dl757md
787 Wing Tanks
Mon Feb 14, 2005 6:25 pm
Reading the other thread about wing tanks, a question came to mind. Does anyone here know how the tanks on the 787 will be sealed to hold fuel?
Fuel and composites don't exactly get along. Carbon fiber probably does the best of the aviation composites but over time problems do occur.
Will they have bladders? A special sealer applied to the inside of integral tanks? I can't really see that working too well as every sealer I've used in tanks fails eventually due to the flexing of the wings. Unlike composites, this isn't a structural problem in aluminum wings as the fuel doesn't adversely affect the metal. Perhaps they have developed a fuel proof resins?
Anybody have any insight or guesses?
Dl757Md
widebodyphotog
RE: 787 Wing Tanks
Mon Feb 14, 2005 7:31 pm
The wing spar structure of 787 will not be made of composites so it will hold fuel just like any other modern airliner.
-widebodyphotog
If you know what's really going on then you'll know what to do
dl757md
RE: 787 Wing Tanks
Mon Feb 14, 2005 7:58 pm
Widebodyphotog
I'm not trying to flame your post. I don't however understand the premise behind it.
From the Boeing website http://www.boeing.com/commercial/7e7/background.html
"Boeing has announced that the majority of the primary structure including the fuselage and wing on the 787 will be made of composite materials."
While it's not specific about the spars it does say the majority of the primary structure. Even if the spars are aluminum the skins, ribs, and stringers are the only other primary structure in the wing. If they are composite they will also be in contact with the fuel. The structure of the wings that forms the integral tanks in modern airliner's wings IS the primary structure of the wings. There are composite components of current wings but they are limited to flight control surfaces and secondary structure(closeout panels and such). If Boeing states that most of the PRIMARY structure of the 787's wings will be composite how do you figure it won't be. Is the Boeing site misleading us?
Dl757Md
[Edited 2005-02-14 11:59:24]
2H4
RE: 787 Wing Tanks
Tue Feb 15, 2005 12:35 am
Great question, Dl757Md. I look forward to hearing the answer.
2H4
Intentionally Left Blank
OldAeroGuy
RE: 787 Wing Tanks
Tue Feb 15, 2005 1:37 am
The A330 and A340 have used a composite H. tail as a fuel tank through out their production life. The B2 is essentially all composite and has used the wing as a fuel tank as it has no other option.
If it works on these aircraft, why should the 787 be any different?
AUAE
RE: 787 Wing Tanks
Tue Feb 15, 2005 1:42 am
I am only guessing, but given the weight penalties of rubber bladders I am sure it is some sort of coating on the inside of tanks.
Shawn
Air transport is just a glorified bus operation. -Michael O'Leary, Ryanair's chief executive
A350
RE: 787 Wing Tanks
Tue Feb 15, 2005 2:41 am
Just a guess, but from a chemistry and engineering point of view I would suggest a teflon coating. Teflon (CxF2x) is very light and chemically extremely inert.
A350
dl757md
RE: 787 Wing Tanks
Tue Feb 15, 2005 2:58 am
Good point OldAeroGuy but I never said it wouldn't work. I merely asked if anyone knows how they will make it work. I have every confidence Boeing has addressed the issue, just was wondering how.
I didn't realize the A330 and A340 horizontal stabs are composite and wet. I forgot about the B-2. So I'm sure this has been addressed and somebody out here has the answer as to what methods are used in these aircraft.
To answer your question, one reason the 787 would be different from the B-2 is that commercial aircraft are utilized far more greatly than military aircraft. I'm sure that operational readiness is very important with the B-2 but I highly doubt that it could come close to delivering a 98% dispatch rate if it were operated 8+hrs every day as airliners are expected to. Basically it has much more ground time with which to correct the technical difficulties I envision with a composite integral tank.
AUAE I like your signature.
A point of view I'm sure a lot of airline CEOs have these days. They just don't have the balls to say it publicly.
Dl757Md
OldAeroGuy
RE: 787 Wing Tanks
Tue Feb 15, 2005 5:46 am
DI757md,
I do appreciate the utilization differences between military and commercial airplanes, but the B2 has been around for a long time so I threw that in as example of how problems would have been recognized and corrected.
By the way, I agree totally with your thoughts on the 757. One of the best examples of "Looks Good, Flies Good".
dl757md
RE: 787 Wing Tanks
Tue Feb 15, 2005 6:08 am
OldAeroGuy
I guess where I was coming from in my remarks about the B-2 is that due to the military's lower utilization of the airframe, they might be more willing to repetitively maintain a problem inherent with an aircraft rather than demand a permanent solution as the airlines would because their planes need to fly more.
Put another way the military might accept 10% of a fleet down at one time for mtc. whereas the same situation would kill an airliner. I know it's a tough generalization to justify but it's how I feel.
I'm glad we share the same fondness for the 57. Just wish someday when I'm doing a takeoff power run at the run-up area at the end of the runway I could release the brakes and see what it's like to fly one!  Big grin
Dl757Md
RE: 787 Wing Tanks
Tue Feb 15, 2005 4:55 pm
Presumingly there must be a Coating application on the Insides of the tank to act as a barrier of the Fuel.
These question sure make me more eager to await the Flight of the B7E7.
 Smile
regds
MEL
Users browsing this forum: celestar345, StereoTechque, VolvoBus and 20 guests
