ba97
Concorde Engine/wing Gap
Wed Nov 17, 2004 11:48 am
I notice on pictures of Concorde that there is a gap along the front half of the engine where it meets the wing. I would have thought the surfaces would have to be smooth and joints sealed. I can't think of seeing similar spaces on other planes. Is there a purpose for this?
Photo © Paul Markman
there is economy class, business class, first class...then Concorde..pure class
XXXX10
RE: Concorde Engine/wing Gap
Wed Nov 17, 2004 5:37 pm
If you are referring to the black strip above the intakes I don't think that is a gap,
FredT
Wed Nov 17, 2004 6:17 pm
Close to the surface of an aircraft is a layer where the air has been slowed down by friction. This is called the boundary layer. It is turbulent and not at all what you want to feed your engines. When it does get sucked into the engine intakes, it is called boundary layer ingestion, and is something you try to avoid. To avoid it, you make sure to have the lip of the engine intake some distance away from the skin of the aircraft. There’s a wedge shape in there to steer the air out to the sides.
Take a look at military aircraft, e g the Saab 39 Gripen or the F-16, and you will see similar features on the intakes.
Fred
ba97
Thu Nov 18, 2004 1:35 am
Thanks. Fred. In the photo you see the thin black gap along the side and makes me thing someone needed a spanner or something to tighten a few screws....
Users browsing this forum: Arch89U, Google Adsense [Bot] and 1 guest
