USAirwaysCLT
CFM56-7B24 Fuel Flow Rate
Wed Nov 17, 2004 10:48 am
Hi:
I have been looking for engine specifications for different engines and I find most of the information, but the one thing I cannot find is the fuel flow rate.
Can any of you engine techs tell me the fuel flow rate in LBS/Hr or Kgs/Hr for the following engines?
CFM56-3B1 @ 20,000lbs thrust (B737-300)
CFM56-7B24 @ 24,200lbs thrust (B737-700)
Thanks so much
swadispatcher
RE: CFM56-7B24 Fuel Flow Rate
Wed Nov 17, 2004 12:48 pm
Are you looking for FF rate in climb, cruise or descent?
Maintain 2300 until Boiler, cleared for the VOR-A approach, report BATLE inbound..
USAirwaysCLT
Wed Nov 17, 2004 10:27 pm
Sorry about that, I guess knowing which would help
What I'm looking for is the FF rate for: 1 engine, at sea-level, standard temperature and pressure. In other words, manufactures specs. I found some for the CFM56-7B20-see below for an example-but not the -7B24.
Engines: CFM56-7B20
Stabilized Idle Indications, ISA conditions, Sea Level, CFM56-7
N1 RPM - 20%
N2 RPM - 59%
EGT - 410°C **
Fuel Flow - 272 kg/hour
** Idle EGT may vary from 320°C - 520°C depending on OAT, bleed configuration and engine
condition.
Users browsing this forum: gunsontheroof and 1 guest
