Samples
Chris  Smile
musang
RE: Reverse Thrust Limit During An RTO?
Thu Dec 11, 2003 4:08 am
Agreed, Spaceman. FOD would become second priority, to stopping it at all costs.
If I remember correctly, the 737 idle reverse is just that, Normal Reverse is 75% thrust, Max Reverse is 85%. Since it ejects at a 45 degree angle approximately, the actual stopping effort is nothing like the acceleration at the same levels of forward thrust.
The common misconception that reverse thrust is brutally effective is due to the fact that if a pilot IS using a lot of reverse, he's SIMULTANEOUSLY pounding the brakes (or the Auto-brake system is). Its actually the wheelbrakes which fling you forward in your seat, the deceleration from reverse is comparatively gentle.
But in the context of your original question - every little bit helps.
Regards - Musang
Mr Spaceman
Thu Dec 11, 2003 4:41 am
Hello Musang.
Thank You for your reply and for the numbers regarding the different reverse thrust settings on a B737.
Unfortunately I can't remember what type of airliner was being discussed when it was explained that at 100 knots or less during landing rollout the reversers automatically retract. It was that aircraft (or any others with this TR safeguard system against FOD) that I was curious about with regards to whether or not the pilots could overide the TR's 100 knot restriction system.
I'm sure that if a flight crew's jet was still rolling forward when only 50 feet from the end of a runway after an RTO or problem during landing, they would want every little bit of help they could get. Even if it was to just prevent the nose gear tires from sinking into the grass off the end.
I understand that some jet airliners can use reverse thrust when moving slower than 100 or so knots. All I have to do is think of MD-80's (I believe) pushing themselves out of a gate with reverse thrust.
I agree with you that many people don't understand that it's not the ground spoilers or TR's that bring an airliner to a stop (although they help), it's the aplications of the brakes.
Question .....
On landing rollout, does the Boeing 737 have a TR speed restriction to prevent FOD?
Chris  Smile
sovietjet
Thu Dec 11, 2003 5:04 am
Probably none of the tail-mounted engines have that because there is almost no chance of FOD period.
Mr Spaceman
Thu Dec 11, 2003 5:41 am
Hello Sovietjet.
That's a very good point. I never thought of that.  Laugh out loud I guess I can rule out those types of jets with regards to having a TR speed limit during rollout.
Has anyone ever seen a jet with wing mounted engines push itself backwards out of gate? Probably not.
You can see in these 2 photos which aircraft type's mechanics need to be more worried about FOD.
Photo © Eduard Brantjes
Photo © Andreas Müller
By the looks of these photos, if any type of airliner's mechanics should be worried about FOD while the thrust reversers are working, it's the 737. Their engines are very close to the ground. Meanwhile, they probably don't have a speed limit for TR use!
Photo © DIGITALEX Wiecka
Photo © Islam Chen
Chris  Smile
Okie
Thu Dec 11, 2003 7:51 am
I can not imagine T/R closing when decelerating through 100 knots automatically while engines are spooled up.
Even stowing the buckets before the turbines spool down causes unexpected acceleration. Trust Me.
Mr Spaceman
Thu Dec 11, 2003 9:21 am
Hello Okie.
Thanks for your reply.
I appreciate your comments. What you are saying about the unexpected acceleration even makes sense to me.
Would this acceleration still occur if the reversers were not buckets/clamshells? Would this happen with every type of TR?
I think the aircraft involved was something like a 767 or 777 ...... maybe!
I will tell you this however, I will find the thread (even if it takes me a week) where it was explained that on a certain airliner the TR's stow automatically after 100 kts. That way you (and everyone else) won't think I'm imagining things. Perhaps I was (we were) taught something incorrect.
I do trust you! Big grin
Chris  Smile
sxmarbury33
Thu Dec 11, 2003 9:39 am
No regular comercial airliner that i know of has an auto shutoff type device on the TR's. It is SOP for a lot of airlines though to have them at idle reverse at aound 70 and stowed at 60. This is totally up to the discretion of the pilot however. There was a copule pics of i think the little rock AA MD80 with the buckets still deployed. It might have been another A/C though.
AJ
Thu Dec 11, 2003 10:47 am
Mr Spaceman, I can assure you the 767 doesn't 'autostow' at 100kts. If we needed it we would use reverse thrust until stationary to prevent injury to passengers and crew.
Full reverse is much more effective at high speed, the effect reducing as the aircraft decelerates.
Okie
Thu Dec 11, 2003 1:00 pm
Mr Spaceman
Maybe you are thinking of a Speedbrake automatically stowing on some particular aircraft? Tail type as on an F-100 or ARJ, just a thought.
Mr Spaceman
Fri Dec 12, 2003 7:47 am
Hi guys.
Thank You very much for getting back to me on this subject.
You guys have made it very clear that there are no Auto Shutoff or Autostow devices for any commercial airliners's TR's. Thanks for drilling this into my head. I still have not been able to find the thread were this was mentioned (I'm not insane), but I will.
I'm not perfect, perhaps my memory has betrayed me. Although I dought it. I'm a very smart guy and I have a great memory. I hope you guys have been enjoying teaching me and everone else about what makes these gorgeous machines tick. I Thank You.  Big thumbs up
> Sxmarbury33, you stated .......
It is SOP for a lot of airlines though to have them at idle reverse at around 70 and stowed at 60.
I understand that it's the pilot's decision and that it's not automatic. However, It does sound like the TR's are stowed at 60 to prevent FOD. Is this the case?
> AJ, I'm sure you would do anything you had to sir.
> Okie, Thanks for the thought, but this question does not have anything to do with speedbrakes.
Chris  Smile
JBirdAV8r
Fri Dec 12, 2003 12:43 pm
Chris,
I seem to recall that certain models of the 747 have leading-edge slats that retract at least partially upon reverser activation to prevent FOD...maybe this is what you're thinking of?
411A
Fri Dec 12, 2003 2:13 pm
Indeed, the 'ole B707 had complete leading edge device auto-stow upon selection of engine reverse thrust...to prevent slush from being driven up/under the leading edge kruger flaps...and when reverse was de-selected, leading edge devices deployed once again.
An old design which worked good.
Users browsing this forum: gcb5196 and 1 guest
