a380900
A380, Why Such A Small Nose Wheel?
Sun Sep 26, 2004 2:14 pm
How come the A380 has only two wheels in the front?
VC-10
RE: A380, Why Such A Small Nose Wheel?
Sun Sep 26, 2004 10:18 pm
How would you steer a bogie in a sharp turn?
Most of an a/c's weight is designed to be around the C of G & C of L
Sun Sep 26, 2004 11:12 pm
Most of the weight is on the body and wing gear. Making the nose gear more complex brings with it a host of problems. As VC-10 says, how would you steer a bogie or a double set of nose wheels in a sharp turn. There would be lots of scrubbing.
I think you will also find those wheels aren't really small  Big grin
G4Doc2004
Mon Sep 27, 2004 2:53 am
As the size of the gear/bogie assembly increases, so does the weight of the assembly and the area required to store it in flight. Not to mention a larger actuator to push it in the well. And, as Starlionblue stated so eloquently, those wheels are bigger than they look!
"Failure to prepare is preparing to fail"--Benjamin Franklin
Buyantukhaa
Mon Sep 27, 2004 8:38 pm
It would be possible to avoid the scrubbing by putting four wheels on one axle. That would be terribly unpractical however, it would be too wide to fit, or would have to rotate 90 degrees, and as already mentioned it would be too heavy. So I guess the current solution is the most sensible one (just don't land with the nose gear first).
I scratch my head, therefore I am.
sovietjet
Tue Sep 28, 2004 6:24 am
It's possible to steer it. Just design it like an An-124. Never heard of them having problems steering.
Airbus Lover
Tue Sep 28, 2004 6:37 am
Why? Because they don't need it?  Nuts They find that the turning radius is acceptable and in line with airport facility compatibility.
I am not familiar with AN124 ops but could the AN124 require more turning circle than other a/c of similar size? Not sure, just guessing.
studentflyer
Tue Sep 28, 2004 12:13 pm
The AN124 and AN225 requires twin bogie at the nose probably because of the nose door of the aircraft -> maybe to withstand cargo loads during loading... The Airbus, well at least for the pax variant, does not have cargo doors. The F version is just a derivative of the pax version, so it would be impractical to give it 2 bogies, whereas the ANs are designed specifically for cargo ops, so it would just be viable to be fitted. That's my shot anyway.
And for turning, they shouldn't really have any effect, because both bogies turn simultaneously anyway... (but correct me if I'm wrong)...
AK
lehpron
Tue Sep 28, 2004 12:43 pm
>> "That would be terribly unpractical however, it would be too wide to fit, or would have to rotate 90 degrees, and as already mentioned it would be too heavy." <<
So the 4-wheel single-axile nose gear of a C-5a Galaxy probably wouldn't work despite the plane having existed since before the 747? I think it was ironic Boeing lost the contract that Lockheed won.
To answer the question, I donno, though I do have an earlier gif that clearly shows initial concepts of the A3XX with a 4 wheel nose gear like the Galaxy. I suppose there would be less load farther from the Center of Gravity.
IL76TD
Wed Sep 29, 2004 6:10 pm
The Russian cargo planes were designed with 4 wheel nose axles to decrease per wheel loads and increase the ability of the planes to operate from dirt, sand, or underdeveloped runways (with 4 wheels the nose loads better match the loads of the 16 rear tires on the IL76). No western plane has yet to match this ability to the extent of the ex mil russian freighters.
Our IL76's can turn on themselves (zero turning radius) so no, it does not affect that either.
tbanger
Wed Sep 29, 2004 7:36 pm
SMALL????????
There is a dude bending over in this photo and the top of the tyre comes up past his waist line
Photo © French Frogs AirSlides
Champion, that wheel is huuuuuuuuge!  Nuts
Wed Sep 29, 2004 10:32 pm
True that no western plane can do this, but the A380 will not operate from dirt strips. And so the advantages of adding an extra two nosewheels on the flying slug would be eaten up by the extra complexity, weight and width of the nose gear well and mechanism.
IL76TD
Thu Sep 30, 2004 9:22 pm
yea i wasn't saying that the A380 needed it, I was agreeing that it doesn't, and that the reason for additional nosewheels was not due to the planes static load on the mechanism, rather the ability to perform specialized operations requiring them
nosewheels generally have little load from the plane, planes are normally balanced evenly, which is why on many planes engine removal requires the nose to be tied down, assuming the weight of the engines was forward the center of gravity
Thrust
Sat Oct 02, 2004 10:41 am
The A380 in that photo looks so stubby from the front....it's hard to believe that the A380 is bigger than the 747  Wow!
Fly one thing; Fly it well
IL76TD
Sat Oct 02, 2004 3:07 pm
I agree, they do look stubby, i think they should have had a 747 style upper deck cockpit. The lower deck cockpit position makes the front look all droopy
Sun Oct 03, 2004 3:05 am
The 747 has the cockpit all the way up on the upper deck because they had to provide clearance for cargo, with or without a nose door. The 747 was meant to be a cargo plane as soon as the SSTs came into service in the late 70s. This never happened, but the cockpit remained up there.
The A380 has the cockpit in a position which has a couple of advantages over the 747:
- Aerodynamically I am not an expert, but I get the feeling the 747 has a pretty blunt nose and the 380 cleaves the air better.
- The cockpit area can be completely isolated from the rest of the aircraft, with it's own staircase from the entrance. On the 747 you have to walk through the upper deck. Security.
- More efficient layout of the double staircase to the upper deck.
- Less height above the ground for the pilots, enabling easier transition from 330/340.
lehpron
Mon Oct 04, 2004 9:26 am
>> "Aerodynamically I am not an expert, but I get the feeling the 747 has a pretty blunt nose and the 380 cleaves the air better." <<
Niether am i, but i heard that it had something to do with the cocpit bulge as a whole created more drag than as if it were smooth. The A380's nose now looks kind of like 7E7/787, just scaled up.
Users browsing this forum: Starlionblue and 1 guest
