splitzer
Super Fan And Tandem Fan Engines
Sun Apr 11, 2004 9:03 am
Can anyone post some diagrams and explanation of the concepts of these engines?
I heard the Tandem Fan had something to do with STOVL aircraft, and the Super Fan was something to do with the A340.
Klaus
RE: Super Fan And Tandem Fan Engines
Sun Apr 11, 2004 9:47 am
The "SuperFan" engine was supposed to employ a geared fan in order to further increase the bypass ratio and overall efficiency by letting the fan rotate slower than the low pressure compressor and turbine. At the time, the concept didn´t come through and Airbus had to scale down to the lower-thrust engines used on the A340-200 and -300s. Only the re-winged A340-500 and -600 were able to use the much larger (but still conventional) RR engines.
Interestingly, though, Pratt & Whitney now seem to have solved the original problems with the geared fan concept and have proposed it for use with the 7E7. As far as I know, Boeing have rejected this proposal, but if P&W can really make it work in practice with an attractive efficiency gain and at acceptable maintenance cost, it could still be used for a new range of engines - maybe even as an alternate choice for the A340NG...
FLUG REVUE October 1998: Pratt & Whitney PW8000 in development
Pratt & Whitney - News - Press Releases
[Edited 2004-04-11 02:55:56]
QantasA332
Sun Apr 11, 2004 5:57 pm
For some information on what a Tandem Fan is, check this out...
QantasA332
splitzer
Mon Apr 12, 2004 2:09 am
Thanks QantasA332
The message you were about to post is too short and probably not of any higher value to the topic at hand. You should think long and hard before posting a message in this forum and make it detailed and a valuable addition to the topic discussed.
Avoid posting "Me Too" messages. These are messages that are posted by people who agree to a point being discussed and post a one liner, "me too!", "Good post Jim!", "I disagree" or similar message. This takes up time as readers must sort through these messages which have no real value to the group at large. Any message containing nothing more than a line or two of text is probably not worth posting.
If you have an opinion on a topic, you should in detail express why you have the opinion and what made you come to that conclusion.
Your post should be relevant to the topic discussed.
zionstrat
Tue Apr 13, 2004 12:24 am
Splitzer
I for one enjoyed the Tandem Fan link- Not sure if this what you were to refering to-
splitzer
Tue Apr 13, 2004 2:32 am
Yeah that is what I meant, though I heard about the Tandem Fan concept from the F35 programme - Rolls-Royce looked at the concept, but Lockheed came up with the Lift Fan concept.
Users browsing this forum: B6JFKH81, Balerit, ChrisKen, DiamondFlyer, res77W, Woodreau and 2 guests
