N243NW
How Are The Reversers Engaged?
Wed Mar 10, 2004 8:31 am
Hi all-
I know the system is different between the aircraft models and manufacturers, so can any pilots or techies here explain how the thrust reversers are physically engaged and used in different aircraft (the procedure and steps involved)? I know that most/all of Boeing's planes have the reverser handles forward of the thrust levers, and if I'm not mistaken, Airbus's newer models have simple push buttons instead. Also, do any of today's commercial airliners have the capability of arming the reversers for landing? Can anyone elaborate on this topic?
-N243NW Big grin
Mr Spaceman
RE: How Are The Reversers Engaged?
Wed Mar 10, 2004 9:39 am
Hello N243NW.
I believe that most of the airliners flying today can have their thrust reversers ARMED prior to landing, as well as their ground spoilers and auto-brakes.
Once the airliner's main landing gear has compressed enough apon landing, "squat switches" on the gear make contact and they send a signal to the airliner's computers that the aircraft is infact on the ground, and then the reversers, spoilers & brakes are automatically deployed & applied.
I think these squat switches need to have contact for a specific amount of time (a few seconds), to ensure the airliner isn't going to bounce back into the air before the computers will activate the auto controls.
I believe some airliner's computers also depend on main gear wheel rpm to ensure the airliner is on the ground before these auto systems will activate.
Also, you can ARM the TR's, spoilers, brakes, (and the cabin pressure dump valve I believe) all you want before touchdown, but the computers won't activate them if the airliner isn't in landing configuration with the throttles at idle (meaning the pilots are not doing a touch and go) and with the flaps/slats at a landing setting.
This is basic info off the top of my head that I've learned from this forum. It may have some errors although I think I've got it pretty much correct.
I hope the professionals in here will expand on this info with more detail for you.
Chris  Smile
OPNLguy
Wed Mar 10, 2004 9:48 am
I usually leave these kinds of questions to the pilot folks, but I have to note that the thrust reversers must be manipulated by the crew in order to actually deploy. Both the reversers and ground spoilers use the info from the squat switch that the aircraft is on the ground, but, if armed, only the ground spoilers "automatically" deploy.
Mr Spaceman
Wed Mar 10, 2004 9:57 am
Hi guys.
> OPNLguy, thanks for making sure my info about the TR's was corrected. It makes sense that the pilots would physically move the throttles for the TR's so that they are only used as long as they're needed.
I guess I was thinking about auto-throttles or perhaps my fingers were typing faster than my brain was thinking.
Sorry about that N243NW.
Chris  Smile
N243NW
Wed Mar 10, 2004 9:59 am
So OPNLguy, you're saying that while there is a wheel spinup/squat switch for the reversers, the switch is simply a lockout to prevent inadvertent deployment in the air, and there is no actual automatic deployment unlike the spoilers and autobrakes? Also, keep in mind, pilots, that I'm also interested to know (procedure-wise) how the pilots manually engage the reversers even if they DO automatically deploy. Thanks for the replies so far!
-N243NW Big grin
gearup
Wed Mar 10, 2004 10:01 am
In the case of the Boeing 737-200 and 707 series, the reverser levers were forward of the throttles and could only be pulled back over the throttle levers if the throttle was at idle position which would or should be the case at touchdown (at least I think so!). This action by the pilot would operate the hydraulic actuators on the reverser, thus unlocking and deploying it. BTW, I really like the way the 737-200 reversers deploy! The reverser mechanism on the P&W JT8D engines is completely external and you can see everything going on if you are in a good window seat. In fact, the first time I saw it operate along with the spoilers extending and the flaps at full, I thought for a minute the wings were coming apart, there was that much stuff moving!
I have no memory of this place.
OPNLguy
You are not alone in the occasional 300bps brain and 56K fingers department--I assure you...  Big grin
N243NW
Wed Mar 10, 2004 10:28 am
Haha, well put, OPNLguy! Big thumbs up Mr Spaceman, I do the same thing. Apology accepted.
So, once the reverser handles are deployed, the throttles are moved forward as usual to increase reverse thrust? I would assume so. Unlike Airbus, Boeing doesn't have a marked "reverse area" on the throttle quadrant.
-N243NW Big grin
CanadianNorth
Gearup... The first time one of my aunts was on a plane she saw the reverse action there going on and she went as green as a plant, although i am reasonably amused by all the parts shifting around followed by the powerful roar and surprisingly fast loss of speed!
CanadianNorth
Way to go, nice and slow, never late, 748!
OPNLguy
Wed Mar 10, 2004 10:34 am
Like they say at Hertz rent-a-car, "Not exactly..."
I'll let one of the pilots here take over now... MD88Captain? AAR90? Skipper?
AJ
Wed Mar 10, 2004 10:35 am
For the 767:
-The reverse thrust levers can be raised to the interlock after main gear touchdown, which disengages the autothrottle and deploys the auto speedbrake (if not already done),
-REV in amber appears on the EICAS,
-Once the translating sleeve has fully opened (hydraulically JT9, pneumatically CF6/RB211), REV in green on EICAS, the reverse thrust levers can be raised to the full reverse position.
Each reverser has an autostow function if movement is detected in flight. On the CF6 and RB211 there is also and electromechanical lock.
In this photo the reverse levers can be seen in the forwards position between the flap handle and the speedbrake lever:
AJ
Wed Mar 10, 2004 10:38 am
To add....all reverser operation is with the reverse thrust levers only, the thrust levers remain on the idle stop.
DeltaGuy
Wed Mar 10, 2004 2:48 pm
The arming before landing is the Autospoilers...done by sliding the lever (outboard, to port of the thrust levers that AJ pictured) Those are deployed by weight on gear (on the MD-88 at least). The reversers, as said, are deployed with the levers fwd of the throttles.
Autobrakes are another armed feature...but that's not totally reverser dependent  Smile
Nice pic AJ!!!  Big thumbs up
DeltaGuy
dc10hound
Wed Mar 10, 2004 3:13 pm
On the AAL B757, the ground spoilers will be deployed automatically when reverse thrust is selected, whether Auto Speedbrakes are armed or not. I think it's actually a function for RTO...
The only way to deploy the reversers is for the crew to manually pull the levers to the interlock. As mentioned previously, increased thrust is selected by continuing to pull the T/R levers past the interlock.
"Eagles soar. But weasels never get sucked into jet intakes.."
SlamClick
Thu Mar 11, 2004 12:02 am
There are two common types of reverser handles. One is a separate reverser handle mounted on a thrust lever. (Like the B-767 shown) The other is where the thrust lever itself moves aft of idle into the reversing range. (Newer Airbus)
On the Boeing type, the handle cannot be raised to the reverse postition if the thrust levers are forward of idle. Also the thrust lever cannot be moved forward of idle with the reverser handle raised. On the Airbus types that does not apply since the thrust lever itself must be moved aft of idle, but there is a small lockout lever on the forward side of the thrust lever that must be lifted in order to move the lever aft of the idle positon.
On either type the engines are at idle just on each side of the reverser interlock. Increasing reverse thrust requires pulling the levers farther aft (Airbus) or raising them higher (Boeing and McDoug) which is sort of aft or instinctively feels like aft travel.
The behind the scenes reverse interlocks that have been discussed in other replies above are found on most newer airliners but some of the early ones could be reversed in flight if you were feeling sporty. I believe that two engines in reverse idle was a speedbrake mode in the DC-8. Anyone confirm that?
Also, I think it has been cleared up already but I am not sure there are any T/Rs that can be "armed" prior to touchdown. Not necessary to take any action with cabin pressure either. Most modern systems schedule the cabin down to zero differential pressure (approximately) just before touchdown, and drive the outflow valves full open on ground shift anyway.
Last, as has been posted here before, thrust reversers are not the big factor in stopping the airplane. The shake the plane and make lots of noise but stopping with T/Rs alone would take five times as much runway as stopping with brakes alone. In fact ground spoilers are more important to getting stopped than T/Rs are because they transfer the weight to the wheels a lot faster which makes wheel braking possible.
Slam "easy on the Jake Brake" Click
JBirdAV8r
Thu Mar 11, 2004 12:46 am
I believe it was. The two inboard engines could be put in idle reverse to compensate for the fact that the DC-8 had no flight spoilers.
I like your Jake Brake analogy...clever...never thought about that before!
goingboeing
Thu Mar 11, 2004 1:28 am
OPNLguy....plan me a good route - Friday, 3/12 flight 2110.  Big grin
OPNLguy
Thu Mar 11, 2004 2:11 am
Don't I always?  Big grin
A3204eva
Thu Mar 11, 2004 7:32 am
I like the Airbus reversers, just pull the throttle all the way back- nice and easy.
Photo © Luis Rosa
"They have lady pilots......... they're not that good, but they have 'em"
AC_A340
Tue Apr 20, 2004 9:57 am
On the CRJ, the thrust reversers are like on boeing products, with weight on wheels and thrust levers at idle, you can move the reverse levers up and 14th stage bleed air (on -200 series, -700 series is hydraulic) opens the thrust reverser doors and then you can pull the thrust levers to whatever reverse position needed. They also need to be retracted by about 60 knots.
The spoilers and everything else are automatic. If the GLD (Ground Lift Dump) is armed, when the aircraft touches down, and the thrust levers are at idle, and there is a certain wheel speed (among other things) all of the spoilers and spoilerons deploy. They also retract automatically when the aircraft is slow enough.
Users browsing this forum: texl1649, WIederling and 1 guest
