BMI701EGCC
Default Speed/height Of LOC* Interception
Sat Feb 12, 2005 9:44 am
Scott Waterworth
BMI701EGCC
G-PATI-"G-PATI, Back inbound to Barton"MCT APR-"G-PATI, Continue, Keep lookout on VFR traffic"
corey07850
RE: Default Speed/height Of LOC* Interception
Sat Feb 12, 2005 9:47 am
More specfic.... What type of plane? what airport?
flyf15
Sat Feb 12, 2005 4:54 pm
Every aircraft has an approach speed and every approach has its own localizer and glideslope intercept heights.
Approach speed is typically in the high double digits or low to mid 100s depending on aircraft, weight, etc. Localizer intercept...typically a couple thousand feet up, depending on the approach, how the final approach course was entered, etc.
BMI701EGCC
Sun Feb 13, 2005 8:48 pm
A320 series?
Scott Waterworth
BMI701EGCC
PhilSquares
Sun Feb 13, 2005 9:41 pm
Perhaps, I don't understand the question, but it's really dependent on the approach for the intercepts of glide slope and localizer. For the speed, it is aircraft dependent.
For the 744, depending on gross weight, the average approach speed would be around 155KIAS. At Changi (WSSS), 02L/C you're generally vectored in anywhere between 10-14 miles to intercept the Localizer at around 2500'. Your glide slope intercept on those approaches is generally just before 8 DME. Obviously, if you were vectored in higher the intercept would be further out (every 1000' would be just over 3 miles further out) and the converse would be also true.
Again, I'm not quite sure what you're asking, but if that isn't what you're looking for perhaps you could rephrase the question.
Fly fast, live slow
star_world
Sun Feb 13, 2005 10:22 pm
It's impossible to answer this without giving some more detail - as already said above it'll vary significantly depending on what approach into which airport you're talking about...
fspilot747
Sun Feb 13, 2005 10:52 pm
As Star world said, we need a little more detail. It depends on the airport.
As a rule of thumb, you want to intercept the glideslope from below in order to avoid catching the false glideslope.
Other than that and what Philsquares wrote, I don't know what you really want to know.
You could possibly type out the question in a sentence  Big grin
FSP
[Edited 2005-02-13 14:53:08]
SlamClick
Mon Feb 14, 2005 4:21 am
And check back in from time to time to acknowledge the answers.
Users browsing this forum: 747classic, tommy1808, WPvsMW and 11 guests
