zona8
What Is An APU?
Thu Dec 25, 2003 11:13 am
I am sorry if this is a stupid question, but I keep hearing the term APU, what does it mean and what does it do? Thanks for the help and Happy Holidays!
akjetBlue
RE: What Is An APU?
Thu Dec 25, 2003 11:16 am
Auxiliary Power Unit: Internal engine on aircraft that provides pneumatic air for engine start, a/c, hydraulics, and power while the engines are off. Am I missing anything?
Save a horse! Ride a Cowboy!
Q330
RE: What Is An APU?
Thu Dec 25, 2003 11:17 am
An APU is an Auxiliary Power Unit. It is used to provide power to a plane's systems when the engines are not running. APUs are located in the tail cone of most airliners.
-Q
Long live the A330!
raven111
RE: What Is An APU?
APU stands for Auxilary Power Unit.
The APU runs everything on an aircraft while the main engines are off.
"The secret to my success is that I always managed to live to fly another day." Chuck Yeager
jmc1975
RE: What Is An APU?
Thu Dec 25, 2003 11:18 am
Auxiliary Power Unit - it uses fuel to produce electricity for the aircraft without the need of using the engines.
Q330
RE: What Is An APU?
Thu Dec 25, 2003 11:19 am
only on a.net can you get three replies within seconds of posting a topic! Big grin
-Q
Long live the A330!
A330Jamaica
RE: What Is An APU?
Thu Dec 25, 2003 11:39 am
As was said, an APU is an auxiliary power unit used to supply power when the main engines are down. It is really a smaller version of the main turbine engines that turn alternating current electric generators instead of a fan or propeller. There has been research into using other energy converting devices like fuel cells but for now they remain small turbine engines. If you are ever at an open airport i.e one where you are within reasonable proximity outside to a large commercial airliner, the APU is what makes that hissing sound when it is clear that the main engines are off.
FLAIRPORT
RE: What Is An APU?
Thu Dec 25, 2003 12:00 pm
evenin jetways, you hear the hissing sounds (some airports are better than others in reducing... at ATL, the terminal is virtually soundproff except when there are arrving planes, but FLL is much less and you clearly hear the AP in the terminal! i=I lovehat sound!
NEXT FLIGHT: FLL-ATL-HPN on FL
flpuck6
RE: What Is An APU?
Thu Dec 25, 2003 12:06 pm
NOT good when the APU is not functioning ... the need for an air start (external machine to push air into the engines) can be potentially annoying, since the air start machines never work when you need them to LOL.
Bonjour Chef!
AJ
RE: What Is An APU?
Thu Dec 25, 2003 12:08 pm
The hissing sound is often the result of the air conditioning packs running. As they are mounted in the belly of many jet airliners the noise attenuates on the nearby ground exaggerating the noise.
modesto2
RE: What Is An APU?
Fri Dec 26, 2003 12:45 am
Similarly, a ground power unit (GPU) can be connected to the aircraft to serve the same purpose of the APU. Keep in mind that the APU is usually deactivated after engine start.
OPNLguy
RE: What Is An APU?
Fri Dec 26, 2003 1:05 am
Another thing to keep in mind, in addition to whatthe others have mentioned, is that the APU can be used in-flight on most aircraft (the 727 being an exception). With so many of the world's airliners being twins, the APU provides a third generator for redundancy.
The APU is usually located in the tail of the aircraft. In the picture below, you can see the air inlet to the left of the aft service door.
Photo © Marlo Plate - IBERIAN SPOTTERS
The APU exhaust is right at the end of the aircraft, as seen here:
Photo © Islam Chen
For a detailed description of what's what, see:
http://www.b737.org.uk/apu.htm
Happy holidays....!
pilotpip
RE: What Is An APU?
Fri Dec 26, 2003 3:18 am
In addition to electrical power, they also provide pneumatic power for start and can be a suppliment/backup in some aircraft for both systems in flight. The 727 is the only exception becuase the apu is in the wheelwell instead of the tail like other aircraft. They are pretty small too. The APU on the ERJ-145 is comparable in size to a couple large bags of potato chips. Most are made by Allied-Signal.
You can tell that an APU is running on an aircraft when you hear a small jet engine running, that is what it is. It may be harder to hear from the left side because most of the aircraft out there position the business end on the right side of the aircraft, or at the tail.
DMI
CanadianNorth
RE: What Is An APU?
Fri Dec 26, 2003 8:37 am
APU: Auxiliary Power Unit.
It provides power to the aircraft when the engines are shut off, and can provide the power to start the engines. On some aircraft, it also doubles as backup power incase of engine failure. On most aircraft the exaust outlets under the tail are easy to notice; and i believe Boeing's 727 was the first jetliner to feature an APU, but i may be rong.
CanadianNorth
HS-748, just like a 747 but better!
RayChuang
RE: What Is An APU?
Fri Dec 26, 2003 1:51 pm
It should be noted that APU's are essentially miniature jet engines that provide power to an airliner when the jet engines are shut down (this allows APU's to use the same fuel supply as the main jet engines). Frequently, when the aircraft is seriously delayed on ground hold, the flight crew switches the airplane to be powered by APU power instead of power from the running main jet engines.
L-188
RE: What Is An APU?
Fri Dec 26, 2003 2:26 pm
Not all APU's are turbines, although they pretty much universally are today.
The B-17 used a Briggs and Stratton Lawnmower engine driving a generator for an APU. The B-29 has a bigger two cylinder jobber, I think the motor powering that was a McCullah (spl? My chainsaw is made by these guys)
Those APU's could only supply electrical power. The turbine ones today supply both electrical power but bleed air, which is used by the air conditioning packs and the start motors on the engines.
DC-10Tech
RE: What Is An APU?
Fri Dec 26, 2003 7:20 pm
Please, could we possibly get one more know-it-all to chime in with 'APU=Auxilliary Power Unit'.
I'm not sure if I fully understand what it is yet.
Thanks.
Forums.AMTCentral.com
wietse
RE: What Is An APU?
Fri Dec 26, 2003 8:11 pm
There, got it know DC-10Tech?  Wink/being sarcastic
Wietse
Wietse de Graaf
B727-200
RE: What Is An APU?
Fri Dec 26, 2003 8:19 pm
OK DC-10Tech, an APU is an Auxilliary Power Unit. Anything is possible  Big thumbs up
I believe British Aerospace uses four of these under the wings of the BAe146 range of commercial jetliners, although some would say they are actually lawnmower engines as used on the B-17 (re: L-188 above).
Seriously, quite an important piece of equipment. Here in Australia for instance, there are some airports in the "Outback" that do not have ground power, and have very few flights per day (some only one flight per day). As these remote areas are often very hot, airlines could not afford to send an aircraft with a non-functioning APU (air conditioning requirements on the ground). This can make scheduling quite interesting.
Some of the stats of the APU are phenomenal. I am sure someone can correct me with exact figures here, but some can generate enough electricity to run a small town, and spin at about 40,000 RPM.
FredT
RE: What Is An APU?
Fri Dec 26, 2003 10:27 pm
AJ,
the packs need pressurised air to function. From a ground source, engines (making the packs hard to hear) or the APU.
Many (most?) APUs have an altitude restriction making them unavailable in cruise.
BTW, DC10-Tech, it's Auxiliary Power Unit.  Big grin
It'll have to be a very small town if you are to run it off an APU!
Fred
OPNLguy
RE: What Is An APU?
Sat Dec 27, 2003 12:54 am
Just to clarify, some do have altitude limits, but the APU -is- available if you're cruising -below- that limiting altitude.
Cheers...
SlamClick
RE: What Is An APU?
Sat Dec 27, 2003 1:24 am
re: The B-727. That APU was an afterthought. The -100 came out without one. As small cities were obviously going to be a huge market for the 727 the APU was a smart alternative to having each little airport have to buy ground power units. It was added into the main gear well, forward of the wheels and the pneumatic air was originally plumbed through part of the wing anti-ice ducting. On the -200 it got its own piping.
The 727 APU is usable only on the ground. The exhaust discharges over the top of the right wing root and "torching" during start has caused more than one passenger-initiated evacuation.
airplay
RE: What Is An APU?
Sat Dec 27, 2003 1:55 am
Apu runs the "Quicky Mart" in Springfield. Although I'm sure he is quite important, the town can do without him for days at a time....
AJ
RE: What Is An APU?
Sat Dec 27, 2003 7:34 pm
Thanks FredT, I'm very familiar with the air conditioning packs. My point was the noise heard by passengers boarding via an aerobridge is the packs operating, turn the packs off and the APU is audible, but not nearly as noisy.
modesto2
RE: What Is An APU?
Sun Dec 28, 2003 2:20 am
One can also determine if the APU is running by looking at the tail cones of most aircraft. If it's running, one can see the exhaust distort your vision.
A/c train
RE: What Is An APU?
Sun Dec 28, 2003 7:34 am
I dont believe its taken 24 replys to answer waht an APU is.
Airplay got it right anyways ! this is the saught of topic that was looking for flowering though !! Everyone knows better !
regards.
a/c
bio15
RE: What Is An APU?
Mon Jan 05, 2004 8:27 am
Though a bit late I thought I might add a note: 747-400 APU's are capable of providing enough air to start two engines at the same time. That is a pretty powerful APU.
-Alfredo
brons2
RE: What Is An APU?
Tue Mar 23, 2004 6:14 am
This post made me laugh.
Firings, if well done, are good for employee morale.
fritzi
RE: What Is An APU?
Tue Mar 23, 2004 6:58 am
If I recall correctly, the VC-25s (US presidential 747-200) are fitted with 2 APU's, in case anybody wants to know.
crjdispatchkid
RE: What Is An APU?
Tue Mar 23, 2004 7:10 am
Let's not forget how warm an APU can keep you on those cold winter nights when you are working the ramp. I sure don't miss those days.
Thanks...C-Ya...Bye
NoUFO
RE: What Is An APU?
Tue Mar 23, 2004 8:49 pm
To add my 2 Cent (Euro): Here's an article on APUs:
http://flug-revue.rotor.com/FRHeft/FRHeft04/FRH0404/FR0404d.htm
I support the right to arm bears
VC-10
RE: What Is An APU?
Mon Mar 29, 2004 2:04 am
During the night the Philippeno's in Saudia used to like lieing on the ground bathed in L1011 APU exhaust - until one got run over.
747srule
What's An APU
Mon Mar 29, 2004 12:30 pm
What's the diff between a 747 and an A340? An A340 has 5 APU's!
Jesus is the way,the truth,and the life
RE: What Is An APU?
Mon Mar 29, 2004 5:05 pm
I think you mean an Avro100/BAe-146 has 5 APUs... Big grin
