videns
Flight Surface Authority
Sun Oct 03, 2004 2:33 pm
What are the speeds at which flight surfaces start having an effect on an aircraft?
eg: when an airplane is taxiing, none of the flight surfaces have any effect on what the airplane does...
Any flight surface/aircraft combination info appreciated...
Travel? Why would i travel if I can watch it on TV?
Woodreau
RE: Flight Surface Authority
Sun Oct 03, 2004 3:57 pm
I think it depends on the airfoil design.
There are gliders when sitting on the ground, hooked up for aerotow, the ailerons are fully effective and can be used to keep it upright when a good 5-10kt breeze blows across wings.
wilco737
Sun Oct 03, 2004 7:18 pm
hi Videns,
during take off roll u use the rudder pedals to keep the aircraft on the centerline. This happens because the nose wheel is connected to the rudder pedals and you have a steering angle of about 3.5° in each direction! At about 60-80 kts the rudder on the tail is effective that you can hold the aircraft on the centerline only with the aerodynamic forces of the rudder! So, you can say at about 60-80 kts the filght controls become effective...
WILCO737
FredT
Mon Oct 04, 2004 3:35 am
They don't become effective at one defined airspeed. They are effective in proportion to the dynamic pressure, which is proportional to the airspeed squared. At a very small airspeed, they are effective but perhaps not effective enough to control the aircraft, depending on what you do. At twice that airspeed, they are four times as effective... which might just be enough.
It is like asking "at which temperature does cold water turn into warm water". There's no answer as it all depends on what you are trying to use it for!
Fred
Users browsing this forum: george77300, jetmechanicdave, Rookie87 and 1 guest
