Thrust
Benefits Of Various Winglets
Wed Sep 22, 2004 10:15 am
I was just wondering what the differences in benefits are between the following: raked wingtips, wingtip fences, the winglets on the Airbus A330s and A340s, and Boeing's blended winglets. Yes, they are designed to reduce cruise efficiency and allow a slight increase in range, but why not choose all blended winglets? Please tell me the specific benefits of winglets, raked wingtips, winglet fences, etc. I just want to know what each of these is best at, and not good at.
Fly one thing; Fly it well
lmml 14/32
RE: Benefits Of Various Winglets
Wed Sep 22, 2004 4:41 pm
Wed Sep 22, 2004 6:14 pm
The simplest way to put it that one flavor does not suit all planes. For example, you could of course put raked wingtips on the A380, but this would bump the wingspan above 80m, an unacceptable width for the airport.
Reply 15 of this thread gives a good overview:
http://www.airliners.net/discussions/tech_ops/read.main/98566/
MAC100
Fri Oct 15, 2004 12:28 am
Thanks, very helpful!
Thrust
Wed Oct 20, 2004 9:45 am
Thanks for the links guys...cleared things up very well for me.
Brgds,
Thrust
2H4
Sun Oct 24, 2004 12:30 am
Check these out:
Intentionally Left Blank
Thrust
Tue Oct 26, 2004 8:42 am
 Wow!
Is that really aerodynamically possible? That is the craziest winglet design I have ever seen
videns
Tue Oct 26, 2004 3:48 pm
2H4: do you have any more info or a link to go check that out at?
Travel? Why would i travel if I can watch it on TV?
QantasA332
Tue Oct 26, 2004 4:33 pm
They're called "spiroids," and they were pioneered by the engineers at Aviation Partners. I'm not 100% as to whether they can technically be classed in the category of winglets, as the device surfaces may or may not be designed to produce forward lift - thrust - which is the basic determining characteristic of winglets. Rather, they're simply yet another design in the ever-growing group of effective aspect-ratio devices.
At any rate, spiroids sort of operate along the lines of drooped tips. Drooped tips deflect the wingtip vortices away from the wing as they begin to rotate up and around, thus distancing them from, and reducing their effect on, the wings. While spiroids aren't really deflecting the vortices away from the wing, they diffuse the vortices and reduce vortex interaction with the departing airstream. This has the obvious drag-reducing effects, as it limits downwash and accordingly reduces induced drag. On the particular design shown in the pictures above, it was said that the spiroids reduced drag in cruise by as much as 10%.
QantasA332
AUAE
Tue Oct 26, 2004 9:05 pm
Those spiroids remind of the many nights I spent dreaming up how a circular wing could work. I gave up and decided to play computer games instead!
 Smile
Shawn
Air transport is just a glorified bus operation. -Michael O'Leary, Ryanair's chief executive
Thrust
Fri Oct 29, 2004 3:46 pm
Wonder if those spiroids will ever make it onto a giant jetliner. That would be very interesting.
QantasA332
Fri Oct 29, 2004 4:10 pm
I'm guessing that due to their relatively complicated nature, high production costs will rule out any commercial applications in the near future...
QantasA332
justplanesmart
Fri Oct 29, 2004 6:26 pm
I would have thought a better name would be "ringlets."  Smile
"So many planes; so little time..."
Santhosh
Fri Oct 29, 2004 8:21 pm
Are all Winglets manufactured by NASA or individual Companies manufacture there own Winglets?
George
Happy Landings :)
lehpron
Sat Oct 30, 2004 8:30 am
You know, a forward swept wing could kill off all of the induced drag simply becuase the induced flow would be going inwards instead of outwards, the vortex has NO interaction with the wing, if anything it will enhance the lift features by sucking down the back of the fuselage. You can cut the drag by up to 29%! The difficulty comes from its loading, most happens at the tips and not the roots.
With winglets, to be perfectly honest (and I will get slamed for this) I see them all as functionally the same. Their names and shapes almost don't matter to me. But some people/customers are asthetically obcessive apart from justifying the costs/weight.
From what I can tell, there are currently two different kinds, one decreases the rotation of the induced vortex itself and the other is actually a micro delta surface that spins its own vortex as it trys to produce lift and the main induced flow gets caught up in it reducing the size of the whole.
The first is either vertical or curved up and might be for allowing closer separation of large planes. The latter is usually parallel with the wing and may reduce the impact of the vortex on the plane's wing downstream, as QantasA332 stated, the " they diffuse the vortices and reduce vortex interaction with the departing airstream".
I think another can be designed within the next few decades, one where it severely disturbs the rotation of a vortex, killing it's effect on anything. The only way I can think of is to mix the rotating flow in one direction with the other direction; it should cancel out. I guess this would be curved down or going in an inverted ringlet arraingment...just an idea...that I thought of a long time ago but since subsonics weren't my thing then, well... Laugh out loud
Sun Oct 31, 2004 5:03 am
As Lephron says, forward swept wings are a great idea aerodynamically.
Structurally is another story. They tend to twist from the outside in (wingtips go up), which makes for rather nasty forces.
They look cool though Big grin
57AZ
Winglet Manufacturers
Wed Nov 03, 2004 3:21 pm
In answer to Santhosh's question, winglets are manufactured by private aerospace companies. NASA has performed a significant amount of research on airfoil designs, including winglets and forward swept wings. In the United States. the two largest manufacturers of winglet mod packages are probably Aviation Partners and Riley Aircraft Modifications (RAM). As winglets require modification to the airframe, modifications have to be approved by the Federal Aviation Administration for each different aircraft model. Due to the costs involved, very few aircraft are modified with winglets. Our airplane, a 1981 Cessna 414A is one of only a few high performance piston twins to have the RAM winglets added. Its not a full RAM modified aircraft as it does not have the liquid cooled engines. Most winglets that appear on corporate jets are designed as an integral part of the airframe and are either manfactured by the aircraft builder or a factory installed modification provided by an outside supplier such as Aviation Partners or RAM.
"When a man runs on railroads over half of his lifetime he is fit for nothing else-and at times he don't know that."
Thrust
Tue Nov 23, 2004 3:38 pm
it's funny how we see more winglets on smaller jets than on bigger jets.
Tue Nov 23, 2004 9:48 pm
Indeed. Lower development cost?
Users browsing this forum: E2, glen, retiredmx and 1 guest
