SafetyDude
747 Stair "Lock"?
Sun Aug 01, 2004 11:23 am
I remember seeing on "Turbulence" that the FA went to the upper deck stairs and on a panel near the stairs, was able to flick a switch with a key that moved a metal panel that covered the top of the staircase so that no one could go up or down on the stairs.
I am wondering if 747s (-300 and -400, and possibly the SUDs) do actually have this feature and what it is used for.
 Smile
-Will
"She Flew For What We Stand For"
DL_Mech
RE: 747 Stair "Lock"?
Mon Aug 02, 2004 6:17 am
I'm no 747 expert, but there is a "smoke barrier" similar to the "lock" at the top of the stairs on the -300/-400s.
This plane is built to withstand anything... except a bad pilot.
SafetyDude
Mon Aug 02, 2004 6:36 am
That makes sense as to what it is.
Thanks.  Smile
-Will
Msl747
Mon Aug 02, 2004 10:12 am
By "smoke barrier" do you mean like separating the smoking and Non-smoking sections or something else? Is it standard or optional equipment on the -300/-400?
Msl747 Smile/happy/getting dizzy
Commercial Pilot Certificate: Single and Multi-Engine Land; Instrument Airplane
SafetyDude
Mon Aug 02, 2004 10:42 am
What I am talking about (and I believe the first reply as well) is at the top of the stairs that separate the main cabin from the upper deck, and I would presume that it is standard.
 Smile
-Will
Msl747
Mon Aug 02, 2004 11:00 am
So what purpose does a stair lock serve? Why would it be needed? Just wondering...
-Msl747 Smile/happy/getting dizzy
SafetyDude
Mon Aug 02, 2004 11:42 am
Judging from the earlier post, in the event that there is smoke somewhere on the aircraft, that lock can be applied that would prevent smoke from going between levels, although I wonder what would be done regarding the oxygen circulation as smoke could travel through it.
Does anyone have any operating procedures on the lock?
 Smile
-Will
lorm
Wed Aug 04, 2004 4:53 pm
Went digging around in the closet for some old F/A handbook pages about the 747 smoke barrier since I've seen it deployed once in a 747-200 a long time ago, at a gate as MX were doing a check on stuff after an overhaul. The smoke barrier is a deployable screen almost parachute like in material that is deployed to prevent smoke from the lower deck from entering the cockpit area. In the earlier 100/200 series with the spiral staircase they looked almost like an umbrella when deployed. 300/400 series they deploy over the top railing of the staircase. Although how effective they are in preventing smoke from traveling up the stairs is anyone's guess....
-Mike
Brick Windows
747Teach
Wed Aug 04, 2004 11:22 pm
SafetyDude: Lorm's got it. Most of the 747's have some sort of fabric barrier device at the top of the stairs to keep smoke out of the upper deck. Nothing in any reference I have for any "metal panel" (except for the stair door on the freighters) on a 747 that could block the stairs. Early 747's had a dumbwaiter to the left of the spiral stairs so the attendants in the forward main deck galley could move the meal trays up to the upper deck galley without carrying them up that tiny spiral staircase. When in use, it projected down from the ceiling in the main deck galley. Once loaded, it could be run up. On the upper deck, it came up out of the floor between the staircase and the upper deck galley. When stowed, a metal panel closed to cover the floor in the aisle. There was a switch on both decks that could run the lift up, down, and turn it on and off, if memory serves. That's the closest thing I can think of that resembles what you saw. Regards,
SafetyDude
Thu Aug 05, 2004 12:14 am
Thanks for all your replies. What I saw in the movie was definitely metal and hard, so I imagine that Hollywood has been designing planes.  Big grin
-Will
