toxicmegacolon
What Would Happen If you opened a door in flight
Mon Mar 01, 2004 6:22 am
So sitting near an exit row on a widebody plane always makes me nervous....what would happen if some idiot just walked up to the door and pulled the handle to open it in midflight? Does anyone know what safety precautions are in place, or what conditions need to be satisfied so that the handle can be pulled and the door opened? Thanks!
Mon Mar 01, 2004 6:29 am
Nothing would happen. Those exits are "plug" type and the cabin pressure would make it impossible for the exit to open. In other words, the actual emergency exit door is slightly larger than the frame it rests in - hence, the term "plug". The cabin has to be depressurized in order for the exit to be opened.
Jetguy
ba757
Mon Mar 01, 2004 6:32 am
My understanding (from what I've read in the past) is you can't. The door wouldn't open because they are 'plug' doors. It basically works by the high pressure in the cabin pushing the door into the fitting - doors are apparently a little larger than the hole - no man would be ever be able to open a door with that pressure on it.
Someone will probably explain it better.
Adam
ba757
Mon Mar 01, 2004 6:33 am
Jetguy beat me too it!
Adam
Leskova
Mon Mar 01, 2004 6:43 am
Ok, I knew about the plug-design - but how does it work with the exists on the 737NG?
Photo © Gregg Stansbery
As you can see in this picture, they open outward - is there a mechanism in there that they also work like plugs?
Frank
Smile - it confuses people!
airplay
Mon Mar 01, 2004 6:52 am
Although it is true not all designs use "plug" doors for emergency exits or passenger doors for that matter, it is still quite improbable that someone will open one.
Current designs use safety interlocks such as pressure and speed locks. Pressure locks are pneumatic devices that apply a latch to the handle when the aircraft pressurizes. Many designs require no electrical power to operate.
Speed locks apply secondary locks when the aircraft reaches a certain speed (usually 80 or 90 knots). The speed locks are usually electrical solenoids that require aircraft electrical power to operate.
I'm not sure what to make of the picture. I'm not familiar with the 737-800 but I find it hard to believe they went away from the "plug" emer hatch.
Mon Mar 01, 2004 7:05 am
My explaination of Leskova's picture? Perhaps they are laterally firing passenger ejection seats.  Innocent
msllsmith
Mon Mar 01, 2004 9:06 am
Good one Jetguy! Obviously you're not that tired!
There's nothing more beautiful than flying into the dawn.
TheGov
Mon Mar 01, 2004 11:59 am
Someone correct me if I am wrong, but during the Saudia TriStar fire of about 20 years ago, the report on the accident stated that to some degree because the cabin pressure was not released, the doors could not be opened as soon as needed and that led to the death of everyone on board. I think most of the blame rested with the pilots because the did not realise how serious the situation really was to take the necessary actions to save everyone.
Always a pallbearer, never a corpse.
trekster
Mon Mar 01, 2004 12:27 pm
That is true, but also the captain did not turn the engines off,he kept them on meaning the cabin crew could not openthe doors and safley get the chutes down.
He even taxied normally for a while after landing.
Where does the time go???
Mon Mar 01, 2004 5:45 pm
The 737NG has a hinged overwing exit, so obviously it is not the plug type. But I feel confident there is some other safety feature.
pilotpip
Tue Mar 02, 2004 4:59 pm
I just watched a video on that Saudia fire. The opinion of this video was that the crew was incapable of handling the situation. A total CRM failure (Maybe this should come up in the other thread Smile ) The captain, while singing becuase he basically shut down due to stress, made a long landing roll out. By the time the fire trucks go to the aircraft, the aircraft was engulfed and the crew was not responding to ATC.
Does the L10 have a system similiar to the 737 incorporating locks? I don't know if many people would have lived if they jumped out while the aircraft was moving at 75kts. Of course, had the crew not been total morons we probably wouldn't be talking about this.
DMI
Tiger119
Tue Mar 02, 2004 7:41 pm
Pilotpip,
Did you see the video on a television show? If so, what was the name? Thanks
Flying is the second greatest thrill known to mankind, landing is the first!
Bruce
Fri Mar 05, 2004 5:49 am
I read in another thread some time ago that with the amount of pressure exerted on a plug type exit when cabin is pressurized you would need to exert a force on the door of over 10,000 lbs or so in order to open it.
Suffice to say that no human will ever be opening a plug type door inflight.
VC-10
RE: What Would Happen If You Opened A Door In Flight
Fri Mar 05, 2004 6:04 am
Please use the search function, this has been asked many times
Users browsing this forum: Horstroad and 1 guest
