stall
Uncontained Engine Failure / Explosion
Thu Aug 12, 2004 11:47 pm
Hello !
A couple of days ago a Swiss Avroliner had an uncontained engine failure. The first engine damaged the engine next to it and both engines had to be shut down . The problem took place at cruise altitude and cruise speed and the crew carried out an emergency landing without further problems.
I can't help to think that the outcome could have been worse if the uncontained engine failure had happened during t/o or initial climb. Can this aircraft (or any 4 engines aircraft) take off and climb at low speed with too inoperative engine on the same side ?
I thought that the engines were designed in a way that an explosion would not damage an other engine or the aircraft fuselage. Is it correct ?
Flying is fun
RE: Uncontained Engine Failure / Explosion
Thu Aug 12, 2004 11:51 pm
IIRC there was a thread about this a while ago, or at least it touched on the subject.
Something about four holers being able to climb (barely) with two engines inop, or at least one of the members said the A340 could do this (since the whole thing had also inevitably touched on the A340 being a slow climber). I do not know if it is a regulatory requirement.
Engines are designed to contain any fan, compressor or turbine blades that detach (and the resultant imbalances) within the cowling. This is tested thoroughly. Doesn't always work though.
But maybe APUs are not tested in such a way, which might explain the Avro Big grin
phollingsworth
Fri Aug 13, 2004 12:34 am
Two engine INOP rates of climb are very much dependent on loading and conditions. However, I doubt a MTOW A340 or B747 will achieve much of a positive rate of climb with say the number 1&2 or 2&3 engines out. Part of the problem is the resulting T/W is quite low, around 0.12, and the asymmetries are worse than twins with one engine out. There was the El-Al freighter that had both engines on one wing separate on climb out, it crashed into an apartment complex. At least if you physically loose and engine, vs. shutting it down, you don't have to worry about all of the drag they produce. Of course the more energy that is in the aircraft when the engines are lost the better. On the runway above V1 is the worst case scenario.
HaveBlue
Fri Aug 13, 2004 1:22 am
There was Delta Flight 916, an MD-88 at Pensacola on July 7, '96 that had an uncontained engine failure on the starboard engine and killed 2 of the passengers in the cabin.
Here Here for Severe Clear!
Fri Aug 13, 2004 1:57 am
True, but it might well trash part of the wing while leaving, and you would have to be quick to react to the sudden imbalance.
SlamClick
Fri Aug 13, 2004 2:52 am
PSA also had an uncontained failure back in the 1980s with the BAe-146. The newspaper reported that it put schrapnel in passengers' luggage in the overhead bins. Major bad scoobies!
I once saw the aftermath of an uncontained multiple-disk rupture on a CFM-56 mounted at number one position on a UA DC-8-73. It occurred at or near top of climb and the plane made an emergency landing at Reno Nevada.
The first stage fan stayed attached only because the inlet anti-ice ducts were strong enough to hold the intake ring cowl on. Aft of that, you could have crawled in the left side of the engine and out the right side. About a foot of it was completely missing.
Well, not entirely missing. Parts of it had peppered the left side of the fuselage and some of it had blown forward and been ingested by the number two engine. It got down safely. I don't know if the crew shut down number two or not. Well done to the crew and to the airframe manufacturer. It is also good fortune that it had not happened at number 2 or 3 position!
Thing I dislike most about non-revving is that they so often seat you in the turbine disintegration zone.
Fri Aug 13, 2004 3:09 am
I wonder why they don't call it that in the seat map  Big grin
That's just like sitting you in line with the prop on a prop.
But the question remains: Shouldn't the failure be contained? Why is it sometimes (often?) not contained?
And while we're on that, what happens if a prop blade on a prop plane detaches?
SlamClick
Fri Aug 13, 2004 5:15 am
Yeah, sitting in the plane of the prop is another favorite. If you look at some older prop aircraft you will see big dents where they've slung ice. A separated prop blade goes where ever it wants until its energy is spent.
I think it was North Central that had a CV-580 hit some deer on landing in upper Michigan some years back. One blade went through between cabin and flight deck IIRC.
And don't get me started on helicopters! Never watch a helicopter, you'll become a witness!
I learned my lesson in the sawmill just before I took my first flying lessons. We had a 79" circular "cutoff" saw where all logs entering the mill were cut to eight foot lengths. (We cut only studs.) One day the motor burned out and they found another electric motor on the scrap heap. No one gave any thought to direction of rotation when they wired it. When they threw the switch the saw spooled right up backwards and of course, the arbor nut spun right off! We had a huge saw wobbling on a very short arbor shaft.
Some hero reached in and shut off the switch. I did a more sensible thing. I ran like hell 90 degrees to the plane of rotation!
tbanger
Fri Aug 13, 2004 5:16 am
If one blade detaches from the hub in flight, the imbalance and vibration would be so severe that the aircraft would disintegrate very very quickly. If you are lucky, the other blades would quickly depart also, leaving you with a screaming overspeeding engine to worry about.
Propellers are often balanced in Mx to improve pax comfort and reduce engine isolator wear and tear. It can take just a few grams to imbalance a prop.
aogdesk
Fri Aug 13, 2004 6:07 am
I don't know of all the measures that are taken in the design of an airframe/engine combo to contain the shrapnel, but the 757 has areas called 'dry bays' which are located inboard of the engine pylon. They would normally be wet fuel tanks, but in that particular area, they are dry just in case a disk decides to carve some leading edge metal on its departure from the a/c. Fuel + an uncontained failure = a hair raising experience.
Slamclick, I realize your saw predicament probably wasn't funny when it was happening, but its a priceless image in my head now.... Smile/happy/getting dizzy
Fri Aug 13, 2004 6:11 am
So what if the prop strikes a bird or a deer (as mentioned by SlamClick) or some hail?
Wouldn't some of this happen on a turbofan too? Granted the imbalance would be much smaller, but severe are the vibrations?
Spitfire
Fri Aug 13, 2004 7:27 am
That's why the pilots are trained AND paid for....react VERY quickly!!
Rdgs
Spitfire
Sabena ... Never to be forgotten (15 years already , what a shame !! )
phollingsworth
Fri Aug 13, 2004 7:30 am
Well the blade separating happened to and ASA Brasilia back in 1995 or so. The plane did not disintegrate; however, they were unable to continue flying it and the plane did crash, with fatalities.
As for TFs, the wing/pylon is supposed to be designed for this. In some older a/c the whole pylon was supposed to separate. This is now considered a bad idea, dropping engines in peoples yards is frowned upon. For some of the really big engines the thrust bearing will actually disintegrate, on purpose, saving the airframe while destroying the rest of the engine.
N243NW
Fri Aug 13, 2004 7:35 am
Although not directly related to the question, this reminds me of an incident that occurred to a Saab 340. A bird struck the nose of the aircraft just below the windscreen, which in turn broke the captain's wiper blade off the windshield wiper. The blade struck the prop of the #1 engine, which launched it through the left side of the passenger cabin, impaling a passenger in the leg. Talk about sitting in the "turbine disintegration zone!"
-N243NW Big grin
Fri Aug 13, 2004 7:50 am
Those pesky birds!!! I can just see them, circling above me, waiting to strike!
EDIT: I will conclude that planes do not disintegrate if a prop blade leaves.
[Edited 2004-08-13 00:52:21]
EMBQA
Fri Aug 13, 2004 8:48 am
N243NW-
We worked on that Saab here in Nashville. Boy what a mess..... Let alone the wiper arm being turned into a spear...the other birds the aircraft hit where then thrown into the now hole in the aircraft and entered the cabin, ingested into the engine adding to the smell and mess.
greasespot
Fri Aug 13, 2004 9:22 am
It is more than a few grams. You can Blend up to about a inch of the tip of a C1 disk blade(going from memory) and leave it in service. As from props there can be some significant damage that can be blended out. It all depends on where it is. Near the tip lots...Near root very little. It is not because of balancing but because the root is the highest stress area.
I have a blade from a uncontained JT8D-15 failure on my desk. It nearly shook the Engine off the mount. The whole pylon had to be replaced and the fuselage area beefed up. It was on a freighter and on climb at 1500 feet at max weight.
Greasespot
[Edited 2004-08-13 02:22:32]
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
SlamClick
Fri Aug 13, 2004 10:00 am
Thought about some more related items.
A few years ago I had the ice ingestion incident with a DC-9. Did not see it on the walkaround, not even looking out the cabin windows at the upper surface of the wing. Still a sheet of ice detached on rotation on the next flight and went through both engines. There were 30 C1 blades in each engine. 29 of the 60 needed replacement. One was torn nearly halfway, chordwise. None of the downstream stators or blades were damaged. I think we were very lucky. The surprising thing was that it was very smooth and for the whole flight we thought we'd blown a tire!
I know of a case where a nose locker came open in flight on a cabin-class twin and a pair of skis fell out and went through the prop. It took off a prop blade, which unbalanced the engine to the point where it broke the engine mount and it came off and took a horizontal stab with it. Very bad.
I saw a formula one race plane throw about half a blade at high speed. The vibration must have been pretty bad. The pilot pulled the power off and the nose up sharply. I assume he was trying to load up the prop and stop its rotation. The plane stalled, fell off on the right wing and he recovered flying straight at the bleachers. He pulled up again, stalled again and this time dove straight into the ground a little ways behind the crowd.
In 1976 Mercer Airlines lost a DC-6 (N901MA) in a bizarre chain of circumstances that began with throwing a prop blade on runway 16 at Burbank and ended on a golf course on the Sepulveda flood control basin near Van Nuys. Google this one, it makes fascinating reading and really illustrates the oft-stated truth that one single event does not cause the crash.
We don't pay much attention to these things because they so rarely malfunction, but anything that spins that fast has a lot of potential to do damage. Preflight carefully.
Fri Aug 13, 2004 11:49 am
SlamClick, if you had that thing on the DC-9 you must have heard of the SAS MD-80 which "landed" on a field in Gottröra after taking off from ARN/ESSA. Ice sheets came off both wings and frelled both engines. Oops... Deicing checks were changed after that. The tech has to put a bare hand on the wing, not just check visually.
Spitfire
Fri Aug 13, 2004 3:39 pm
"...The tech has to put a bare hand on the wing, not just check visually..."
Very nice indeed....but how to make that on a 747,340,...and A380 in the near future ???
Klaus
Spitfire
Fri Aug 13, 2004 8:33 pm
Spitfire: Very nice indeed....but how to make that on a 747,340,...and A380 in the near future ???
Maybe it´s less critical because they´ve got wing-mounted engines that can´t be hit by ice detaching from the wing? If I´ve understood that correctly, the problem hadn´t been the aerodynamic change due to the ice but only its ingestion into the tail engines.
Fri Aug 13, 2004 8:43 pm
Exactly as Klaus says. If a sheet of ice comes loose from a 747, 380, or 340 wing it won't be gobbled up by the engines. While the sheet of ice is still "attached" to the wing it's really no big deal. But if they HAD to check it, I'm sure they could use a ladder  Big grin
I suppose ice could hit the stabilizer, but I don't imagine it would do much (or any) damage. We're not talking an iceberg coming loose here, just some chunks.
darkblue
Sat Aug 14, 2004 12:53 am
You can't have a discussion of blade-out scenarios without discussing the GE90. Let's do a quick calculation. A single GE90-115B blade weighs around 50lbs. I'll guess that the center of mass is around 3ft out from the center of rotation. Finally, the fan speed at takeoff is around 2500RPM. The radial force is therefore determined by:
F=m*r*w^2
F=50lbm*3ft*(2500rev/min)^2
After a couple unit conversions I find that the total load due to a single blade is 319,600lbf!
If I can count right, it appears from photos I've seen there are 22 blades in the GE90. This means that the loading on the fan hub at during is over 7 million pounds of force!
Spitfire
Sat Aug 14, 2004 2:49 am
Yes Klaus, ...I was joking a littlebit....sorry. Of course ice problem is more crucial for rear engine A/C.
Spitfire
KDTWflyer
Sat Aug 14, 2004 1:31 pm
Isn't a blade out situation on UA flight 232's number 2 engine the cause for all that trouble? For some reason I found the turbine disintegration zone concept/phrase quite amusing  Nuts.
NW B744 B742 B753 B752 A333 A332 A320 A319 DC10 DC9 ARJ CRJ S340
KDTWflyer
Sat Aug 14, 2004 1:39 pm
Darkblue,
That is an amazing calculation.. How did you find out the RPM level at takeoff? Goes to show why jet engines are so damn expensive not to mention the rare high temp/stress resistant alloys in the high pressure turbine section.
meister808
Sat Aug 14, 2004 2:39 pm
KDTWFlyer:
I believe there was something ingested on a previous flight, leaving a nick on a fan blade. About an hour into the flight the blade sheared off, both clanging around the engine doing damage and throwing the whole thing out of whack, causing it to toss more blades. At this point it became evident that there was a crack in the titanium shroud around the engine that was there to protect for exactly this. The shroud failed and the engine started tossing blades and everything else out. Of course, some of these pieces(I believe there were about 60 significant holes) departed out through the horizontal stabilizer, some of them cutting hydraulic lines. The rest is history.
Straight from the mouth of Al Haynes, by the way.
-Meister
air2gxs
Sat Aug 14, 2004 11:19 pm
The max RPM figures are always available in the maintenance manual. We use those for precision measurements during vibration surveys using a laptop computer. I've never done it, but I hear its impressive.
SlamClick
Sun Aug 15, 2004 10:54 am
Many air museums will have an old turbine engine cut away to show the internal workings. Take a look at the compressors (unless it is a Whittle-type engine) and picture one of those blades at the first stage coming off and traveling downstream. The spaces get tighter and tighter. The havoc it will cause is instantly apparent.
Starlionblue I do remember that SAS event. I'll tell you, it is amazing how hard it is to see that ice. The very next departure I had after my incident, we had it again, but this time we pulled the overwing and went out to look at it. The chunk of ice over the gear well area was nearly two meters square and 30-40mm thick. Standing on the bare metal and pulling at the forward edge of it we could see bubbles of water under it. In other words, it was nearly ready to come off. All it would take is, say to develop a little lift. And there are the hungry engines waiting just behind.
MD11Engineer
Sun Aug 15, 2004 11:15 am
Well, I´ve vboroscoped engines with compressor blade failures. The damage is usualy catastophic. Most of the scrap metal usualy gets blown out of the tail pipe, often enough leaving just an empty pipe where the innards of the engine used to be....
About 6 years ago Channel Express had an accident in Shannon, Ireland (SNN). Apparently a crew of oldtime pilots became complacent and didn´t do check lists anymore. Also, apparently, the landing config warning system gave false alerts, so they pulled the C/B.
The result was that they tried to land their L-188 on the runway without extending the landing gear. They only noticed when the inner props hit the concrete. Then they pushed full throttle and did a go around. #3 engine shedded several prop blades, which went through the cabin (fortunately a freighter). Another prop was so badly damaged, that the vibrations tore the engine off it´s mount and it fell into Shannon industrial estate, right behind the airport fence.
The third engine burnt out. They managed to do a circuit on one engine and landed the plane, this time with landing gear extended.
The plane stood parked beside the Westair hangar for more than a year (I considered buying and repairing it) and got finaly scrapped after everything valuable was removed. The fuselage now serves for training fire fighters on the airport.
Another thing I´ve seen during my apprenticeship in SXF was an Air Berlin B737-400, which lost a fan blade on #1 engine.The blade went through the fan case and got stuck in the outboard side (about 7 o´clock position) of the fan cowl. The pilots noticed bad vibrations and shut down the engine in flight.
The plane got pulled into the LH Technik hangar in SXF for inspection and repair. We had reps of both Boeing and CFM, as well as the German Luftfahrtbundesamt (aviation authority) there taking pictures, and looking for the reason of this damage (at first the considered blue ice, but the lav service panel is on the other side, there was no evidence of a bird strike either). Finaly we removed the engine and sent it to CFM for advanced inspection.
Jan
Hugh3306
Sun Aug 15, 2004 6:06 pm
Very interesting discussion. A little known, but unnervingly common, cause of compressor failure is due to contamination (dirtiness) of the compressor. Just a little bit of fouling from airborne particles (salt, agriculture residue, dust, ash, runway exhaust) can cause severe airflow distortion within the compressor. With the amount of forces and pressures being present in the engine, this distortion overstresses the compressor to the point of failure. A weakened blade could easily detach during this failure.
infiniti757
Mon Aug 16, 2004 8:39 am
Meister808,
The cause of the failure on UA 232 was and intergranular discontinuity in on of the turbine discs. Basically a small defect in the metal which led to a stress riser that caused the whole disc to fracture. If it was just a blade the failure probably could have been contained and the damage would have been less. Instead a titanium disc about 3 feet in diameter and several inches thick broke through the engine housing and tail area, wreaking havoc as it left the airframe.
Since we are talking about failures of spinning parts I think we should look at props too. These are a common cause of accidents in propeller driven aircraft:
  • ASA Flight 529, EMB-120
  • Business Express, Beech 1900
  • Mitsubishi MU-2, Zwingle, IA (this crash killed the governor of South Dakota)
  • Pan Am Boeing 377 Stratocruiser, Carolina Brazil 1955
  • Here is a video of the type of oscillation that occurs, it is called whirl flutter,http://www.airspacemag.com/asm/Web/Site/QT/PWFlutter.html, this video shows structural testing, when a prop fails the flutter is much worse.
    Does anyone know of any similar phenomena in jets?
    Give me the luxuries in life and I will gladly do without the necessities. (Frank Lloyd Wright)
    EMBQA
    Mon Aug 16, 2004 9:35 am
    Since we are talking about failures of spinning parts I think we should look at props too. These are a common cause of accidents in propeller driven aircraft: Business Express, Beech 1900
    The crash of BEX N811BE had nothing to do with a prop failure. The engine mount broke free causing the entire nacelle and engine assembly to depart the aircraft....and in turn it struck and ripped off the RH horizontal stabilizer. This caused the aircraft to loose all control and crashed into Block Island sound with the loss of all 3 crew members.
    infiniti757
    Mon Aug 16, 2004 2:19 pm
    Sorry, reread the report, the prop damaged the tail as the engine left the airplane. Though that the prop lead to the engine leaving the airplane. Embarrassment
    darkblue
    Tue Aug 17, 2004 12:27 am
    Yeah, I guess I should have listed my sources. For the most part I just estimated from the top of my head, but all values I used can be found from GE pages.
    Here's an old GEAE press release that describes a blade-out test and lists the fan speeds used:
    http://www.geae.com/aboutgeae/presscenter/ge90/ge90_19950202c.html
    Here's another GE document that lists the fan blade mass:
    http://www.geae.com/services/information/servicesolutions/pdf/v03i05.pdf
    The last document lists the fan blade length to be around 4ft. If I put the center of mass in the middle of the blade, then using a 10ft diameter fan would mean the center of mass is 3ft from the engine centerline.
    My calculation was only an approximation intended to just give a idea of the magnitude of the force involved.
    BR715-A1-30
    Wed Aug 18, 2004 12:17 am
    Yeah, the scary thing is I flew on this exact aircraft on July 17, 2004 and didn't even know it was the one involved.
    Puhdiddle
    Users browsing this forum: GriN and 1 guest
