SafetyDude
Yet Another 747 Door Question
Fri Jul 16, 2004 10:16 am
Yes, I have another 747 door question.  Big grin
Photo © Diego LAO
On the left side of the door is 3/4 of a green square and then another one right opposite of it on the fuselage. My best guess is that the squares are to align the door, but any help would be appreciated.
Thanks.
-Will
"She Flew For What We Stand For"
air2gxs
RE: Yet Another 747 Door Question
Fri Jul 16, 2004 11:23 am
I don't think it is used to align the door. Though never having worked a -400 I'm pretty sure from pictures I've seen that it is the same door as on the classics. The door on a classic doesn't need to be aligned. It is pretty much lined up or it will not lock.
Now what are the markings? From the location, it could be the hook-up location for a lanyard that keeps the door from swinging all the way open on the ground. We have them on some of our aircraft. It just keeps the door from swinging all the way open. This lanyard is not installed all the time. It is there for ground ops only and by flight crew only under very specific conditions. Of course it could not be used in flight due to pressurization.
avioniker
Sat Jul 17, 2004 12:06 am
It's a french plane.
Probably some anal compulsion to know where the hinges are located when they're out of sight.
Actually after looking in Chapter 11 they're not listed so my personal best guess is alignment marks for the door panel installation or maybe my first guess was right and they're "cut here" marks for an emergency?
air2gxs
Sat Jul 17, 2004 3:19 am
Just realized, that door opens forward, so its not what I thought. It is in the right place for the upper hinge, but why do you need to know that from the inside? Its not a cut here mark, AFR is taught to avoid doors when cutting. Too much structure and the possibility of a slide or door assist blowing.
DL_Mech
Wed Jul 21, 2004 4:51 pm
It looks like a designated area for placing a tamper-proof security seal sticker. These are placed on the doors when the aircraft is parked overnight in a remote area.
This plane is built to withstand anything... except a bad pilot.
SafetyDude
Thu Jul 22, 2004 12:07 am
If the stickers have to be placed inside the aircraft, then would their not always be a door that would not have a seal?
 Smile
-Will
DL_Mech
Thu Jul 22, 2004 5:32 am
One door could have the sticker on the outside.The others mounted inside would be easier to inspect.
Users browsing this forum: coronado, yv773p and 2 guests
