GulfstreamGuy
Yaw Damper... What Exactly Is It?
Sun Mar 07, 2004 8:03 pm
Saturday, our NW flt 5807 (CRJ) LIT-DTW was canceled because a "yaw damper would not engage", thus the plane had to be ferried to MEM for maintenance. I am a little fuzzy on the understanding of what it exactly does.
Any help?
GulfstreamGuy
"If we couldn't laugh, we would all go insane. " -Jimmy Buffett
RE: Yaw Damper... What Exactly Is It?
Sun Mar 07, 2004 8:24 pm
Yaw damper is a gyro system which acts on the rudder(s), this for aircraft stability.
xxx
Have you ever heard about Dutch roll ??? (nothing against our friends from NL !)
Some (swept wing) airplanes are unstable on the yaw axis.
This because if they yaw to the left, the RH (swept) wing will present itself as a straight wing.
Straight wings create more lift, and more drag...
More lift = that RH wing will go up - More drag = RH wing is pulled aft (around yaw axis)...
Result, now, the RH wing being further aft, the LH wing will do that game...
LH wing will get more lift, more drag... result is the aircraft will yaw L and R.
Result could be a loss of control = Dutch roll.
xxx
So the yaw damper prevents Dutch roll.
Generally, the yaw damper is the "3rd axis" of the autopilot.
Modern airplanes generally have a full time "series" yaw damper, engaged at all times.
Some airplanes being unstable, their yaw damper is a "NO GO item" on the MEL.
Some other airplanes may be limited in speed and altitude if yaw damper is INOP.
The 747s have 2 yaw dampers... But the airplane flies perfectly without them. Not a NO GO item for 747s.
xxx
Hope this helps you...  Smile
(s) Skipper
GulfstreamGuy
Sun Mar 07, 2004 8:52 pm
Thanks B!
Now I can act like I knew what that meant all the time when someone asks me! Big grin
GulfstreamGuy
airplay
Mon Mar 08, 2004 12:16 am
The yaw damper system isn't exclusively based on "gyro" systems. It also receives yaw acceleration information, often from an internal liquid base yaw acceleration sensor.
The yaw damper offsets the rudder in proportion to the roll angle. It also "kicks" the rudder pedal in response to yaw acceleration to provide a smooth flight and offset the effects of dutch roll as mentioned.
In some aircraft, typically the smaller ones, the yaw damper is required equipment. If it is unservicable, the aircraft may be subject to operating restrictions in speed and/or altitude. This is primarily due to the descision to use a smaller (low drag) vertical stabilizer that just isn't efficient at high altitudes without some help from the yaw damper. Of course the 747 could never be accused of having a small tail....
According to the CRJ MMEL, only the -700 and -900 variants require an operational (1 out of 2) yaw damper for dispatch. The 100/200 doesn't.
http://www.tc.gc.ca/aviation/applications/mmel/en/mmel.asp?x_lang=e
AC_A340
Tue Apr 20, 2004 10:07 am
Though the CRJ may not require operational yaw dampners, some airlines do opt to include it in the MEL. I have heard that the CRJ is really hard to fly without this system. I know for sure that one of the systems needs to be operational in order to engage the autopilot. The Citation 10 has 3 of the systems because the aircraft is so susceptible to Dutch Roll.
DC-10Tech
Tue Apr 20, 2004 2:36 pm
ON the DC-10/MD-11, yaw damp is a no go. There are four independant channels, two for the upper rudder and two for the lower. At least one (at some companies, one for each rudder) must be functional.
Forums.AMTCentral.com
Users browsing this forum: CONTACREW, sunrisevalley and 2 guests
