ktachiya
Snow Tires On Ac's?
Sat Dec 18, 2004 6:01 pm
Just like a car, do ac's also have special tires? I mean for extreme conditions (using YYZ or YUL) come to mind. But like a car, if you use a snow tire the whole year round, the tire will wear out. So I was wondering what ac tires are like and how frequently they get replaced. I can find a lot of information about landing gears, but never specifically about tires.
Can someone help me?
ktachiya
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
Treg
RE: Snow Tires On Ac's?
Sat Dec 18, 2004 7:14 pm
Latest news from Michelin: NordicFrost 1500 with studs. Fits well on your latest 747-400....
Sorry, couldn't resist!  Big thumbs up
SlamClick
Sat Dec 18, 2004 11:54 pm
Remember that planes do not get traction from their tires, they just roll on them and use them for braking. The "tread" requirement would not be like automotive tires at all.
I've only ever seen one set of "ice tires" for a DeHavilland Beaver. They had the tread rubber impregnated with short pieces of very fine wire. I don't know how well they worked since we never mounted them. They would shred your hand if you brushed it over the tread.
longhauler
Sun Dec 19, 2004 12:31 am
Taxiing around YYZ or YUL is not much different than taxiing around NRT, (I have done both). Snow or ice is very rarely left on taxiways or runways, and if it is, it is removed as quickly as possible.
Using charts for takeoff or landing on snow covered runways (rare but happens at YYZ), is not much different than using the same charts for landing on a lot of standing water (rare but happens at NRT).
When a winter storm arrives in YYZ, (a few times a winter) things slow down, as usually only half the facilities are available. The other half is being cleaned so we WONT have to land or taxi on snow/ice covered surfaces.
jetstar
Sun Dec 19, 2004 1:45 am
Back in my military days, my unit operated Boeing C-97's and they all had main tires embedded with pieces of fine wire. This was for braking traction on slippery runways.
These tires all had the standard grooves for water dispersal to prevent hydroplaneing.
These tires were all recapped so the metal pieces was added during the recapping process.
As stated above if you pressed you hand against the surface of the tire you would have numerous punctures in your hand.
Changing tires was no problem because we used a wheeled tire cradle to install the tire assembly on to the aircraft and also wore heavy gloves.
Ralgha
Sun Dec 19, 2004 2:39 am
I've got a studded snow prop for my 152. When it really gets bad I put prop chains on.
 Big thumbs up
SlamClick
Sun Dec 19, 2004 2:52 am
Photo © Dariusz Jezewski
Airplane snow tires.
Contact_tower
Sun Dec 19, 2004 3:44 am
No need for snow tires, and there is a need to taxi/take off on snow/ice.
Complete removal is not possible if the temprature is below the working range of the chemical systems.
This is an example of how good it's possible to get it in certain arctic conditions.
Photo © Anders Forseth
OPNLguy
Sun Dec 19, 2004 5:43 am
SlamClick brings up a good point, and one that some folks (including some of those in the media) forget, i.e. taking automotive analogies too far...
I was with Air Florida when we lost the 737 at DCA back in 1982, and one TV station immediately aired their "the cause" of the crash as there being so much snow/ice on the runway that Palm 90 couldn't get any traction for takeoff. I mean, it's not like tires with studs or chains would have helped, since there's no driveshaft from the engines to the wheels...  Insane
In winter (airline) ops, top-notch snow removal works better than any theoretical special tires...
Ralgha
Sun Dec 19, 2004 6:04 am
Well, studs would have helped steering traction (directional control). I don't know what the situation of was in the crash, so it may not have helped anyway.
LeanOfPeak
Sun Dec 19, 2004 6:58 am
According to the accident report, the aircraft was still on the runway when it took off. However, the airframe was iced up and at least one engine was not developing full power.
It had nothing to do with traction.
spencer
Sun Dec 19, 2004 7:02 am
I read somewhere once that most aircraft tyres are retreads, and rarely are brand new ones used. However, I am in no position to say whether this be true or not, it's just something I read, in Flight if memory serves me well.
Spencer.
longhauler
Sun Dec 19, 2004 7:13 am
Yes, that is true, a lot of airlines use retreads. But for the record, they are not bargain basement tires, and (at my company anyway) it is procedure to x-ray all retread tires before use.
We lost a DC-9 at YYZ many years ago due to the delamination of a retread tire, thus the start of the x-ray rule.
JetRanger2000
Tire X-Ray?
Sun Dec 19, 2004 1:07 pm
What do you do, take the tires to the TSA checkpoint at the airport and run them through the baggage scanner?  Smile
Venus6971
Mon Dec 20, 2004 4:16 pm
I keep getting this image of George Kennedy in the movie airport taxing a stuck 707 in the snow. Put your trust in thrust and pray there is no ice under you.
I would help you but it is not in the contract
KAVL
Mon Dec 20, 2004 6:30 pm
OK, I have a related question
On takeoff roll, traction is not important,
but when landing on snow covered runways, if they
are allowed to get that way in the first place, how does
an airplane brake without sliding all over the runway?
 Smokin cool
[Edited 2004-12-20 10:35:13]
Once you have tasted flight, you will walk with your eyes turned skyward, for it is there you long to return - da Vinci
Mon Dec 20, 2004 10:17 pm
Calculations change. The required runway lenght is much greater. Even on slippery runways there is some traction. Anti-lock brakes help. You can brake to the max AND steer at the same time. Also above 80 knots or so the rudder still works.
Arrow
Tue Dec 21, 2004 2:14 am
A common misconception about auto snow/ice tires is that they are needed just for motive traction (and therefore useless on an aircraft). But braking and directional control are far more important -- that's why they recommend putting snows on all 4 wheels now, even on 2WD cars. Four wheel drive maniacs get a nasty surprise when they get their SUV's up to a high rate of speed on a snowy road and then spin into the ditch because they haven't grasped elementary physics.
The best brakes in the world are useless if there's no "traction" where the rubber meets the snow covered road, and while I'm in no way knowledgable about aircraft tires, I'd bet the aircraft would benefit from a different tread pattern/rubber compound for snow/ice conditions.
[Edited 2004-12-20 18:24:20]
Never let the facts get in the way of a good story.
Users browsing this forum: Apprentice and 1 guest
