Hugh3306
Engine Water Wash
Sat Jul 24, 2004 7:37 pm
Hi,
Any experience with commercial jet engine water wash? Especially interested in indicators of when to wash, benefits derived from wash, problems encountered, frequency of wash, how to, etc. Pretty much anything to do with engine washing (good and bad).
Thanks.
Bungle
RE: Engine Water Wash
Sat Jul 24, 2004 9:56 pm
I've never had to do an engine wash but I know you should use deminralized water. And you don't have to use water to clean an engine at college we were told that crushed almond shells can be fired down, the intake when the engine is running, as the shells are abrasive enough to remove dirt but do not damage the engine.
BUNGLE
airplay
Sat Jul 24, 2004 10:14 pm
There are various methods of cleaning the engine, most using water or a mixture of water and a detergent.
I have seen the use of a water/Magnus solvent (Magnus is a trade name but most of us call this stuff "Magnusol") which is quite a powerful degreaser. The mixture is sprayed into the intake while the engine is dry-motored then pure water is sprayed to rinse. The Magnusol is normally clear but turns white on contact with water, so its quite easy to determine when the engine is completely rinsed.
Magnusol is quite corrosive if you don't rinse thourougly.
The walnut shell method is often called a carbo-blast. It is effective and creates a great light show but the abrasive qualities of the material cause some erosion of the blades so its not used anymore as far as I know. Of course someone out there will come up with proof of someone in darkest Africa still using this method!  Smile
The ground-up walnut shells are fed into a hopper that releases them into the running engine.
The benefit of engine cleaning is purely one of maintaining efficient blade shape. Each compressor and turbine blade are tiny airfoils whose shape is ooptinmized for their purpose. Grime and dirt that builds up, modifies the shape of the blades not unlike icing on the leading edge of a wing and spoils the efficiency.
aloges
Sat Jul 24, 2004 10:43 pm
interesting thread
Does anyone know what "mild abrasive" is sprayed into this engine?
Photo © Colin T. Ebert
WrenchBender
Sun Jul 25, 2004 12:25 am
It depends on whether you are talking about Power Recovery Washes (generally what most people above posted about) or a daily De-Salination Wash carried out at the end of the day, on A/C operated on or near Salt Water.
Indications that a power recovery wash is required are higher Ng/N1 or T5 indications for a given Nr/Np/N2 setting. this means the compressor is having to work harder to deliver the same amount of power and therefore requires cleaning.
The de-salination wash is usually a fresh water rinse of the engine (sometimes while running) to remover any salt build up from the compressor and turbines. and is followed by a drying out run after.
WrenchBender
edited for dyslexic fingers
Silly Pilot, Tricks are for kids.......
MD11Engineer
Sun Jul 25, 2004 12:51 am
Airplay, LH still does carboblasts on their MD-11s.
During my apprenticeship we did turbine water washs on JT8D engines of B737-200s. We would remove the ignitor plugs and stiock a special probe through each ignitor hole. This probe was connected to a fire hydrant. Then we would dry motor the engine a let the water flow. The main reason was to dissolve sulphurous deposits in the hot section and wash them out.
Jan
Mender
Sun Jul 25, 2004 2:47 am
"Does anyone know what "mild abrasive" is sprayed into this engine?"
It's called Jetshot which is form of coke (coal dust) and it's still used today. It's spray dry into the core of the engine at idle power using the compressed air lance you see in the picture. From the flight deck you can barely tell it's being sprayed into the engine, there's a tiny change in EGT. That's it. There will be a bigger effect at high power but the bloke on the Jetwash rig would suffocate because the engine would pull the air out of his lungs!
Hugh3306
Sun Jul 25, 2004 9:13 pm
Thanks for the input so far, but I could use some more cost / benefit information. Thanks!
PS: The following is NOT what I meant  Smile http://www.cybersalt.org/cleanlaugh/yourturn/yt25.htm
EMBQA
Sun Jul 25, 2004 10:44 pm
As said above, in this case it's 'Coke'.....a Steel Production by-product. I've only done it one time on a Saab 340 (GE-CT7). On the down side you can only 'coke' the CT7 one time before your required to send to overhaul as it can actually remove material. On a turboprop it REALLY stinks because you need to stand behind the engine keeping all the hoses out of the way of the prop...and when you inject the coke, you get enveloped in a cloud of coke dust. Coking is only done on an as needed condition and is designed to remove the hard baked on build up.
As for the 'Comp-Wash'... You spool up the engine with the ignition off and inject a heated degreesing fluid into the intake. To me it smells and looks like auto engine degreesing spray and works almost the same way. After you've washed the engine, you then clean it out with several clear water washes, then drag the plane outside and run it to blow out the water and get rid of any bad smells from the washing. If I recall, on the CT7 we did the Comp-Wash every 800hrs or so. As for the cost/benefits......Cost is not that high, just the cost of the Wash Fluid....Benefits include a cooler running engine and thus a longer 'on-wing' time.
Photo © Christopher Edler
[Edited 2004-07-25 15:55:59]
Hugh3306
Mon Jul 26, 2004 7:53 pm
Besides engine cooling (I have seen reports of EGT improvements in the 10 - 15 degree range), what about fuel economy gains for the airline? Also, is engine washing something regularly done at a C check or more often than that?
MD-11 forever
Mon Jul 26, 2004 8:25 pm
Well, a reduction of EGT indication usually comes together with a fuelflow reduction. Regarding the interval, there is no such rule as far as I know. It depends largely on the type of operation an airline has got.
Cheers, Thomas
LMP737
Thu Jul 29, 2004 12:01 am
While I have never done an engine wash on commercial aircraft I have done it on the F-14. Along with keeping EGT temps down it had the added benefit of removing salt from the engines as well.
The engine wash was part of scheduled maintenance. We used a cart specifically desined for washing jet engines. It consisted of tank that held the water/cleaning solvent, a nitrogen tank, and a fitting that attached to the fixed inlet guide vanes. Before you did the actual wash you first had to remove the water traps on the engine so as to prevent water from getting into the engine fuel control system. This can cause the engine to stall.
Once this is done you motor the engine and release the agent into the engine. After all the water/solvent is empteid from the tank you refill it with fresh water only and recharge the nitrogen tank. Then's it's "rinse and repeat".  Smile
After the cleaning is finished you reinstall the water traps and run the engine to dry out the motor.
Buzz
Thu Jul 29, 2004 10:59 pm
Hi Hugh3306, Buzz here. At UAL we used to water wash the JT8D engines in the summer, slight improvement - lower EGT.
I've seen that coke-cleaning of a DC-10 engine - what a mess downwind! It couldn't save the high EGT on that engine, was changed within a week.
Once my partner and i did a DC-10 APU rice-hull cleaning, while standing within touching distance of the APU inlet we sprinkled handfuls of rice hulls which were sucked up and in. OK, so you're supposed to put 'em on a tray and slide the tray toward the inlet... one other guy had the tray "inhaled" and the compressor stall was impressive. The smoke cloud from the burning rice smelled like toasting cereal.
I see that there's a water wash for the CFM56, haven't done it yet.
g'day
AirframeAS
Sun Aug 01, 2004 9:28 pm
At WN we were not allowed to wash the engines at all. For that reason I dont know why. I got into trouble for doing an engine wash, although I was a new hire and didnt know the procedures. I assumed that WN's procedures were similar to AS's procedures since they both fly B737s.
At AS we were required to do a engine wash before going into a check. After the wash the engines were then turned on for an idle speed check.
EMBQA
Sun Aug 01, 2004 9:40 pm
AirframeAS-
Your saying Southwest does not do engine CompWashes at all...?? or the Unions don't let your 'Department' do the washes...?? Say like its reserved for the Engine Shop people...?
AirframeAS
Wed Aug 04, 2004 12:06 am
EMBQA,
All I was told by my lead that engine wash in PHX prior to the A and B checks that it was strictly not allowed. No one would explain to me why. I think that is probably because DAL appearance technicians were the only ones allowed to do engine wash. Honestly, I dont know why although I found it strange. So yeah, I got busted for it, but didnt count against me during my probation...thank god! Whew!
PS....I dont think its a union issue, I think its a departmental issue. Besides, speaking of the union at WN, they sucked. And when I left they then changed unions and now they are represented by AMFA.
northseatiger
Thu Aug 05, 2004 12:54 am
I work on large helicopters that service the oil rigs in the north sea and due to the salt laden atmosphere we wash our engines every night with water, this is done by retarding the engine to ground idle washing for a pre-determined time then drying out at flight idle, Every 50 hrs we do a "Chem" wash wich is venting the engine over and spraying a special fluid into the engine and leaving it to soak for 20 mins then the engine is vented again and water sprayed into to clean out the chemical after that a drying run is carried out. A chem wash may be carried out if the T4 reading is high.
T's And P's look good....Rotate
EMBQA
Thu Aug 05, 2004 10:58 am
AirframeAS-
Well that all sounds strange. I really don't have any experiance with Unions. I was lucky enough never to work for an airline that had one.
TimT
Sat Aug 07, 2004 2:08 pm
During my 10 years at TWA we used to wash every engine we ran in the test cell. Used a 2" hose with a small nozzle and lots of pressure. (don't drop the hose) Ran the engine on the starter for 2 minutes (test cell air is cold so you don't have to worry about cooking it) while hosing it down. Then let it blow itself dry and start. Always got lower EGT's. Everytime.
Hugh3306
Sun Aug 15, 2004 8:06 pm
Thanks for all the info. As TimT states "Always got lower EGT's. Everytime." that is what all my additional research has also found. Most interesting was a comment from a Chief Propulsion Engineer at Boeing: "Every 1 degree improvement in EGT margin equates to 1 month additional on-wing time for an engine." Big bucks when you consider what an overhaul costs! Also, at $1.30 or so a gallon for JetA, a 1/2 to 1% fuel savings for a fleet like WN (400 aircraft) would put about $15 million per year to their (already large) bottom line. It amazes me that any union would be that strong; or an airline as savvy as WN would not be doing periodic engine washes.
Users browsing this forum: iRISH251, jdando, osanco and 1 guest
