ra-85154
Steering The Nose Gear: How?
Wed Jun 02, 2004 9:30 pm
Hi !
I know a lot about aircraft and cockpits, but one thing I still haven't figured out yet Big thumbs up
How (or with what) do the pilots steer the nose gear of an aircraft?
Thankz
Martijn
737doctor
RE: Steering The Nose Gear: How?
Wed Jun 02, 2004 10:11 pm
This is the way it works for the 737:
Hydraulic power from system A is used to turn the nose wheels to either side from zero to 78 degrees. An alternate nose steering switch on the captain's panel allows power from hydraulic system B to turn the nose wheels if power from hydraulic system A is lost. Steering is controlled by a tiller wheel by the captain's left knee and by an interconnect mechanism from the rudder pedals. The tiller gives you full steering authority up to 78 degrees. Rudder pedal steering is available during takeoff, landing, and taxiing when small directional changes are required. Full deflection of the rudder pedals produces about 7 degrees of nose wheel steering. A squat switch on the nose landing gear ensures that rudder pedal steering is only available while the a/c is on the ground.
Patrick Bateman is my hero.
RduBE90Pilot
Wed Jun 02, 2004 11:09 pm
On smaller aircraft, such as the King Air:
Ground steering is accomplished by direct linkage between the rudder pedals and the nose wheel steering linkage. After take-off, a straightener roller centers the nose wheel as the gear retracts into the wheel well.
Klaus
Thu Jun 03, 2004 1:09 am
Is the deflection of the nose gear proportional to the deflection of the tiller as in a car or does the tiller directly control the valves of the steering actuators ("more left" / "more right").
If it´s proportional, how exactly does the servo mechanism work in the older (mechanical) models to achieve that proportional control? (In the newer ones, I´d expect an angle sensor and a digital valve controller with analog or digital input from the tiller.)
Is the tiller self-centering?
Is there an indication of the current nose gear deflection in the cockpit?
MD11Engineer
Thu Jun 03, 2004 1:31 am
Actualy it is usualy just a mechanical system with a valve controled by the tiller and the rudder pedals through cables and a feedback, which closes the valve again once the desired angle is reached.
The control input from the rudder pedals is smaller.
On the 737, once the nose gear becomes airborne, the squat switch will give a signal to a small electrical actuator, which will disengage the rudder pedal input from the nose wheel steering mechanism, so that the fully extended gear can center itself through a centering cam inside the shock strut.
On the MD-11 this disconnection is done purely mechanically.
Jan
Sinlock
Thu Jun 03, 2004 2:14 am
On the ERJ-135,140,145
The nose wheel steering is done with the Flight Yoke. There is a thumb button that engages/disengages it.
Klaus
MD11Engineer
Thu Jun 03, 2004 2:54 am
MD11Engineer: Actualy it is usualy just a mechanical system with a valve controled by the tiller and the rudder pedals through cables and a feedback, which closes the valve again once the desired angle is reached.
Thanks... I guess the same was/is true for the flap positioning servos.
Do the newest models still use mechanical servos everywhere or have they moved towards electronic/digital ones in the meantime? (It´s obvious for primary flight control on FBW types, but what about flaps and nose gear steering?)
MD11Engineer
Thu Jun 03, 2004 5:05 am
On the A320 and later the flaps and slats are controled electrically, same as the nose wheel steering. The A320 has 3 cable systems, if I remember correctly, it´s been a while, rudder, stabilizer trim and emergency landing gear extension.
Jan
Klaus
MD11Engineer
Thu Jun 03, 2004 5:23 am
That´s what I suspected.
Thanks.
ba97
Thu Jun 03, 2004 11:52 am
Question to those holding the tiller/wheel...how do you stay on the yellow line when you are turning or lining up at a gate? You are driving semi blind...no?
there is economy class, business class, first class...then Concorde..pure class
Jetfixer75
Thu Jun 03, 2004 12:15 pm
Rigging the steering on a 737 is such a "joy"!!! I think I'd rather gouge out my eyes with a screwdriver rather than squeeze through those aft pressure panels.
QantasA332
Thu Jun 03, 2004 12:58 pm
Photo © Luis Rosa
 Big thumbs up
QantasA332
320tech
Thu Jun 03, 2004 1:55 pm
Klaus:
On the A320 and Dash-8, at least, there is something called a LVDT or RVDT (Linear or Rotary Variable Differential Transducer) that measures the position of the nosewheel. This information is sent to the BSCU (Brake and Steering Control Unit - A320) or ECU (Electronic Control Unit - Dash), where it is compared to the tiller or rudder input. The BSCU/ECU then commands the hydraulic valve to port more or less pressure to the steering cylinder, and the wheels move as commanded.
Is the tiller self-centring? Yes.
Is there indication in the cockpit? No.
[Edited 2004-06-03 07:26:18]
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
MD11Engineer
Thu Jun 03, 2004 2:21 pm
In myold company (LH Technik SXF) we had a short, skinny young guy to do the rigging of the 737 nose wheel steering cables. He wassmallenough to fit comfortably through those panels into that tight space beside the wheel well. Only problem was, he was singing the whole time while he was working  Wink/being sarcastic .
Jan
ra-85154
Thu Jun 03, 2004 3:57 pm
Thanks for the replies guys~!!!  Smile
I keep learning!
keesje
Thu Jun 03, 2004 7:20 pm
"Is there indication in the cockpit? No."
and even if there is an indicator the pilot has to take a look at the right moment, check out this photo & caption  Wow!
Photo © Erwin
Klaus
320tech
Thu Jun 03, 2004 9:05 pm
320tech: On the A320 and Dash-8, at least, there is something called a LVDT or RVDT (Linear or Rotary Variable Differential Transducer) that measures the position of the nosewheel. [...]
Looks like a standard electronic servo setup, indeed. Thanks.  Smile
320tech: Is the tiller self-centring? Yes.
With the tiller self-centering, that would probably eliminate the need for such a display.
While you´re "here": Could you please say a word or two about the A320 rudder control system in this thread: Airliners.net Aviation Forum - Rudder Limiters & Ntsb Which Comm A/craft? Please!  Big thumbs up
EMBQA
Fri Jun 04, 2004 5:39 am
So what is the steering tiller next to the Capt's knee for......??
Photo © Europix
If I remember correctly from ERJ School, the yoke only gives you 5 to 8 degs of turning radius, and only really used during the final moments of take off and landings. The real steering is done by the tiller which gives you significantly more turning radius.
[Edited 2004-06-03 22:56:54]
Mender
Fri Jun 04, 2004 5:52 pm
Klaus
"how exactly does the servo mechanism work in the older (mechanical) models to achieve that proportional control? "
This works in exactly the same way as any other cable controlled hydraulic actuator such as an aileron or rudder actuator. This would be very easy to explain using a pen and paper. I'll try my best with text.
If you imagine the actuator has a hydraulic control valve mounted on the body of the actuator. Bolt the body of the actuator with the control valve to the wing and the moveable end of the actuator to the control surface.
If you apply a minute input to the control valve the actuator will slowly extend to maximum extention. A larger input will make the actuator extend to max quicker. With the actuator connected like this you do not have any "feedback" to the control valve.
Now imagine the same setup as above but turn the actuator around and connect the moveable end of the actuator to the wing and the body and control valve to the control surface.
Now what happens is that when you put a small input into the control valve via your control cable the actuator and control valve extends away from the control cable pulley and "nulls" the input so stops extending. Move the cable more and the actuator extends a little move then nulls. This is a feedback system.
I hope you can understand this. It'd be very easy to understand is you could see it.
Klaus
Mender
Fri Jun 04, 2004 7:25 pm
Thanks again.
I generally know how a mechanical servo works; I just tried to find out how exactly it would have been implemented in this case.
Nothing beats being able to actually have a look at the real thing with hands-on explanations... But this forum here is still not a bad substitute.  Wink/being sarcastic
Mon Jun 21, 2004 3:55 pm
Actually a lot of pilots prefer to taxi with the nose gear to one side of lines. Since these tend to have lights inset in the middle, riding directly on the line will yíeld a bump-bump-bump-bump to the ride. No big deal but I guess it either wears out the tires or is aesthetically irritating.  Big grin
XFSUgimpLB41X
Tue Jun 22, 2004 3:42 am
Starlion- the bumps are offset from the centerline actually. If you are right on the centerline then you won't have the "stevie wonder" centerline.
Chicks dig winglets.
Georg
Fri Jun 25, 2004 4:14 am
I know that Dash8 can be also switched to mode where you can turn nosewheel with yoke.
NO URLS in signature
T prop
Sat Jul 10, 2004 9:38 am
Never heard of that, and I've worked on Dash 8's for years. Is it something new, or is this somthing the Q400 has? Sounds handy if the F/O wants to steer.
T prop.
Users browsing this forum: zaphod42 and 26 guests
