How Much Fuel Can A 747 Carry?
Thu Mar 18, 2004 1:02 am
Hi!
I wonder how much is the fuel capacity of a B747-400. And how much fuel does a B747-400 burn on a Transatlantic flight... ( no matter which destinations, flight alt or speed ) ... just on average please
[Edited 2004-03-17 17:03:18]
andrej
RE: How Much Fuel Can A 747 Carry?
Thu Mar 18, 2004 1:40 am
Hello,
fuel capacity varies from airline and type of airplane. Is it cargo or passanger? Thus capacity can be from 163 tons to 176 tons.
I believe that B744 usually takes 10tons of fuel for one flying hour. It should be more for the first flying hour. Please correct me if i am wrong.
Thanks.
Andrej
Thu Mar 18, 2004 1:52 am
Dear Andrej -
xxx
You are very well informed, your numbers are quite correct  Big grin
I do not fly the 400, I only fly the 200s, but I know their fuel numbers...
A heavy cargo may burn a little more per hour.
But typical JFK to LHR would be the figures you indicated.
They fill their tanks to some 90 tons for such flight.
They land with some 15 tons remaining, maybe 20 at most.
xxx
Happy contrails -
(s) Skipper
Thu Mar 18, 2004 1:54 am
After some digging, I found that: "The 747-400 can carry more than 57,000 gallons of fuel (215,745 L)"
mrwayne
Thu Mar 18, 2004 2:29 am
A 747/400 can carry roughly 206,250 litres / 165000 kgs of fuel, it all depends on the S.G meaning weather conditions.
It burns roughly 10 tonnes of fuel an hour.
Thu Mar 18, 2004 3:47 am
By taking my head out of my ass for a moment, I found out that with the optional horizontal stabilizer tank, the 744 can carry 215,991 to 216,824 litres (173,424 to 174,093kg) of "usable fuel" (whatever that means). Without the extra tank, it can carry 203,493 to 204,333 litres (163,396 to 164,064kg).
The 744F can carry more if optional body tanks are installed. Up to 240,196 litres (192,860 kg)
Starlionblue (putting head back in his ass) hopes that he didn't get the numbers wrong.
KYIPpilot
Thu Mar 18, 2004 4:59 am
Starlion, "usable fuel" means fuel that you can use, as far as regs are concerned, until you need to get more. Therefore, "unusable fuel" is the minimum amount of fuel that an airplane should ever land with. You are not supposed to fly past your usable fuel limit, or you risk running out.
I hope that makes sense. Someone else may explain it better.
"It starts when you're always afraid; You step out of line, the man come and take you away" -Buffalo Springfield
flightsimfreak
Thu Mar 18, 2004 4:17 pm
KYIPpilot: In GA, I'm not sure if it's the same as in the airline world, but in GA, usable fuel is the fuel that can be sucked out of the tanks... The unusable fuel is there to catch contaminates that settle out. For example, the warrior I fly has 2 25 gallon tanks, but only 48 gallons total usable gallons. Because of the shape of the tanks and the position of the intakes, there is one gallon in each tank that the engine cannot get. In theory, this is where the water and muck in the fuel will go.
Thu Mar 18, 2004 5:02 pm
GA or airlines - same definitions -
xxx
Usable fuel - fuel in the tank that can be "pumped" for use in engines. Level flight.
Unusable fuel - residual fuel at bottom of tank, cannot be pumped out. Could be drained out.
That is the fuel that is located "below" the fuel pump(s)...
xxx
Unusable fuel is not accounted as fuel "available". It is part of the basic "empty" operating weight.
In a 747, may be some 300-500 kg...
xxx
Happy contrails  Smile
(s) Skipper
Thu Mar 18, 2004 6:27 pm
Slight correction -
There is also reference made to "undrainable fuel" -
Fuel that is below the level of fuel drains...
xxx
Again, the only fuel of concern to flying is "USABLE FUEL"...
xxx
(s) Skipper
Thu Mar 18, 2004 7:57 pm
Thanks! That does explain a lot.
On a related note, I have heard of "gravity feed", specifically that the 737 can "gravity feed" both engines from either wing tank without operational fuel pumps. This seems logical given that the engines are under the wing.
But what about our tail mounted friends? What happens if the pumps break? Can they siphon it up like a petrol thief?
Thu Mar 18, 2004 8:02 pm
Yes Starlionblue -
xxx
You can feed an engine that is "higher" than the tanks (i.e. 727, DC9)...
Fuel tanks are slightly pressurized, generally by "ram air"...
The more indicated airspeed, the more ram air pressure...
But yet it is quite low pressure, but sufficient to feed the engines somewhat.
Some airplanes need to descend to lower altitude when they have to feed engines that way.
Lower altitude, more indicated airspeed, more pressure.
xxx
(s) Skipper
Thu Mar 18, 2004 8:06 pm
Thanks Skipper. As always your explanations are much appreciated.
Thu Mar 18, 2004 8:16 pm
I remember in my "long time" notes learning about Boeing planes, and having stayed awake in the classroom, mention was made of the figure of 0.8 psi "head of pressure", present in the tanks, excess pressure was vented overboard by relief valve which was set at that pressure number. Very low value indeed.
xxx
(s) Skipper
sllevin
Thu Mar 18, 2004 9:31 pm
There's also one more case for "usable" fuel -- it is the fuel level that can be "accessed" during all permissible flight attitudes (i.e., higher bank angles). You might be able to pull that fuel while in straight and level flight, but not in a bank angle, say, turning downwind to base leg  Smile
Steve
Fri Mar 19, 2004 3:14 am
In the 747 we have a limitation with low fuel (less than 10 tonnes remaining).
Maximum nose up attitude 10 degrees in case of go around.
We also open all crossfeeds, and all main tank boost pumps must be ON.
xxx
Note that most airliners have 2 pumps per tank, one generally located forward, one located aft, so if nose up or nose down, one of the pump will still be able to get fuel.
xxx
(s) Skipper
wannabe
Fri Mar 19, 2004 4:24 am
Allright gang,
So far in this tread, I have seen fuel amounts measured in:
Tons (not sure if that is US or British)
liters
Kilograms
Gallons (not sure if it is US or Imperial)
Who makes sure that this 747-400 doesn't become the next Air Canada glider? What is (IF there is) the standard international unit of measurement for fuel?
mrwayne
Fri Mar 19, 2004 4:37 am
Wannabe; fuel is measured in weight; in the UK and EU we measure in KGS ie;36500 kgs is 36.5 tonnes.
In the USA it is in Lbs and US Gals totally different from the UK/EU market.
Fri Mar 19, 2004 5:44 am
Dear Wannabe -
xxx
Big problem here, the USA has gallons and pounds. Nobody else does.
300 million people vs. humanity, of what, 4.5 billion?, in the rest of the world.
Europe, Asia, Africa, South America, Australasia, Canada is METRIC.
xxx
In the real world, fuel is sold in LITRES...
Airplanes and pilots fly with KILOS (or TONNES, which is 1,000 kilos)...
xxx
I just made an entry in "Fuel Query" here in Tech.Ops...
Suggest you have a look, some explanation of volume vs. weight...
I am just "metric"... I do not have Albert Einstein's brains...
xxx
(s) Skipper
Fri Mar 19, 2004 7:24 am
To keep it simple, Boeing docs have litres, kilos and gallons. Of course, the ratio of volume to weight varies with temperature, but that's a whole other problem Big grin
Moolies
Fri Mar 19, 2004 11:59 pm
SAA in their inflight magazine say their 744 (if memory serves me correctly) carries 219000 litres.
