mozart
Boeing 737NG - Which Tank Gets Filled First?
Wed Jul 07, 2004 7:40 am
Which tank gets filled first:
- the center tank, and then remaining fuel in the side tanks
- or first the wing tanks, and then remaining fuel in the center tank?
OPNLguy
RE: Boeing 737NG - Which Tank Gets Filled First?
Wed Jul 07, 2004 8:04 am
On -all- the 737 variants, it's fill the wings first, before you put anything in the center tank. It's an AFM (airplane flight manual) limitation...
Wed Jul 07, 2004 8:27 am
Heavier wings give less wing bending moment, which is a good thing.
As far as I know, this is pretty much the norm in modern airliners.
FDXmech
Wed Jul 07, 2004 8:48 am
Are you asking which tanks are refueled first?
QantasA332
Wed Jul 07, 2004 9:05 am
While that's certainly true, I doubt it comes into play in terms of what get refueled when. Obviously, wing bending is only present when the wings are lifting, so relieving that bending is a mute point while on the ground (refueling).
QantasA332
Wed Jul 07, 2004 3:40 pm
Hmmm, but eventually the plane will be in the air, and in case of a short trip it might dispatch with the center tank empty or partially filled. So that is relevant right? Or I may pf course be wrong  Big grin It's all about learning.
QantasA332
Wed Jul 07, 2004 4:11 pm
You're completely right: in the case of a short trip, yes, wing bending considerations would certainly come into play (assuming you're not just topping up all of the tanks). I was just thinking more along the line of a "normal" (longhaul?) all-tanks-filled flight, for which fuelling order wouldn't matter in terms of wing bending. Sorry, I hadn't be very clear before.
QantasA332
Crosswind
Wed Jul 07, 2004 9:48 pm
Even on a long-haul - unless you're really pushing the aircraft's range limits, it's rare for the fuel tanks to be full. You will usually reach your MTOM due to the payload carried before fuel-voulume becomes limiting.
As such, the centre tank will always be filled last, even on short-haul. As OPNL/Starlionblue said, this is a structural requirement to minimise the bending moment of the wings, particularly in the initial stages of flight when the aircraft is haviest. A similar rationale is behind the max ZFM, which I believe is set with reference to the stresses on the wing/body joints, again too much of mass in the fuselage which then has to be supported by the wing/body joints puts additional stess on the aircraft, which is not healthy for them long-term.
Photo © Chris Sheldon
Photo © Joe Pries - A.T. TEAM
As an example of the use of the centre tank, on the 757, for flights up to around 2-2h30 duration the centre tank will be empty - aside from the unuseable fuel which is mandated by the current ADs.
CROSSWIND
[Edited 2004-07-07 15:20:33]
Users browsing this forum: rjsampson and 1 guest
