nwaflyer
What Does The Term "heavy" Mean?
Fri Jun 18, 2004 10:10 am
I seen and heard the word "heavy" used. What determines that an aircraft is "heavy"?
MD11LuxuryLinr
RE: What Does The Term "heavy" Mean?
Fri Jun 18, 2004 10:13 am
Ha.. if it weighs over 250,000 pounds.. loaded..
Caution wake turbulence, you are following a heavy jet.
rockyracoon
Fri Jun 18, 2004 10:21 am
Heavy planes require larger spacing in airspace traffic patterns. THey're wake turbulance can really toss the smaller airliners around. Exception to the rule is the 752, sometimes it gets treated like a "heavy" due to it's strong wake turbulance, even though it is >250,00 lbs (some weigh 250+ ie: TZ).
peace
Airports: CVG PIT MWO PHL PIT PHX ORD DCA MIA TPA MCO ATL DTW DFW SJC LAX DEN SLC LAS HNL LIH OGG YVR MUC ICN NRT PVG SHA SZX MNL PPS CRK BKK DMK KBV EOH MDE CLO CTG SMR BOG ACD MEX CUN MID
ConcordeBoy
Fri Jun 18, 2004 10:29 am
actually, it has to weigh over 255,000lbs
MD11LuxuryLinr
Fri Jun 18, 2004 11:05 am
~" Exception to the rule is the 752, sometimes it gets treated like a "heavy" due to it's strong wake turbulence"~
Assuming you mean that all aircraft flying behind it are a minimum of 5 miles (IIRC) away because of wake turbulence, then yes. All 757s are treated that way.
As far as being 'heavy jets', for airlines like AA, UA, US, etc., the 752 is not.
Brick
Fri Jun 18, 2004 12:43 pm
I have heard 752's be referred to as heavy just a few times in all of my years listening to ATC on United Airlines. The 753's are almost always referred to as heavys.
A noble spirit embiggens the smallest man...
calpilot
Fri Jun 18, 2004 2:53 pm
MGTOW has to 255,000lbs. Not actual weight.
wilco737
Sun Jun 20, 2004 6:59 am
Hi you guys,
all of your posts were correct, but the "heavy" is just the wake turbulence category, which results of the weight!
There is light, medium and heavy. It is important for separation between the aircrafts. A 737 needs to be separated of a minimum of 2 minutes behind a heavy. Otherwise it can encounter these severe wake turbulence, which can bring you in unusual attitudes!! Like we saw on the AA 300 in NY! The encountered wake turbulence of e preceding 747 and we know what happened.
The B752 is also heavy, although its weight is not above the limit for the wake turbulence category, but the 752 has short wings and these short wings need to produce a lot of lift! And with this lift the wake turbulence are even worse! So a 752 is heavy!
In ATC Communication they use the word HEAVY to make sure, that there is sufficient separation between the aircrafts...
WILCO737
Users browsing this forum: CrimsonNL and 20 guests
