CVR CB Posn During Towing
Fri Jan 14, 2005 4:00 pm
Is it Mandatory for Activating the CVR CB during a Mx towing operation from one bay to another parking bay adjacent.
In other words,Everytime the Aircraft is moved [Towed/Taxied] the CVR CB should be in.
Anyone.
regds
MEL
amtrosie
RE: CVR CB Posn During Towing
Fri Jan 14, 2005 10:17 pm
Your GMM (operator procedure manual) will dictate towing procedure, including whether or not the CVR C/B needs to be pulled.
air2gxs
Fri Jan 14, 2005 11:27 pm
Yup, its all operator specific. I've worked for airlines that required the CB, for both CVR and FDR, pulled and I've worked for operators that insist (checklist item) that they are in.
On reflection, in the past ten years or so, as the industry has moved from tape based to digital based recorders, the tendency to pull the CB has gone away. My guess is that since we (maintenance) are not eating into the life of the CVR or FDR recording medium, our operators will insist that the recorders are operative in case of a problem, so the "tapes" can be reviewed.
Sat Jan 15, 2005 3:34 pm
Out here its mandatory.
regds
MEL
pilotaydin
Sat Jan 15, 2005 6:58 pm
in the JAA regulations it states that the CVR only needs to be on when the a/c is operating under it's own power...however operators may impose stricter regulations.
The only time there is too much fuel onboard, is when you're on fire!
Sat Jan 15, 2005 9:41 pm
The reason could be to Investigate any Incident occuring.
regds
MEL
Users browsing this forum: GriN, sharles and 1 guest
