flyabr
Landing Gear ...
Mon Jan 26, 2004 3:23 pm
hey folks,
this might be a stupid question...but i'll ask it anyway. i've always wondered why the A320 aircraft family have "TALLER" landing gear vs the B737 family?
in other words, the airbus fuselage is quite a bit higher off the ground vs the boeing. any good reasons for this ... ? thanks.
futureualpilot
RE: Landing Gear ...
Mon Jan 26, 2004 3:30 pm
Ground clearence, the A318/319/320/321 doesnt have that unique nacell the 737 has, thus they need a taller gear for ground clearence.
Life is better when you surf.
flyabr
Mon Jan 26, 2004 3:33 pm
yeah but the original pratt engines didn't have odd shaped nacelle's, did they?
JBirdAV8r
Mon Jan 26, 2004 8:50 pm
Also I believe the A320 series was designed from the start as being stretch-friendly; the 737 was not. You can see the 737NG's have a taller gear than the rest.
aloges
Tue Jan 27, 2004 6:53 am
"yeah but the original pratt engines didn't have odd shaped nacelle's, did they?"
Correct, they didn't. But bear in mind that their diameter was much smaller than the one of a CFM56 engine.
SlamClick
Tue Jan 27, 2004 11:43 am
I think I remember reading when the 737-300 was introduced that the engine had only 7/8 of an inch less ground clearance than the JT-8D on the 100/200.
I've always thought the short gear on the 737 was a limiter on the design. It is possible on the -400 to strike the aft fuselage on the ground without hitting the tail skid.
I'm also pretty sure that the -900 sits higher. Whether it is redesigned gear or what I do not know, it is just a perception I got at the rollout at Renton.
bio15
Wed Jan 28, 2004 1:04 am
All the NG's have the re-designed taller main landing gear assembly.
-Alfredo
SlamClick
Wed Jan 28, 2004 2:01 am
Thanks Alfredo. I sure thought it looked that way. I was able to walk under it which is not something I ever did on a 300/400.
bio15
Wed Jan 28, 2004 9:09 am
Hi Slamclick. Did you get the chance to fly a delivery flight?
The taller main gear assembly is hard to notice just by watching pictures. Walking under the wing seems to be the best way to notice this. Neat that you had the chance to be at Renton  Smile
-Alfredo
