Bruce
Taking Off With Tailwind
Wed Feb 16, 2005 8:39 am
I recently took a second look at one of my window views.
Photo © Bruce Leibowitz
We're taking off on 22, and there is a windsock out there that shows us going in the direction of the wind! What do you guys think based on this photo? Could that be for real? I thought that there was a 6kt limit on tailwinds for safe takeoff - that windsock looks like a bit more than 6kts! It appears to be pointed right in the direction we are going but could be slightly off but that is not taking off "into the wind"! There was no bad weather on that day and the ride was not unusually bumpy.
bruce
Pihero
RE: Taking Off With Tailwind
Wed Feb 16, 2005 8:59 am
The usual tail wind component limit is 10kts for most airlines.
There are even a few airfields where the local DGCA allows 15 kts (if there is only one direction for take-offs for obstacle clearance reasons).
According to your picture,the wind velocity is just under 10kts; Older pilots would tell you a straight sock is worth 15kts if stable.
Contrail designer
Bruce
Wed Feb 16, 2005 9:13 am
So then that is pretty close to the limit.... Maybe i should have said, what is the recommended limit on a 737-200 for takeoff tailwind?
Its probably ok for them because its a 732, but if that were an airport with bigger jets then they would have turned the pattern around by then, right?
I wonder if this is something that Southwest does a lot to save time....it was a very short taxi from the gate and 22 was close to the direction they needed to go....going to the other end and takeoff on 4 would add some time.
bruce
wilco737
Wed Feb 16, 2005 3:51 pm
Hi Bruce,
I fly 737's and the max tailwind component for take off is 10 kts, in some rare cases 15 kts. Tailwind in general is something you dont want for take off! It in creses your take off roll and your performance is less etc etc! but as you said: the way to taxi was shorten a lot and runway 22 is better for the destination... and if the runway is long enough and the other weather conditions are good then you can take off with tailwind up to the max component to safe time/fuel/money. For the take off calculation you consider the tailwind and then you are on the safe side, so no worries....  Wink/being sarcastic
WILCO737
Wed Feb 16, 2005 4:10 pm
What would be these rare cases like.
regds
MEL
wilco737
Wed Feb 16, 2005 6:01 pm
hi Hawk21M,
for example I fly for LH and we are allowed to take off with tailwind 15 kts on runway 18 in Frankfurt... thats pretty much the only case where we are allowed to do that....
WILCO737
Users browsing this forum: 7673mech and 1 guest
