jfidler
Typical Cargo Hold Temperature
Sun Dec 12, 2004 3:54 am
What is the typical temperature in the cargo hold, specifically the area where they put your luggage? The reason I ask is I'm flying on SK from CPH-IAD this week, and I was planning on taking some perishable food items in my luggage. I'm trying to figure out how much I should insulate them for the flight -- is it already reasonably cold in the cargo hold?
Santhosh
RE: Typical Cargo Hold Temperature
Sun Dec 12, 2004 4:12 am
Jfidler! Out of the cockpit videos which I have seen the temperatures in the cargo bay are generally from 25 to 28. May be because pilots know that some people might carry food items which might be perishable if kept in high temperatures. Well the pilots can set different temperatures at different sections of the cargo bay depending upon the type of cargo they carry. Anyway wish you a happy journey to IAD.
Best Wishes,
George
Happy Landings :)
air2gxs
Sun Dec 12, 2004 5:17 am
B767 - The lower pits are maintained around 50 deg F.
B757 - Between 50 deg F and 70 deg F.
A300 - Between 2 deg C and 26 C.
Of course this is on our cargo aircraft, but i would guess its about the same.
patroni
Sun Dec 12, 2004 11:05 am
Tere Jfidler,
I can't answer your question for passenger aircraft.
However be careful regarding import of food into the US. As far as I know it is not allowed to take any agricultural or meat products etc into the US. They check this quite thoroughly, so maybe you would want to clarify before risking to have your food items confiscated at customs plus being fined.
Thomas
PPGMD
Sun Dec 12, 2004 11:28 am
Actually checked food items are if not prohibited, highly discouraged because many have the same constancy as plastic explosives.
At worst, you screw up and die.
ContinentalFan
Sun Dec 12, 2004 11:38 am
Generally, I think that if it's in a can or jar or other sealed packaging it's ok. My aunt and uncle went to Japan earlier in the year and brought back tons of Japanese snacks, all neatly packaged in typical Japanese fashion, no hassles.
Sun Dec 12, 2004 6:35 pm
The B737 Fwd cargo hold is used to carry perishables which is at a higher temp than the Aft hold due to Exhausted heated air that passes through the E&E compartment used to cool the equipment present there.
regds
MEL
Users browsing this forum: DL777200LR, simfanatic and 2 guests
