Static Vents,how Are They Cleaned
Mon Feb 02, 2004 5:08 pm
What is the procedure for cleaning Static vents [flush mounted] on an Aircraft.
regds
HAWK
air2gxs
RE: Static Vents,how Are They Cleaned
Mon Feb 02, 2004 10:44 pm
You flush a static system with air. The basic procedure is to disconnect all instruments, cap all fittings, supply air (15 psi max per B757 AMM), and remoce and cap fittins 1 at a time in order to completely flush debris/moisture from the system.
If for some reason you need to clean the outside, just wipe it down. use no abrasives or solvents that may cause any distortation of the port or surrounding area.
Users browsing this forum: AST1Driver, ATA L1011, zanl188 and 1 guest
