modesto2
LAX Ramp Control
Thu Dec 11, 2003 5:42 pm
Can someone please explain ramp control ops at LAX? Where are these controllers located? Do aircraft parked at the end of the terminal still contact ramp for push or do they contact ground instead? Do ramp and ground communicate? Finally, does anyone know ramp frequencies for AA, DL and/or UA? Thanks.
avioniker
RE: LAX Ramp Control
Thu Dec 11, 2003 10:39 pm
All the answers you could ever want in one simple website:
http://avn.faa.gov/ap_diagrams.asp?search=lax&stateSearch=&select=&submit1=Search
And should you get the answers to your questions please let the rest of us trying to move stuff around LAX what they are. (Not to say there's a lack of consistency in operations...)
AAR90
Fri Dec 12, 2003 3:13 am
DL has a small control tower over their terminal. I believe that is where their ramp controllers work. AA ramp control is a room overlooking the C-10 alley. Not sure about others.
LAX Ground Control if you're going to move anywhere on the taxiways. AA specifically lists the gates that need to call LAX, DL or AA before pushing.
Not really. If LAX controllers have the time they usually keep an eye on what gates are open in areas that have their own ramp control, but often they'll just give you initial taxi instructions to clear their runway exits and to call them back when you (aircraft) find out your gate's status.
Jepp. page 10-9B has ramp freqs listed, but I don't have my pubs with me at the moment.
aaway
Mon Dec 15, 2003 10:06 am
AA Ramp Tower - 129.45
UA Ramp Tower - 129.4 (C6 alleyway)
UA Ramp Tower - 129.5 (C7 alleyway)
DL Ramp Tower - 131.45
Also Alaska has a ramp tower operation for the D10 alleyway (TBIT gates 119-122 and west side of Terminal 3). Don't recall the freq., but will post when I have the info.
"The greatest mistake you can make in life is to continually be afraid you will make one." - Elbert Hubbard
aaway
Mon Dec 15, 2003 4:35 pm
Correction!!! Frequency 129.22 for the AA ramp tower.
aaway
Tue Dec 16, 2003 8:06 am
Final corrections!!!
AA ramp tower - 129.32
Frequency for AS ramp tower is 130.85
Hope this helps!!!
[Edited 2003-12-16 00:08:45]
Users browsing this forum: laser8 and 1 guest
