MADtoCAE
Altitude Question
Mon Dec 20, 2004 4:48 am
Good day,
I live at 20 Km from MAD,I was wondering,at what altitude are the airplanes that far out of the airport?
I know there won-t be an exact altitude, since MD-80's are higher than a A340.I want an aproximation(i.e 3000-6000 ft)
Operator!!! Give me the number for 911!!
RightWayUp
RE: Altitude Question
Mon Dec 20, 2004 6:05 am
It depends where you are in relationship to the airport, and which runway they are using. In general they use r/w 33.
If you are to the north, then can be usually you will be in the region of 12,000-14000 ft.
If you are to the south you could be anything from 4-7000 ft. It can vary greatly depending on if you do the complete arrival or whether you get more direct radar vectors.
MADtoCAE
Mon Dec 20, 2004 6:40 am
Thank you.
Where I live I allways see planes climbing.For take off they usually use runway 36L and when they are in the air the turn left.Can you give me an altitude now?
timz
RE: Altitude
Mon Dec 20, 2004 7:49 am
If the aircraft have to fly 20 km to reach you, then they'll pass you maybe three minutes after takeoff? I'm guessing 2500-3000 ft per minute is a typical rate of climb for not-too-heavy departures-- so they'll be around 8000 ft above airport elevation, if they've been climbing the whole time.
If they're right overhead, compare their size with the moon or the sun, which are maybe 110 times as far away as their diameter. So if an MD80's length equals the sun/moon's diameter (and you're looking at it at 90 degrees) then its 5 km away-- and so on.
MADtoCAE
Tue Dec 21, 2004 1:12 am
Thank you very much!!
DColeMAN
Tue Dec 21, 2004 9:30 am
I live approx 20 miles out from MAN airport. I see departures (from 06L) over my house usually between 5000-8000ft. Although 24R arrivals (which we usually see over here) are between 2000-4000ft.
Hope that helps a little.
Dale
Topless Women Drink 4 Free
Newark777
Tue Dec 21, 2004 10:29 am
I live about 20 miles west of EWR, and the planes that are departing that fly over my house are usually in the 10000 to 12000 feet range. I get mostly approach aircraft, though, and they are all usually at around 5000 feet when they go over my house.
Harry
timz
Wed Dec 22, 2004 8:55 am
"I live approx 20 miles out from MAN airport. I see departures (from 06L) over my house usually between 5000-8000ft."
If that's true they must be restricted by ATC. I'm 16 nm NNE of SFO and the 1R domestic departures are almost always 8000 ft and higher.
(That's not just a guess-- they usually switch from Departure to Center about the time they pass me, and they announce their altitude to the Center controller.)
[Edited 2004-12-22 00:57:26]
DColeMAN
Wed Dec 22, 2004 9:40 am
That's how I found out they fly between 5000-8000ft on departure over my house, by listening to my scanner.
Dale
kaddyuk
Thu Dec 23, 2004 9:16 pm
I live 3 miles from gatwick and no aeroplanes fly over my house...
