modesto2
Brake Fans
Sat Jun 26, 2004 10:30 am
Do most airlines equip their aircraft with brake fans? Why or why not?
EMBQA
RE: Brake Fans
Sat Jun 26, 2004 11:00 am
No....weight being the big reason, and the better quality of newer carbon brake stacks being second.
G4Doc2004
RE: Brake Fans
Sat Jun 26, 2004 1:04 pm
Actually the BAE-146 used brake cooling fans. If I recall correctly they were hydraulically powered and worked well.
"Failure to prepare is preparing to fail"--Benjamin Franklin
Fly2HMO
RE: Brake Fans
Sat Jun 26, 2004 2:05 pm
I'm a huge brake fan...
GO BRAKES, GO!!!!
 Big grin
fadec
RE: Brake Fans
Sat Jun 26, 2004 4:47 pm
Some do, some don't. It all depends on the airline, and if they think they are worth it.
The majority don't use them. Normally because of weight and cost to maintain. I can say we hated seeing them... they were total pain to work with.
DL_Mech
RE: Brake Fans
Sat Jun 26, 2004 5:01 pm
Pan Am A-310's had them, Delta's new ordered A-310's did not.
This plane is built to withstand anything... except a bad pilot.
B747FE
RE: Brake Fans
Sat Jun 26, 2004 11:47 pm
Also depend of the rates of cycles and the time between flights.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
air2gxs
RE: Brake Fans
Sat Jun 26, 2004 11:58 pm
I believe that we only turn the fans on when the brake temps are in danger of reaching overheat. The reason is that the rapid cooling of the carbon stack may lead to brittleness. This is on our buses.
SlamClick
RE: Brake Fans
Sun Jun 27, 2004 11:44 am
Fly2HMO if you really were a big brake fan, you'd know that the cheer is:
STOP BRAKES! STOP!
That is what brakes do.
Brake fans also work a lot better if you can leave the parking brake off.
Minuteman
RE: Brake Fans
Mon Jun 28, 2004 12:26 pm
Where are the fans usually placed and what do they look like? (I'll give a shiny quarter to anyone who find a picture in the database  Big grin )
I would guess the cooling has more to do with the rotors than the pads, although that may reveal my ignorance of most brake setups. It seems like a little bit of convective cooling wouldn't be bad.
G4Doc2004
RE: Brake Fans
Mon Jun 28, 2004 3:20 pm
Not in the Anet database, but here's a link to a very informative page:
http://www.technofan.com/public/technofan/html/en/technofan/produits.php?aid=57&fake=
sabenapilot
RE: Brake Fans
Tue Jun 29, 2004 6:32 am
It depends really on how much time between flights the airline expects to have with its plane... at SN for instance we didn't have brake fans on the A340, but we did on the A330, because with the A330 we regularly did short hops between African airports and the cooling time (especially in hot climates) was deemed too short to do without...
willo
RE: Brake Fans
Wed Jun 30, 2004 12:01 am
The 146 brake fans are electric (we make the motors and impellers that are fitted to the Dunlop units).
modesto2
RE: Brake Fans
Wed Jun 30, 2004 9:59 am
Thanks for the replies, everyone. I was just curious because we use brake fans at JetBlue. Often times, I see the brake fans engaged when entering cockpits - 35 minute Blue turns require these devices...
Users browsing this forum: 747classic, Bing [Bot] and 19 guests
