lamyl_hhlco
Noise After Push Back
Sat Jan 03, 2004 11:02 am
What is this weird lousy noise that we hear after a push back?
air2gxs
RE: Noise After Push Back
Sat Jan 03, 2004 11:34 pm
Well, that's specific.
Can be engine start.
Can be power transfer.
Can be the tow bar being disconnected.
Can be the flaps being extended.
Can be the flight controls being tested.
SlamClick
Sun Jan 04, 2004 1:15 am
Would help you get an answer if you told us what kind of airplane.
Barking dogs on an A-320 possibly?
757lgw
Sun Jan 04, 2004 4:39 am
while were on the topic whats the grinding noise after pushback on the A32s. Is that what your on about lamy?.
Okie
Sun Jan 04, 2004 6:30 am
Probably moaning "after push back" emitting from the loo if it was a 57.
Sorry could not resist after reading the post on the Civial Aviation side.
Lots of noises to be heard before during and after pushback depending on aircraft and starting procedures at that particular airport and particular operator. We need more clues
Aux Hydraulic Pumps
Air Starter
Wing devices
lamyl_hhlco
Sun Jan 04, 2004 1:40 pm
yeah specifically on a A320...right after push back there is a loud noise like when you screw something with a machine, it's abviously not the Flaps or any mecanical noise that i easy recognize... I never heared this noise on a 737 though just the A320.
tsufang@CI
Sun Jan 04, 2004 3:50 pm
to slamclick
xxxxxxxxxx
that's strange sound comes from ptu when elec hyd pump on
every time when i towing with aircraft ,and i turn on the elec pump
the dog barking comes from the floor
L-188
Sun Jan 04, 2004 4:05 pm
The sound of the tug jackknifing into the side of the airplane  Acting devilish
lamyl_hhlco
Sun Jan 04, 2004 5:32 pm
na i don't think it's the dog barking sound..it's something else ,right after PB and engines starting up then the guys on the ground do something or disconnecting something and it makes like an electric screwdriver noise but very loud...mmm wonder what it is??
L-188
Sun Jan 04, 2004 5:39 pm
Turning the nosegear steering back on?
Some aircraft have a NLG pin.
Some have a pump for it that is operated from the cockpit.
Sun Jan 04, 2004 5:44 pm
Probably The Flap drive pump/motor,used to extend the LEDs.At times the Flaps & Slats are extended to position 1 after engine start up for Visual confirmation that they are extended from Ground staff, prior to Taxi out.[In addition to the Indication lts].
regds
regds
HAWK
MD11Engineer
Mon Jan 05, 2004 1:30 am
On a 737 the standby pump makesa loud rasping noise.
Jan
Sabenaboy
Mon Jan 05, 2004 6:14 am
lamyl_hhlco
Mon Jan 05, 2004 12:42 pm
That must be it ,the PTU
Users browsing this forum: joelliot, planecane and 2 guests
